Vinyl Guys... Dust Cover Up/Off or Down/On?
Mikey081057
Is there a correct answer? Is there an audible difference? I've alway been an UPPER... I honestly don't know the reason... (BTW while you are playing a record)
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
This is a public poll: others will see what you voted for.
I have a custom dustcover that isn't attached to my tt otherwise it would stay up when playing a record
Up/Offmotorstereo wrote: »I have a custom dustcover that isn't attached to my tt otherwise it would stay up when playing a record
So you would vote off?
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Nope mine stays on
Up/OffWhen I had my turntable, the cover was off. It can pick up sound waves, and transfer the vibrations to the base.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Down/OnI have used mine both ways and can't tell a difference, although I have heard people say having the cover down makes the cover act like a bell. I figure sound waves will affect the needle one way or another, and having the cover down prevents dust from getting on the LP while it is playing. So, most of the time it is cover down for me.
Up/Offon and UP! thought I read somewhere not to run it with the lid down, but I know if I closed it once it started I'd skip my record when I re-opened it
It's not an airplane wing, you need the soft touch Darryl
Up/OffMost covers are acrylic of some type, and have a resonance frequency. That could also be transferred to the base.Home Theater/2 Channel:
Up/Offwestmassguy wrote: »Most covers are acrylic of some type, and have a resonance frequency. That could also be transferred to the base.
Maybe i should dynamat it
Up/OffMikey081057 wrote: »westmassguy wrote: »Most covers are acrylic of some type, and have a resonance frequency. That could also be transferred to the base.
LOLHome Theater/2 Channel:
Off for me.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Up/OffOffafterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Always offOh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Down/OnI live in a dust bowl. Down with the stress ball.
I have never noticed a difference, so I leave mine down.
Is there a right or wrong? Not a consistent answer. I test each table just like I test feedback in a live sound situation since the cartridge is really just a microphone. I pump the volume to see if there is any feedback present. Tap the lid, raise it, if it causes problems raised or lowered that don't exist when it is off, it comes off during play. I have had both scenarios happen depending on the gear and setup location with proximity to speakers/subs.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
ken brydson wrote: »
Good One LOL -
Up/OffUp
Down/OnUntil I got my current table, I too was an upper. With this table though, I like it down. It may be purely aesthetic.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
It's there just for dust! Has no value to the operation of TT when playing so up or even better off completely. On when not in use to keep dust off of TT and mechanisms.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Up/OffAlways Off..
Down/OnI voted down because I have two large cats - Elvis and Bigboy."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Didn't your wife always tell you to put the lid down2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Up/OffBlueBirdMusic wrote: »I voted down because I have two large cats - Elvis and Bigboy.
Hopefully Elvis keeps his jelly donuts away for your TTMy New Year's resolution is 3840 × 2160
Down/Up - depends on which table, but always on.
I hear no difference on the MMF 5SE with the cover down during play or tilted up. It does not lend itself to complete removal.
On the Bluenote Bellavista, I leave it tilted up due to the height of my "Joe's - The Clamp". It also does not lend itself to complete removal. -
Up/Offwestmassguy wrote: »When I had my turntable, the cover was off. It can pick up sound waves, and transfer the vibrations to the base.
exactamundo !!!!!!
Because I am The Pumpkinking
Up/OffI have a custom cover I made and it cannot be on when playing a record. I've heard that the hinged ones will suck in dust as you put it down when playing a record...or is it when you pull it up!
Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Up/OffBlueMDPicker wrote: »Down/Up - depends on which table, but always on.
Although I don't have my turntable set up at the moment, this is the same reason I keep mine up. I have Joe's clamp as well and love it.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Up/OffI leave mine up I just like watching the strobe and the record spin. I know but its the simple things that make me happy, hey you guys let me join the forum now your stuck with me..
