Which would yield the better performance gain-high end interconnects or spk.wire?
1234568
Answers
    tonyb Posts: 33,072
    rmpolk wrote: »
    Tony b-Semantics must play a big role in your life
    No, not really, but when one tries to prove a point it's best to be factually correct.
    tonyb Posts: 33,072
    Depends on how you define "error". Misspoke can be viewed as an error, a design flaw can also be viewed as an error. Speaking without thinking can be viewed as an error. Quoting things out of context can also be viewed as an error.
    One must assume then, that an "error" is also subjective. Hence the importance of being factually correct.
    tonyb Posts: 33,072
    .....and, I'm not always factually correct myself. I make tons of "errors". I just blame my old age for them. ;)
    gudnoyez Posts: 8,161
    So I'm so confused people need a set of interconnects for my Vincent PHO 700 as I'm borrowing my signal interconnects running the analogs from my Oppo to my AVR, but need to put em back. I have a pair of 1M Wireworld Solstice 7's in my cart, should I save the money and just use the cheapie red and white stock interconnects of which I have a drawer full of, because according to some I wouldn't hear much of a difference anyways. What to do just what to do? Somebody please help me out on a decision.
  • Nightfall
    Nightfall Posts: 10,084
    That drawer of red and white "box in" cables you have are unnecessary, sell them and get your money back. All you need are four thin single strands of copper, tape them to the positive and negative areas of the female RCA connectors. Scotch tape should do.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Geoff4rfc
    Geoff4rfc Posts: 2,823
    So, I had a few good laughs here, especially after skimming through 9 pages of food stuffed yummyness and some good face slapping, but what about the OP?? Did he settle on Hotdogs or Popcorn to improve his set up??
    Now I'm hungry for some sausage
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • Nightfall
    @rmpolk We would likewise like to offer our condolences if you have also been embarrassed in front of everyone regarding your reading comprehension - specifically relating to this post.
    BlueFox wrote:
    This is a useless quote, if that is what it is. Post a link to it so the reader can judge the veracity of the source, and understand the context. For all anyone knows, you just made up your 'quote'.
    Sincerely, we are all very sorry to have had this come out in public like it has.
    afterburnt wrote: »
    F1nut Posts: 51,737
    Josh, that deserves a big...WAAAAAAAAAAAAAAAAA
  • K_M
    K_M Posts: 1,632
    edited March 2016
    StevieB wrote: »
    For 2 channel listening, whomever on this site came up with 'everything matters' has hit the nail on the head. If and that is a big if, you are wanting to search for synergy in your system to your ears, everything matters, from components to interconnects to speaker wires. Pretty simple.
    It was not only a phrase used in well known quotes, but used as sales slogans years before.
    "It is what it is" Hard to argue with though, I will give you that :)
    Living with an obsessive/compulsive person, everything can matter in their mind, and having known carefree people, almost nothing matters to them.
    There is a ground in the middle that is reality.
    Post edited by K_M on
  • K_M
    K_M Posts: 1,632
    tonyb wrote: »
    rmpolk wrote: »
    Tony b- Since you took the time to respond to my posting on the other relevant thread I'll respond in kind and re-post my reply to your post here to: I'm curious to see how many other members agree with all your viewpoints on this subject. I'll admit I don't know Much on this subject and I may prove naive but I posted it because I believe what I read!!--[read]past tense implied [red] Hope to hear some feedback but please be aware I was referring to the issue of cable only in relation to my reference to what i copied from the net in my previous post
    No, you believe what you want to believe and read what supports the conclusions you've already subscribed to. If you simply believe everything you read, go read cable manufacturers marketing and reviews. How do you decipher the different opinions you'll read ?....if you truly believe everything you read.
    Stevieb,
    Great post. A little here and a little there all adds up to something bigger. Hence the everything matters we keep throwing around.
    That is most likely true of all people. (believe what one wants to believe)
    One must come to their own conclusions, based on several factors. Logic, common sense, experience, known information that is based on reality, has no reason to be biased etc, and the biased opinions of individuals. (subjective perceptions)
    They all hold different weight though.
    It is just as likely to come to a wrong "conclusion" and still feel that one is "right"
    Bias, expectation, peer pressure, and many other things factor into one's perception of right or wrong, possible or not possible, better or worse.
    Just as though a perception or bias or expectation can make something seem "Right" or "Meaningful" to an individual, their claims and experiences, will not always coincide with another's reality, especially if they are willingly or unwillingly unaware of their bias, or expectation.
    Their explanation is simple to them.
    "Other people can not hear what I hear"
    Where the issue starts, is when one believes their own subjective reality, makes their view superior, and are unable to understand why others do not always share their view.
    There is usually no consideration at all made, for their subjective perception to ever be wrong or be questioned.
    It can not be put to any test.
    It can not be scrutinized or questioned.
    As you say Tony, "believe what you want to believe"
    txcoastal1 Posts: 13,507
    ^^^^Keep in mind the street goes both ways
  • motorhead43026
    motorhead43026 Posts: 4,009
    edited March 2016
    deleted
    – Kevin Alfred Strom
    tonyb Posts: 33,072
    edited March 2016
    txcoastal1 wrote: »
    Amen to that.
