This joint needs some more vintage hifi
1222325272862
    Very nice. I have a CR 800, which I like better than the succeeding series. I find the 800 gives you an excellent feeling for the vintage Yammie sound, which I like but find a little too neutral. I prefer the warmth of HK units. The Yammie strength is in more high frequency detail.
    mhardy6647 Posts: 35,170
    should come in handy; I guess I ought to pick up an organ donor or two as/if the opportunity presents itself...
  • boston1450
    boston1450 Posts: 7,758
    cnh wrote: »
    i agree. Those smaller HK receivers back in the day were built like tanks & sound wonderful. Very conservative
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    edited June 2015
    Randy-Maine
    by David WMG
  • leftwinger57
    leftwinger57 Posts: 2,917
    Possibly early to mid 80s. This is a rack face Adcom GFA 555.Still has the East Brunswick N.J. address. I got this from Audio Classics for $300 even w/ shipping thrown in . It's on my 5th year now w/ no problems and it's really clean on the inside.fwp9g0dlo25a.jpg
  • boston1450
    Nice Lew. Adcom sounds very good on SDA's too :smile:
    Randy-Maine
    by David WMG
  • oldrocker
    oldrocker Posts: 2,590
    A few of the things that hopped in my trunk while out today.
    Nice! Seems like you have a very "flirtatious" trunk!
  • oldrocker
    Right place right time I guess. I also got 3 of these bose speakers which I have NO clue on nor a use for and will probably get chastised for even posting pics of them :(88dwkj7eubms.jpg
    I got some peavey stuff which I'm not into by any means but the guy wanted it all gone.
    edited June 2015
    The Hafler could've jumped into my trunk -- it's a pretty nice amplifier.
    Not all Peavey stuff was/is junk; just most of it :-P
    I even own one Peavey amplifier; it is sort of a poor persons Manley Stingray (i.e., push-pull parallel EL84 stereo amplifier)! :- )
    16420215214_d48f00bb39_b.jpgP1020121 by Mark Hardy, on Flickr
    16856404899_0008c19c20_b.jpgPeaveyClassic5050topless by Mark Hardy, on Flickr
  • oldrocker
    This peavey stuff I got is terribly sad, a power booster amp thingey and a set of old speakers, t-300's I think. They do have dual paper cone drivers which are working, tweets are mostly dead.
    Working on a deal to trade the Hafler for an Akai amp to go with my 280D SS RTR.
    I have a lead on a crown IC150 preamp for cheap that originally came with the 150A amps.
    Not sure if I want to pursue it.
  • leftwinger57
    I used to install Bose speakers like that if they are the true hi-hat style and not car speakers. To install on prewires Bose made a cutout template that had a locking spring assembly that was also installed. When the house was nearing close you would grab on to the springs that fit into their locking mates on the speakers and the tension of these springs would just snap up the speakers just like hi-hat lights. For existing houses Bose made basically the same template only in 2 halves so after your hole is cut you could slide the ' rat trap' and wire the speaker and lock it into place. These went w/ 3 room amps that looked like car amplifiers w/ an input for a sub and volume controls and were meant for basements or closets and not to be seen.
  • oldrocker
    Thanks, they are the in-ceiling type and do work.
    Back in a box they go..
  • leftwinger57
    For serious listening not a chance. For background music there just fine. People went crazy nuts over those things during the building boom of the 90's and spent close to 10k to do a full house w/ multiple amps, subs. volume controls and input plates. Then there was the Lifestyle surround system for the family rooms at $5k.
  • pumpkinman
    pumpkinman Posts: 10,281
    If all goes well tomorrow I'll be bringing home a pair of Boston Acoustics a400's in need of TLC
    Because I am The Pumpkinking
    pumpkinman wrote: »
    You should enjoy those! Give them the power they crave. Nice stuff!
  • pumpkinman
    I had to drive to the Jersey shore but what the hell. If it's free it's for me.
    Boston Acoustics A-400
    Specs:
    8" woofers x 2
    6.5" midrange
    1" tweeter
    Frequency Response: 36Hz-25kHz
    Efficiency: 90dB
    Impedance: 4 Ohm
    Dimensions: 41"(H) x 21"(W) x 8"(D)
  • oldrocker
    edited July 2015
    Latest pickup, KEF CODA III. Two way 8" bookshelf, ridiculously cheap, the guy threw in a, supposedly, defunct HK 340 for free!
    Surprisingly detailed and airy top end, tight bass, not very deep but competent for their size-only 18" high!
    Now I have to source a missing BALANCE KNOB for an HK 340 and hit it with deOxit. The receiver seems to play through H-phones fine (well, with the regular drop outs associated with dirty pots, that is), but needs cleaning. If I can find a replacement knob I may just return it to the guy I got it from! He seems to think this unit is dead? I still have to test it on speakers. But I suspect it will work if the H-phone section is working? We have one for sale on this site: NICE warm full (20 watt per side) sound! Someone should buy it!
    http://forum.polkaudio.com/discussion/167197/70s-harman-kardon-receiver-available#latest
    Any ideas as to what I can use for a knob. Not looking to source one from ebay. Anything that will work and I can spray paint silver would be fine. Not that concerned with cosmetics, if I had a 3D printer I could just measure a knob and reproduce one of similar size. But I don't.
    Thanks!
    Nice loudspeakers are those KEFs.
  • Nightfall
    Nightfall Posts: 10,083
    Talk like Yoda, you do. ...or was that supposed to end in a question mark?
    afterburnt wrote: »
    Village Idiot of Club Polk
    No. A statement it was.
  • soundfreak1
    soundfreak1 Posts: 3,414
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • soundfreak1
    Oh ya they are AR 4X'S
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • EDUBAG
    EDUBAG Posts: 403
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Nice. Mine are doing duty as rear surrounds right now...
  • [Deleted User]
    saved from the scrap heap today;
    Specifications
    Power output: 100 watts per channel into 8Ω (stereo)
    Frequency response: 10Hz to 100kHz
    Total harmonic distortion: 0.01%
    Damping factor: 40
    Input sensitivity: 0.25mV (MC), 2.5mV (MM), 150mV (line)
    Signal to noise ratio: 68dB (MC), 86dB (MM), 105dB (line)
    Speaker load impedance: 4Ω to 16Ω
    Year: 1984
    It has a subsonic filter! :D
    A Nikko I've never seen before...
  • [Deleted User]
    edited July 2015
    sounds harsh to these old ears w/ the RT-7s hooked up to them.
    I haven't cleaned anything yet... o.k. at 3-4 on the volume dial.
    It has this mono...stereo...wide pot?!
    It can do MM/MC. It seems like the one's I recall except bars instead
    of VU meters. It's also not much of a looker. Could be headed for
    the garage. :)
  • soundfreak1
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
