Vinyl Guys... Dust Cover Up/Off or Down/On?
Mikey081057
Mikey081057 Posts: 7,127
edited February 2016 in 2 Channel Audio
Is there a correct answer? Is there an audible difference? I've alway been an UPPER... I honestly don't know the reason... (BTW while you are playing a record)
Garage | Polk Monitor 5B's
Sign in to vote!
This is a public poll: others will see what you voted for.
  • motorstereo
    motorstereo Posts: 2,392
    I have a custom dustcover that isn't attached to my tt otherwise it would stay up when playing a record
  • Mikey081057
    Up/Off
    So you would vote off?
  • motorstereo
    Nope mine stays on
  • westmassguy
    westmassguy Posts: 6,850
    Up/Off
    When I had my turntable, the cover was off. It can pick up sound waves, and transfer the vibrations to the base.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Emlyn
    Emlyn Posts: 4,868
    Down/On
    I have used mine both ways and can't tell a difference, although I have heard people say having the cover down makes the cover act like a bell. I figure sound waves will affect the needle one way or another, and having the cover down prevents dust from getting on the LP while it is playing. So, most of the time it is cover down for me.
  • voltz
    voltz Posts: 5,384
    Up/Off
    on and UP! thought I read somewhere not to run it with the lid down, but I know if I closed it once it started I'd skip my record when I re-opened it :p
  • westmassguy
    Up/Off
    voltz wrote: »
    It's not an airplane wing, you need the soft touch Darryl :)
  • westmassguy
    Up/Off
    Most covers are acrylic of some type, and have a resonance frequency. That could also be transferred to the base.
  • Mikey081057
    Up/Off
    Maybe i should dynamat it :#
  • westmassguy
    Up/Off
    LOL
  • Nightfall
    Nightfall Posts: 10,083
    Up/Off
    Off
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Always off
  • afterburnt
    afterburnt Posts: 7,892
    Down/On
    I live in a dust bowl. Down with the stress ball.
  • I have never noticed a difference, so I leave mine down.
  • ken brydson
    ken brydson Posts: 9,058
    zappafan2 wrote: »
    She was disappointed...
  • Is there a right or wrong? Not a consistent answer. I test each table just like I test feedback in a live sound situation since the cartridge is really just a microphone. I pump the volume to see if there is any feedback present. Tap the lid, raise it, if it causes problems raised or lowered that don't exist when it is off, it comes off during play. I have had both scenarios happen depending on the gear and setup location with proximity to speakers/subs.
  • zappafan2 wrote: »
    Good One LOL
  • xsmi
    xsmi Posts: 1,804
    Down/On
    Until I got my current table, I too was an upper. With this table though, I like it down. It may be purely aesthetic.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • soundfreak1
    soundfreak1 Posts: 3,414
    It's there just for dust! Has no value to the operation of TT when playing so up or even better off completely. On when not in use to keep dust off of TT and mechanisms.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    Toolfan66 Posts: 18,290
    Up/Off
    Always Off..
  • Down/On
    I voted down because I have two large cats - Elvis and Bigboy.
    Harry / Marietta GA
    txcoastal1 Posts: 13,519
    Didn't your wife always tell you to put the lid down
  • Mikey081057
    Up/Off
    Hopefully Elvis keeps his jelly donuts away for your TT
  • Down/Up - depends on which table, but always on.
    I hear no difference on the MMF 5SE with the cover down during play or tilted up. It does not lend itself to complete removal.
    On the Bluenote Bellavista, I leave it tilted up due to the height of my "Joe's - The Clamp". It also does not lend itself to complete removal.
  • pumpkinman
    pumpkinman Posts: 10,399
    Up/Off
    exactamundo !!!!!!
    Because I am The Pumpkinking
  • gce
    gce Posts: 2,158
    Up/Off
    I have a custom cover I made and it cannot be on when playing a record. I've heard that the hinged ones will suck in dust as you put it down when playing a record...or is it when you pull it up! :/
    Anaheim Hills CA,
  • vmaxer
    vmaxer Posts: 5,121
    Up/Off
    Although I don't have my turntable set up at the moment, this is the same reason I keep mine up. I have Joe's clamp as well and love it.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Up/Off
    I leave mine up I just like watching the strobe and the record spin. I know but its the simple things that make me happy, hey you guys let me join the forum now your stuck with me..
