Laserdisc-The godfather of ALL consumer optical disc media
1111214161720
  • honestaquarianhonestaquarian Posts: 2,403
    Living room Home theater: Upgrade Company modified Onkyo PR-SC5509,Sunfire Cinema grand Signature 5 channel amp(1st gen),Carver TFM-45,Carver M-400a,Panasonic TC-P50ST60 50" Plasma(last gen before Plasma production stopped)Pioneer Elite DVL-91,Meridian 519 Dolby AC-3 RF Demodulator,Oppo Digital UDP-205,TiVo Bolt VOX,Nakamich BX-300,Technics SL-1200MKII,Shure V15 Type VxMR cartridge,Polk SDA-SRS 3.1 TL(with RD-0198 tweeters, upgraded with Larry's rings, black hole5,an Avel-Lindberg 1000VA isolation transformer, VR3 customer crossovers and internal wiring),Polk CS-1000P(with SL-6506 tweeter),Polk Monitor 5jr(with RD-0194 tweeters),Polk RT-35i (1),Polk Mini Monitors,Polk PSW150(4)Monster Power HTPS 7000 MKII Signature series,Monster Power AVS 2000 Signature Series,Various MIT,Monster,Upgrade Company and Belden interconnect,power,HDMI,Coax and Toslink Digital and speaker cables.
    Bedroom 2 channel system:Integra DTM 40.4,Nakamichi BX-100,TiVo mini,Musical Fidelity X-LPS,X-PSU,Carver TFM-25,Sony KV-34XBR970(last of the widescreen tube sets before production stopped)Technics SL-1200MKII,Shure V15 Type V MR cartridge,Polk RT-55(with SL-6506 tweeters),Polk PSW-200 in plexiglass(2),Sony Playstation 3 slim.Monster Power HTPS-7000,Monster AVS-2000, PowerVarious Kimber,Audioquest and MIT interconnects and speaker cables.
  • a burst of energy :)
    Studio 2 equipment;
    Yamaha a-s2100 Amp, CD-2100 CD player, T-S500 tuner
    Loudspeakers: Harbeth p3esr, Polk RT7
    Cables: Aural Harmony Sonnet Interconnect II, WireWorld Equinox 7 speaker,
    Black Cat silverstar 75 ohm digital, Signal Digital Power Cord, PS Audio Perfect Wave AC-3,
    Pangea SE14, Voltz supplied interconnects
    Optional: Arcam DV88 DVD/CD (HDCD) player, Polk SDS-400 speakers
    THE best AC-3 RF demodulator ever made!
    This is the one with the reclocking circuitry built in to lower jitter and it works!
  • F1nutF1nut Posts: 41,804
    You're the Polk forum hero, no one here knew how to search eBay.
  • nooshinjohnnooshinjohn Posts: 20,434
    What's eBay?
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with Pass Labs Xono Phono Preamp, Walker Precision Motor Drive, ClearAudio Goldfinger Diamond v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X0.2 three chassis preamp, PS Audio PerfectWave DAC MkII, Pioneer Elite SC-65, Oppo UDP-205 4K Blu-ray player, Sony XBR70x850B 4k, Polk audio AB700/800 "in-wall" surrounds.
    Saying that it's "too hard" to pursue your dreams is no different than admitting to yourself that you are too lazy to achieve them.
    “If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
  • NightfallNightfall Posts: 7,545
    I believe it's a bay in Ecuador near Guayaquil.
    afterburnt wrote: »
    Do you think they have marching powder there?
  • I have threads w/ hundreds of posts that I do not read.
    Why not try that? o:)
    Studio 2 equipment;
  • Living room Home theater: Upgrade Company modified Onkyo PR-SC5509,Sunfire Cinema grand Signature 5 channel amp(1st gen),Carver TFM-45,Carver M-400a,Panasonic TC-P50ST60 50" Plasma(last gen before Plasma production stopped)Pioneer Elite DVL-91,Meridian 519 Dolby AC-3 RF Demodulator,Oppo Digital UDP-205,TiVo Bolt VOX,Nakamich BX-300,Technics SL-1200MKII,Shure V15 Type VxMR cartridge,Polk SDA-SRS 3.1 TL(with RD-0198 tweeters, upgraded with Larry's rings, black hole5,an Avel-Lindberg 1000VA isolation transformer, VR3 customer crossovers and internal wiring),Polk CS-1000P(with SL-6506 tweeter),Polk Monitor 5jr(with RD-0194 tweeters),Polk RT-35i (1),Polk Mini Monitors,Polk PSW150(4)Monster Power HTPS 7000 MKII Signature series,Monster Power AVS 2000 Signature Series,Various MIT,Monster,Upgrade Company and Belden interconnect,power,HDMI,Coax and Toslink Digital and speaker cables.
  • [Deleted User][Deleted User] Posts: 91
    edited August 2016
    so you need some kind a converter to use the optical out right?
    The meridian does the trick?
    Studio 2 equipment;
  • @rednedtugent
    No
    Your receiver or processor will have an optical digital input. The Meridian is a Dolby AC-3 RF demodulator. It allows you to be able to decode the Dolby Digital 5.1 tracks on the Laserdisc. Because it has a reclocking circuit,it significantly lowers jitter (*which Laserdiscs are known to have lots of*) to give you cleaner sound and it WORKS!
    My discs from 3" to 12" ALL sound better with it in the signal path.
    BTW both of the functioning Meridians on eBay have been sold. There is one non functioning unit that is still up for sale and he is asking for too much for it.
  • P.S. YES you could use the Meridian to convert the Optical to RCA. However the odds that you don't have an optical in are far less likely than not having an RCA digital input.
    afterburnt wrote: »
  • thanks HA and @nightfall!
    I thought I read somewhere that the old optical was a diff signal
    and needed a convertor. Thanks for the correction.
    So the 97 seems to be the player to get...
    Studio 2 equipment;
  • @rednedtugent
    The CLD-97 doesn't have an AC-3 RF out just so's you know. The thing is a TANK though. If you're looking for something that has an AC-3. RF out then the CLD-99 which is the player that replaced it is the way to go. They used to have kits that you could have installed to upgrade them,but good luck trying to find one of those now. Every so often you can find a CLD-97 up for sale with the mod. I may even have posted a link to one of those auctions. However they are ridiculously expensive and rare.
  • StantonZStantonZ Posts: 393
    edited August 2016
    Blast from the past: I watched The Abyss LD last night, and while the video left a little to be desired (I'm left to upconverting composite video in the brave new world), the DD5.1 audio was great! The AC-3 RF out goes through a B&K DT-1 demod to my AVR.
    Yamaha RX-A2050 AVR (5.0.2)
    (2) Polk Monitor 4's w/peerless tweets (Top Middle)
    Polk CS300 center channel
    LG 65EF9500 4K OLED
  • StantonZ wrote: »
    @StantonZ
    Was it one of the special editions?
    They released it letterboxed and pan & scan. The reviewers all said get the pan & scan for some reason. I just couldn't and got the letterbox.
    edited August 2016
    StantonZ wrote: »
    @StantonZ
    I believe it was, because I had to "re-buy" it (originally had the non AC-3 version). I'm allergic to pan & scan. :p
    What kills me is how much we used to pay for these things...especially the box sets...and now they're worth like $1.
    LG 65EF9500 4K OLED
Howdy, Stranger!
