SDA 2Bs still bright
I was going from my Oppo directly to the Parasound HCA-750 and, even after the polyswitch mod, they still sounded bright. I wound up getting a Yaqin CD3 tube buffer and rolled in some Sylvania 6SN7s. The bass got a little deeper and some detail came out but they still sound bright to my ears. Anyone have any ideas of how I can tame the highs?
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • westmassguy
    westmassguy Posts: 6,850
    What value resistor did you install in place of the Polyswitch?
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • ROHfan
    ROHfan Posts: 1,014
    .5 ohm.
  • ROHfan
    ROHfan Posts: 1,014
    I'd be very interested in some 6SN7 tube opinions, also. Very new to tubes.
  • westmassguy
    You could increase it to .6-.7 ohms
    txcoastal1 Posts: 13,519
    ROHfan wrote: »
    RCA VT231 gray glass
  • ROHfan
    ROHfan Posts: 1,014
    txcoastal1 wrote: »
    ROHfan wrote: »
    Are they a direct replacement?
    F1nut Posts: 52,173
    It's your source and possibly your cables.
  • Gunther16
    Gunther16 Posts: 243
    Had a issue like that just last week, With a little help from my friends here found 2 Drivers out of phase. Problem solved. Just saying!
  • MrBuhl
    MrBuhl Posts: 2,419
    I used Mundorff MOX so mine was .47 ohm (closest value to .5) - mine are TL'd now as well but the last thing I'd say is they are bright. In fact, I'd say I finally understand why everyone loves the 2b's so much. I prefer them to my modded 1c's in some ways (but not all ways).
    I'd check the easy stuff first, swap some cables, as Jesse suggests, also, I hate to broach the subject but some of your chain has a rep for being brighter. You may find a cable or tube that tames that very nicely if you don't mind experimenting.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    heiney9 Posts: 25,590
    Source and then cables. Why would you use the volume control in the Oppo?
    F1nut Posts: 52,173
    heiney9 wrote: »
    Brock, it seems to be a fad these days with a growing number of Oppo owners to remove the pre amp from the chain.
    heiney9 wrote: »
    Why? A pre-amp is much more than an inexpensively implemented vol control.
  • ROHfan
    ROHfan Posts: 1,014
    edited March 2016
    heiney9 wrote: »
    I was under the impression that the DAC in the Oppo was of good quality, no?
    You know, everything seems to point to the harshness originating in the BDP-103. Even when I stream music from my NAS it's very bright. When I use the Oppo via HDMI to my AVR the sound is not nearly as harsh but I seem to lose detail. So, that said, would I be better served by a dedicated CD player or should I go with a good quality DAC between the 103 and the Yaqin? My speaker cables aren't an issue as they're high quality, although I forget the manufacturer. Got them from a Polkie here. And my interconnects are custom made by me so they must be perfect. :)
    Good quality dac because it also give you some further flexibility.
  • ROHfan
    ROHfan Posts: 1,014
    heiney9 wrote: »
    What would be the preferred way to get signal from the Oppo to the DAC? Optical output?
  • mikeyb128
    mikeyb128 Posts: 2,885
    My 105 as a preamp blew. It works ok as a back up pre if needed. I also ran my 93 as a pre when I had it, it was even worse.
    2 channel:
    Theater:
  • motorhead43026
    motorhead43026 Posts: 4,051
    To me optical is the least preferred method.
    Coax is best
  • polrbehr
    polrbehr Posts: 2,861
    One of two things should happen here, Bill - you bring those 2Bs to me, or I'll bring my preamp/amp/cables to you.
    Theoretically we have identically matched speakers, except yours have totally redone
    Xovers. I can say that mine do not sound at all bright or fatiguing, but your ears are what we're talking about so you'd have to decide for yourself.
  • mikeyb128
    Maybe the speakers need some break in? The oppos were far from bright. My vr3 modded lsi 15's were like a roller coaster on break in before they smoothed out. I'm talking 200 hours here.
    2 channel:
    Theater:
  • ROHfan
    ROHfan Posts: 1,014
    mikeyb128 wrote: »
    The speakers are more than broken in. I think Harry is onto something in his post. I may have to haul them over to his place and give a listen with his equipment and my speakers.
  • Nightfall
    Nightfall Posts: 10,083
    Try his equipment on your speakers. That will tell you where your percieved brightness is coming from better, no?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • ROHfan
    ROHfan Posts: 1,014
    Nightfall wrote: »
    Coulda sworn that's what I posted above.
  • Nightfall
    edited March 2016
    I read it wrong because of the way polr initially posted your speakers his house or his equipment your house. You switched it up with your speakers his house. Derp, sorry. Wouldn't it be easier to move equipment than speakers?
    Post edited by Nightfall on
    afterburnt wrote: »
  • polrbehr
    Nightfall wrote: »
    I read it wrong because of the way polr initially posted your speakers his house or his equipment your house. You switched it up with your speakers his house. Deep, sorry. Wouldn't it be easier to move equipment than speakers?
    Uhh, keep outta this, he isn't exactly around the block from me... LOL B)
    Whatever works though, I offered because I'm anxious to give yours a listen either way.
  • ROHfan
    ROHfan Posts: 1,014
    I think what I'm gonna try this weekend is going from the Oppo's coax out to the coax in of my VSX-1120 and seeing what happens. I'll probably throw the tube buffer into the mix after the preouts on the VSX.
  • RandyCroissant
    Bill putting your speakers into a completely different rig, room dynamics, as well as another pair of ears listening should help solve your problem. That is if the solution hasn't already been found. Keep us informed as to what you find!
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • voltz
    voltz Posts: 5,384
    Bill have you use your Mapletree preamp with your amp and a source like a CD player to see how that sounds? and or from the Oppo to the Mapletree to the amp?
  • polrbehr
    Food for thought, Bill - my 2ch rig is in my finished basement which, because it's connected to the garage, is 100% accessible. So no worries about dealing with stairs OK?
    And there's already spots impressed into the carpet that should be just about the right size; placement just doesn't get any easier!
  • ROHfan
    ROHfan Posts: 1,014
    voltz wrote: »
    I actually sold the Mapletree. Wasn't enough of a good improvement to hold onto it and I got a really sweet offer for it, to boot. However, it definitely wasn't as bright as what I have now.
    Harry, I think I'll be in for a week from Saturday.
