SDA 2Bs still bright
ROHfan
I was going from my Oppo directly to the Parasound HCA-750 and, even after the polyswitch mod, they still sounded bright. I wound up getting a Yaqin CD3 tube buffer and rolled in some Sylvania 6SN7s. The bass got a little deeper and some detail came out but they still sound bright to my ears. Anyone have any ideas of how I can tame the highs?
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
What value resistor did you install in place of the Polyswitch?Home Theater/2 Channel:
dhsspeakerservice.com/ -
westmassguy wrote: »What value resistor did you install in place of the Polyswitch?
.5 ohm.TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
I'd be very interested in some 6SN7 tube opinions, also. Very new to tubes.TV: 65" Samsung QLED 4K
You could increase it to .6-.7 ohmsHome Theater/2 Channel:
RCA VT231 gray glass2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »
Are they a direct replacement?TV: 65" Samsung QLED 4K
It's your source and possibly your cables.Political Correctness'.........defined
President of Club Polk -
Had a issue like that just last week, With a little help from my friends here found 2 Drivers out of phase. Problem solved. Just saying!
I used Mundorff MOX so mine was .47 ohm (closest value to .5) - mine are TL'd now as well but the last thing I'd say is they are bright. In fact, I'd say I finally understand why everyone loves the 2b's so much. I prefer them to my modded 1c's in some ways (but not all ways).
I'd check the easy stuff first, swap some cables, as Jesse suggests, also, I hate to broach the subject but some of your chain has a rep for being brighter. You may find a cable or tube that tames that very nicely if you don't mind experimenting.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Source and then cables. Why would you use the volume control in the Oppo?
Brock, it seems to be a fad these days with a growing number of Oppo owners to remove the pre amp from the chain.Political Correctness'.........defined
Why? A pre-amp is much more than an inexpensively implemented vol control.
I was under the impression that the DAC in the Oppo was of good quality, no?
You know, everything seems to point to the harshness originating in the BDP-103. Even when I stream music from my NAS it's very bright. When I use the Oppo via HDMI to my AVR the sound is not nearly as harsh but I seem to lose detail. So, that said, would I be better served by a dedicated CD player or should I go with a good quality DAC between the 103 and the Yaqin? My speaker cables aren't an issue as they're high quality, although I forget the manufacturer. Got them from a Polkie here. And my interconnects are custom made by me so they must be perfect.
Good quality dac because it also give you some further flexibility."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
What would be the preferred way to get signal from the Oppo to the DAC? Optical output?TV: 65" Samsung QLED 4K
My 105 as a preamp blew. It works ok as a back up pre if needed. I also ran my 93 as a pre when I had it, it was even worse.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
To me optical is the least preferred method.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
Coax is best"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
One of two things should happen here, Bill - you bring those 2Bs to me, or I'll bring my preamp/amp/cables to you.
Theoretically we have identically matched speakers, except yours have totally redone
Xovers. I can say that mine do not sound at all bright or fatiguing, but your ears are what we're talking about so you'd have to decide for yourself.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Maybe the speakers need some break in? The oppos were far from bright. My vr3 modded lsi 15's were like a roller coaster on break in before they smoothed out. I'm talking 200 hours here.2 channel:
Theater:
The speakers are more than broken in. I think Harry is onto something in his post. I may have to haul them over to his place and give a listen with his equipment and my speakers.TV: 65" Samsung QLED 4K
Try his equipment on your speakers. That will tell you where your percieved brightness is coming from better, no?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Coulda sworn that's what I posted above.TV: 65" Samsung QLED 4K
I read it wrong because of the way polr initially posted your speakers his house or his equipment your house. You switched it up with your speakers his house. Derp, sorry. Wouldn't it be easier to move equipment than speakers?Post edited by Nightfall onafterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
I read it wrong because of the way polr initially posted your speakers his house or his equipment your house. You switched it up with your speakers his house. Deep, sorry. Wouldn't it be easier to move equipment than speakers?
Uhh, keep outta this, he isn't exactly around the block from me... LOL
Whatever works though, I offered because I'm anxious to give yours a listen either way.
I think what I'm gonna try this weekend is going from the Oppo's coax out to the coax in of my VSX-1120 and seeing what happens. I'll probably throw the tube buffer into the mix after the preouts on the VSX.TV: 65" Samsung QLED 4K
Bill putting your speakers into a completely different rig, room dynamics, as well as another pair of ears listening should help solve your problem. That is if the solution hasn't already been found. Keep us informed as to what you find!Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Bill have you use your Mapletree preamp with your amp and a source like a CD player to see how that sounds? and or from the Oppo to the Mapletree to the amp?2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
RandyCroissant wrote: »Bill putting your speakers into a completely different rig, room dynamics, as well as another pair of ears listening should help solve your problem. That is if the solution hasn't already been found. Keep us informed as to what you find!
Food for thought, Bill - my 2ch rig is in my finished basement which, because it's connected to the garage, is 100% accessible. So no worries about dealing with stairs OK?
And there's already spots impressed into the carpet that should be just about the right size; placement just doesn't get any easier!So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
I actually sold the Mapletree. Wasn't enough of a good improvement to hold onto it and I got a really sweet offer for it, to boot. However, it definitely wasn't as bright as what I have now.
Harry, I think I'll be in for a week from Saturday.TV: 65" Samsung QLED 4K
