This joint needs some more vintage hifi
1394042444562
  • boston1450
    boston1450 Posts: 7,758
    Just scored a MASSIVE almost broke my back integrated amplifier today :) will report back later
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • oldrocker
    oldrocker Posts: 2,590
    boston1450 wrote: »
    Hmm, massive weight and back strain. Me needs to know whatcha got :o
  • boston1450
    Sa-155 :)3m4xvg2cm76u.jpeg
    Randy-Maine
    by David WMG
    mhardy6647 Posts: 35,230
    irony... or is it sarcasm?
    I had one of the little, earlier R/S amps for a while; used it as a bench/test amp. It worked; that's about all I can say about it.
    11385036933_0cb271dca7_b.jpgP2170002 by Mark Hardy, on Flickr
    Well, actually, I can say another thing about it... the design of the one I had was all-discrete inside -- probably not a bad thing, and certainly something that could be tweaked a bit with better electrolytics, e.g. -- although the term polishing a t-u-r-d may come to mind...
    11384894815_286366313c_b.jpgP2170005 by Mark Hardy, on Flickr
    1979
    1994 (original SA-155 variant, branded "Optimus" instead of "RCA")
    R/S sold the silver-fronted SA-150 for a long time, prior to the 155, but I don't know if it differed only cosmetically or if the guts were any different.
  • boston1450
    edited July 2016
    Mark i have one of those SA-10's somewhere. Tough ole amplifiers
    Randy-Maine
    by David WMG
  • boston1450
    la2vegas wrote: »
    Had me envisioning something on a pallet. Kinda like Joey out in TX.
    Few more years & i will need a pallet & jack
    Randy-Maine
    by David WMG
  • jdjohn
    jdjohn Posts: 3,384
    edited July 2016
    I recently found these Infinity Column II floorstanders on CL for $75. Back in the mid 70s these went for over a grand for a pair. They have bottom-firing 10in subs in addition to the front woofers, and also rear-mounted tweeters on the back. The front tweeters are replacements - compression horn tweeters - but the rear ones are original piezos.
    The Sansui 9090 drives them easily. These speakers are bass-heavy as you might expect with dual 10in woofers.
    Post edited by jdjohn on
  • boston1450
    That there is a sweet set up there. Gorgeous speaker
    Randy-Maine
    by David WMG
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Dang! I want that equipment rack.
  • boston1450
    udi204f0dcg4.jpeg just put on some new knob caps on. They came out pretty good. Listened to it earlier with some Ben Tankard & some Clapton. Now i just gotta get someone to completely rehab the inner's & im sure it will sound much better than it already does
    Randy-Maine
    by David WMG
    Unless you're focused on a professional job (which, don't get me wrong, a 400 deserves), and if you feel like schlepping it way over to the other side of NH, I can do a rehab for you for the cost of parts -- I've done a couple of 400s; they're very easy (plenty of room under the hood). I am just... slow. Ask mrbiron :-/
    15398531316_9081a8f560_b.jpgundersidenoveau by Mark Hardy, on Flickr
    This is what a 400 looks like below the deck when I have been dinking around with one.
    edited August 2016
  • boston1450
    la2vegas wrote: »
    Those speaker look clean & with boxes to boot. Do tell us what you think. Awhile back i had some small KEF c15's (i think)& hooked them to a nad 3020 & they sounded ok for their size. Heck if you ship me that gorgeous receiver-it tell ya plastic Aiwa's are great :)
    Randy-Maine
    by David WMG
  • oldrocker
    I wondered what was peaking around the corner..
    edited August 2016
    la2vegas wrote: »
    I second that yes, and I have a pair running on a Realistic STA-2270 and an old '90s Sony CDP. Nice vintage system for next to nothing. I picked up a pair from a local guy who begged me to also take an old HK 330C with them for nothing; a whopping $15 for the KEFs. The HK is missing a knob, but worked fine after a DeOxit bath. (Some Karmas will be coming as I need to thin the herd in the next year or so and I HATE selling things).
    And now, back to the way Hell should be!
