Building a pair of Polk Monitor 10's
All I can say is let me know if you decide to build an experimental pair of cabinets for SDA 2Bs. I will happily test them out for you...
Like it is with most trades, it sure pays to have the right tools. Beautiful work there.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
deucekazoo wrote: »
Sorry, but nothing makes the grain of wood pop like a dye and a film coat. New walnut is cold, it needs to be warmed up.
The type of finish has everything to do with how the wood looks and I am not talking about stain. I once ruined (well not ruined but not the look I was going for) a pre-amp box I made. I used Bloodwood and maple for the box. At that time I did not know finishes too well and used a poly to finish it. The blood wood turned brown. If you know Bloodwood it has a nice deep red to it.
From this
To this
Same wood, different finishes.
Polk S10, S8, S4
Polk RT8
Polk Monitor 7s
Working on getting SDAs -
While true that the type of finish and the sheen have an effect on the final appearance, it's not everything. Poly should not have caused that to happen. What brand, wiping or brush, how old was it?
President of Club Polk -
deucekazoo wrote: »
To each their own... walnut can be a bit cold but to that point almost any wood grain can be a bit harsh... With the right dye and film coat you can make poplar pop...
Will I am -
Not sure about the brand name but it was a quality brand, not a no brand name from Walmart. It was a brush on and I think it was water based.
I know what you are saying, I was not expecting that color either. I just know certain finishes go deep into the wood to bring out the beauty. I never had Walnut look cold.
Now back to speaker building. Let see some more pictures.
Polk S10, S8, S4
Polk RT8
Polk Monitor 7s
There's the problem. Water borne finishes have gotten better, but still aren't there. Not unlike fluorescent compared to incandescent lighting. I do not use water borne finishes, won't even consider them.I never had Walnut look cold.
The walnut in willwilly's pics is cold.
Will, I would be remiss if I didn't say your craftsmanship is top notch.Political Correctness'.........defined
One down...
Will I am -
Well a bit of bad news, using one of my MW6503'S in the shop to test fit holes several times, being passed around with visitors... even having the JB weld treatment on the top plate, the driver locked up.
I see the logic in the JB weld technique, but make sure you do it on the top and bottom side of the magnet... Mine were done on just the top edge of the magnet.
So if anyone has a good 6503 laying around, I'm interested.
I have yet to abandoned a resemblance of a budget, or I would buy four new drivers.
Thanks in advance.
Will I am -
So while I'm waiting for the last coat to dry, this is a sample I put together of 1" MDF. I have been researching vinyl wraps to see what is available. These wraps can be pricey, and make any wood worker gag, but...for a speaker, handled properly, vinyl may be an acceptable option. Did I say that out loud.
Will I am -
This is my Garage system. I using two 5jrs' and 4's. I'll be using a Denon AVR5700 to drive my 10's.
Will I am -
Because I am The Pumpkinking
Max treble on the receiver, max treble on the EQ, holy cr ap you like a lot of high end.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
And with the Loudness maxed out. UGH!Political Correctness'.........defined
Somehow I knew I was in for it posting a picture of my system...Will I am
Those 10's are no longer garage worthy
And they deserve a new gear family2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Might I suggest a pair of Klipsch on Emotiva gear?
All things aside, I agree with Skip.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Just some are more apt to Criticize than Advise! But that aside. Exemplary workmanship! I've enjoyed following your thread,looking forward to seeing the finished pair! Btw if your interested in starting another project,yesterday in the for sale section GEPPY1 listed a selection of parts for sda2b's that are definitely worthy of your level of craftsmanship,,,[upgraded crossovers and tweets- worth consideration]
Post edited by notified on -
I don't know if this is proper but it is a great deal easier than painting MDF.
One complement I have for this forum is the high res pictures. You can zoom up on these and see the most minute detail. I see things in the pictures I don't see, even with my glasses on.
Will I am -
Weak, old plastic with new seal bends and one hole cracked. Larry's ring for the crossover?
Will I am -
The next discussion will be Monitor 7's. I have most of the parts. These will most likely get new drivers and RDO 198's. I have original crossovers that will get new caps, and a original pair of PR's.
Look at me throwing around speaker talk like I know what I'm doing...
Off to the fabric store for polyfill. I feel so uncomfortable in that store...
Will I am -
If they have bonded Dacron, it will work better than Polyfil. It's what Polk used originally.The next discussion will be Monitor 7's. I have most of the parts. These will most likely get new drivers and RDO 198's. I have original crossovers that will get new caps, and a original pair of PR's.
Home Theater/2 Channel:
dhsspeakerservice.com/ -
No Bonded Dacron, 2" Polyfill...
A roll sitting behind the tweeter, and just a few staples to hold it in place...
Will I am -
Stock M10'S do not have Dacron in the PR compartment. Also it is rolled up behind the mids.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm. -
Really, I have plenty of fill.motorhead43026 wrote: »Stock M10'S do not have Dacron in the PR compartment. Also it is rolled up behind the mids.
Will I am
