Group Buy '16: Dreadnought Avel Lindberg 1000VA Isolation Transformers
1…34689…16
    msg Posts: 10,650
    SketchyCraig. One of my favorite dudes.
  • Goat
    Goat Posts: 6
    edited January 2017
    Hi all, just joined and am researching all of this. I have wanted a pair of polk SDA's for a long time. I had a pair of monitor 12's many years ago and regret selling them. I just landed a pair of 2.3tl's and my amp is mono design so to use it I would need to buy or build one of these. Is there a chance to get in on this yet? Now I am running a pair of carver amazing originals that the ribbons are just about done for on so it was time to find another speaker I always wanted to have but never could afford at the time.
  • vcwatkins
    vcwatkins Posts: 1,992
    Hi, @Goat. Congrats on the 2.3tl's and welcome to the forum.
    You can still join the group buy. I will send you information. As long as payment and shipping info is received by the time all the current members pay, you'll be in. To give you an idea on timing, we are 75% paid up after two days. Look for a PM from me today.
    Thanks,
    Craig
  • lightman1
    lightman1 Posts: 10,802
    SketchyCraig is the man!
  • nikonik
    nikonik Posts: 120
    $ent :)
  • gmcman
    gmcman Posts: 1,877
    Funds sent. Thanks again for setting this up.
  • Goat
    Goat Posts: 6
    Funds sent. Thanks for adding me in!
  • vcwatkins
    Great job on settling up, guys! 85% home.
  • gmcman
    gmcman Posts: 1,877
    Toolfan66 wrote: »
    Nice!
    heiney9 Posts: 25,709
    Sweet, but can we get some info about how the cases are prepped? I am not using Neutrik, but standard speaker terminals. Are the cases pre-drilled? If so, what pre-drilled options do we have?
  • nspindel
    nspindel Posts: 5,343
    So Larry what about the idea of a badge??? Someone around here's gotta be a decent graphics guy, do up some sort of Dread logo and somehow get it on the front face?
  • BlueBirdMusic
    I would like to have Larry's old "Eyeball" profile pic as a badge perhaps with the word "Dreadnought" to the right of it.
    Harry / Marietta GA
  • nspindel
    I was thinking something a little more Rasta mon.
  • BlueBirdMusic
    I don't know what that means mon? Examples?
    Harry / Marietta GA
  • nspindel
    Never been to Jamaica eh?
  • nspindel
    I'm thinking about a smiling Jamaican dude with huge dreads and a pair of speakers. And then the word Dreadnought spelled out underneath.
  • BlueBirdMusic
    That sounds like a unique one.
    Harry / Marietta GA
    edited January 2017
    Toolfan66 wrote: »
    heiney9 wrote: »
    I will post more later, I can just send you blank panels, and you can mod to your liking..
    Since I wasn't paying that much attention to the first couple rounds, I wasn't sure how they were manufactured. I'd prefer to have them done. I don't have the tools or work bench necessary to do it easily or neatly....lol. I don't even know how they are assembled.
    Mine was more or less an inquiry as to how or what options were available.
    I also don't have the tranny to see the orientation of the wires, etc.
    P.s. If we are going to discuss the cases later-on that's fine.
  • vcwatkins
    Great job on settling up, guys!. Just 3 to settle up and we're home.
  • vcwatkins
    2 more to go!
    I agree, very impressed this is going so smoothly. Not that it wouldn't, but usually when collecting funds there are a few hiccups, delays, discrepancies, etc.
    If Avel Lindberg turns these out quickly we'll be up and running in no time.
    F1nut Posts: 52,406
    Quit being a pain Brock, use the Neutrik connectors.
    I am not modding everything just for the Neutrik's. I didn't know that was how the cases were all manufactured. But then there isn't a thread for the cases yet to see how those are constructed.
    edited January 2017
    My space is very limited and I may end up placing the case vertically, that's why I will need to know at some point how the cases are made, dimensions and what options we have for connection.
  • vcwatkins
    The case I got from Larry in '12 was drilled for binding posts. Not sure if the '14 crew got all Neutrik, all binding posts, or a mix? Think it was a mixture, but not sure.
    F1nut Posts: 52,406
    The case should be vertical as it sounds better that way. In regards to the orientation it matters not which connection type is used.
  • vcwatkins
    heiney9 wrote: »
    I have mine sitting vertically on what would ordinarily be the face plate with binding posts on the top plate that would ordinarily be the rear. Pretty sure F1's Neutriks are on opposing ends to be used vertically (or horizontally too I suppose).
    I am not modding my SDA terminal cups to accept Neutriks. Ideally I'd like to set it up like your Craig, except have the binding posts mounted on each side, but I'm not sure of the orientation of the wiring for the transformer. That's the cleanest and best way for wire management. Having all MIT stuff really takes up real estate behind my low boy shelf.
  • vcwatkins
    edited January 2017
    The leads are long enough and case large enough to run to either same side or opposing sides (adjacent corners). Someone correct me if I'm wrong. but I think Larry's cases have been either Neutrik on opposing sides or BP's on same side. If so, maybe Larry could offer opposing side BP holes.
    You could easily mix the terminations - I've got Neutrik at speakers and BP's at Dreadnought. You could do the reverse/
    F1's Neutrik:
    DK's BP:
    f1dn.jpg 177.8K
    F1nut Posts: 52,406
    edited January 2017
    All connected with MIT cable, piece of cake.