  • Nightfall
    Nightfall Posts: 10,083
    Crazy, the journey an audio signal takes before it's reproduced.
    afterburnt wrote: »
    Village Idiot of Club Polk
    edited August 2016
    Nightfall wrote: »
    Not at my house. From the source, each channel passes through a source selector switch, and autoformer (attenuator), three triodes, a few resistors & capacitors, and a transformer (oh, and some wire) to get to the loudspeaker. OK, to the crossover first, and thence to the loudspeaker.
    That other stuff was all just a way for hifi hardware makers to charge more money for their stuff ;-)
    Post edited by mhardy6647 on
  • pumpkinman
    pumpkinman Posts: 10,313
    edited August 2016
    Sorry wrong thread
    Because I am The Pumpkinking
    aww :-( c'mon back! :-)
  • boston1450
    Dynaco A25's Havent had a chance to listened to these yet. Gonna try them on The Fisher 400 which the owner said he used it in on Fisher & other gear with great results. If it doesnt fly i can use them elsewhere. p6wcn5czzhc2.jpeg
    Randy-Maine
    by David WMG
    edited August 2016
    Good loudspeakers. Not in the pantheon of great loudspeakers, but musical, well-behaved and very pleasant to listen to (EDIT, just my opinions, of course). Also happy with modest input power and a pretty well behaved load impedance-wise.
    Every hifi nut ought to have a pair, if only for comparative/reference purposes, since zillions of them were made and many, many folks are familiar with/used to their sound.
  • boston1450
    I spent a fair amount of time reading up on them & they seem to be well liked. So im looking forward to listening to them. I may try them on the cr1000 tomorrow & then just tuck em away till the Fisher is ready
    Randy-Maine
    by David WMG
  • boston1450
    BTW the last owner says he did the crossovers & bypassed the adjustable knob on back. I will know more when i open them up
    Randy-Maine
    by David WMG
  • [Deleted User]
    They like tubes as well...
    boston1450 wrote: »
  • Nightfall
    My new linear tracking Yamaha PX-3 has been working flawlessly, love this thing!
    afterburnt wrote: »
    edited August 2016
    I bought my parents a pair of them in the late 1970s (used); they served my folks well for the rest of their lives and I kept them after my parents were both gone -- and I still have them (the Dynacos, that is -- I not goin' all Norman Bates on you all!).
    edited August 2016
    A25s? Yep! Have a pair. Pretty ratty looking but drivers are mint! I run mine with an HK 430, a superb combo. Probably even better with good tubes.
    They may not be great speakers in the classic sense as Mr. M points out (and he should know, because he knows that he knows-ridiculously redundant, no?), but you can listen to these all day every day. And that, to me, is the most important thing! I find myself NOT listening to my BEST speakers most of the time but opting for the more laid back warmth of certain classics like this. But my ears are probably full of olive oil and yours may not be! lol And what do I know anyway, I'm mostly superfluous!
    I think you'll find them to your taste, Randy. Although, from a lot of your posts, you seem to like the really Big Bad cabinets with room filling sound and thunderous bass.
    12980008165_d42bcedc8f_b.jpgP1020753 by Mark Hardy, on Flickr
    He's really gonna need a pair of Altec Valencias... or bigger.
    Even a pair of (gasp) Klipsch Cornwalls are pretty darned enjoyable driven by a Fisher vacuum tube receiver.
    15414336868_4c36deb6de_b.jpgRcornieoly by Mark Hardy, on Flickr
    (my Valencias & Cornies are long gone, though)
    I was a little hard on the A25s earlier, and I'm sorry about that -- I have always liked them and (as mentioned) I do have a pair (mine are in need of cosmetic refreshent, too). Heck, I have a pair of A35s, as well -- but they sorta don't count, since I found 'em at the dump in Harvard, MA. They're very nice loudspeakers, but more in the "Polk Monitor 7" neck of the woods... probably not most folks' be-all and end-all loudspeakers.
    14605877941_1a0f03f24d_b.jpgDSC_9644 by Mark Hardy, on Flickr
    Dynaco A-35.