    Bias and perception are often spoke of as a bad thing, but are they really ? We all use them, we all have different biases and perceptions on what the best appliance is, TV, Lawn mower, shoes, the list goes on.
    That's the reason we have a variety of products, audio or otherwise, to cater to those biases and perceptions. When it comes to audio, the only perceptions that matter are yours, not mine or someone else's.
    That said, your perceptions/biases change over time. Mine certainly have from my earlier days in audio to now. How do they change though ?
    Part is your hearing changes, preferences in music, and....you've gained more knowledge along the way by trying different stuff, hearing different gear at friends or shows. Remember the old saying, "When I see it, I'll believe it ?" Which is why most don't believe in Aliens, Ghosts, or Bigfoot. Nobody but a select few, supposedly, have ever seen them. Audio is no different, hearing is believing. If you never attempt to hear anything, you obviously will never believe anything, audio wise. Capiche ?
    tonyb Posts: 33,072
    LOL....only I can bring Aliens, Ghosts, and bigfoot into a cable discussion.
  • K_M
    K_M Posts: 1,632
    txcoastal1 wrote: »
    Absolutely!
    and I think I was saying that.
  • K_M
    K_M Posts: 1,632
    tonyb wrote: »
    txcoastal1 wrote: »
    .... Audio is no different, hearing is believing. If you never attempt to hear anything, you obviously will never believe anything, audio wise. Capiche ?
    Yes, hearing is believing.
    Proof of a belief is reality.
    tonyb Posts: 33,072
    K_M wrote: »
    tonyb wrote: »
    txcoastal1 wrote: »
    The proof is what you hear. Why does one need to prove anything to anyone ? Listen for yourself and determine your own reality. My reality doesn't have to coincide with yours, nor yours mine.
  • ken brydson
    ken brydson Posts: 8,997
    Jesse, you need to change your profile pic to this... dang
    nooshinjohn Posts: 25,906
    K_M wrote: »
    tonyb wrote: »
    txcoastal1 wrote: »
    I believe in God, and the proof is all around me. I believe cables and everything else in a music system matters, and the proof is heard by my ears.
  • 11tsteve
    11tsteve Posts: 1,166
    K_M wrote: »
    tonyb wrote: »
    rmpolk wrote: »
    Stevieb,
    I believe the issue is why people who believe cables don't matter bother to get involved in these threads.
    The OP asked a genuine question about cables making a difference. You KNOW this will be a thread populated by the ProCable faction, the "Everything Matters" crowd, and that belief is firm.
    So why bother??? Unless you are looking for an argument? It's the same result, every time, leading to snarky comments and sarcastic memes. Neither side will change the other's minds, and yet it always ends up with this pseudo-philosophical debate over humankind's ability to have differing POV and still believe wholeheartedly both are true.... ugh.
    And then I read every single cable debate. Sheesh.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • lightman1
    lightman1 Posts: 10,796
    Sorry about the memes, Steve. >:)
  • 11tsteve
    Polk Lsi9
    Keces DA-131 mk.II
    tonyb Posts: 33,072
    edited March 2016
    oops
    tonyb Posts: 33,072
    Not necessarily true Kelly. How can a perception be wrong and what test is available to prove that ? Perception is truth to that individual.
    However, perceptions can change, thus so can the truth for that individual. Do you still hold the same perceptions about anything today as you did in your teenage years ? So your truth then must differ from your truth now, right ? What changed ? Maybe you matured, got wiser, had some life experiences that influenced your perceptions and changed your truth ?
    When one explains the process in which they came to their perceptions, then questions are asked and faults in the process exposed. Which at that point suggestions can be made to improve the process, it's no guarantee their perceptions will change though.
    Kinda like a recipe for cookies someone gives you. Best cookies in the world, you gotta try these. You make them and they turn out like garbage. Those who love the cookies will ask what did you do wrong. ? Did you follow the recipe ? Change the ingredients, substitute something of lessor quality ? Bake at the wrong temp ?
    Many things can be off kilter in the process of following a recipe. In audio, many do not even know what to listen for, let alone choose the quality products to listen to. They don't know how to match gear/ingredients to come up with a good system/cookie.
    That's the value in forums and those with experience making cookies. :) If your satisfied with your cookies, don't get involved with better recipes, it's of no interest to you anyway
    tonyb Posts: 33,072
    Dang it, now I need to go find some chocolate chip cookies.
  • motorhead43026
    edited March 2016
    Deleted, no sense in feeding the trolls.
  • K_M
    K_M Posts: 1,632
    As long as you simply call someone a "Troll" for having a different, equally valid view, there is zero chance of a mature discourse.
    I was not even stating any view, but simply trying to show a bit of composure and respect for how the two differing views see things.
  • motorhead43026
    edited March 2016
    K_M wrote: »
    Hmmmmm, so what makes you think this was directed toward you, that is unless, never mind.
  • K_M
    K_M Posts: 1,632
    edited March 2016
    tonyb wrote: »
    How?
    Easily. Other things factor into how one's minds eye "sees" something.
    But that is common knowledge.
    Test?
    If a Person, can pick product "X" out from product "Z" easily, when not aware of which is which.
    But that is also common knowledge.
    Many times a person does not want their preference or perception challenged.
    Or to find out it is suspect.
