Bi-Wiring, what exactly is it doing?
The Polk Quick Start Guide that came with my 703's, 705's & 706 states "Bi-Wiring can provide noticeable improvements in the overall transparency of your loudspeakers. Remove the jumpers, run 2 sets speaker wire from same terminals on the the amp to the low & high frequency drivers(abbrev)."
Is there less 'power' feeding the speakers, because the jumpers are gone the speakers produce better sound? Is that what transparency means? Thank you for any info, seems like some music tracks sound better, difficult to nail down exactly what it is.
«1345678
  • Hermitism
    Hermitism Posts: 4,323
    edited April 2015
    A lot of the people here believe that the improvements you hear with bi-wiring is due to the elimination of the jumper, which in most cases is of lesser quality than the speaker cables you are using.
  • Hermitism
    I use biwire cables. But in my case, I was having custom cables made and it was cheaper to use biwire cables than use single wire and then have matching jumpers made from the same wire. For me it was all about saving $$.
  • GlennDog
    GlennDog Posts: 3,150
    I recently commissioned doug of DouglasConnection to make jumpers for me. They appear to be of very good quality & Doug is a very conscientious cable maker.
    Mine were approx 100 smackers . . .a far cry from MITs 700 jumpers
    But like everything, you get what you pay for ...
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Upstatemax
    Upstatemax Posts: 2,735
    On my old LSi 9's and RTi A7's is was all about getting rid of the stock jumpers.
    I found better separation and an overall more cohesive sound stage.
  • Hermitism
    Doug is who made mine also. Super nice guy!
  • [Deleted User]
    [Deleted User] Posts: 10,716
    I can tell you that when I had lower quality regular speaker cable hooked
    up to my 703's they had this phat bass sound. When I was lucky enough
    to go Audioquest bi-wire it eliminated that issue. Surprisingly to me there
    was a break in period when I switched. I had been running the the single cable
    method for 2 months.
    Here is what AQ thinks
    http://www.audioquest.com/resource_tools/LearningMods/UndrstndgBiWr.pdf
    mhardy6647 Posts: 34,940
    edited April 2015
    There are quasi-technical explanations on-line, but I've gotta say that the physics eludes me. In all fairness, I am a biochemist (dammit, Jim!), not a physicist... but still...
    That said, it seems to me to be at worst a benign thing to do (i.e., biwiring should do no harm to any components so interconnected).
    tonyb Posts: 33,069
    Has nothing to do with power. More so a better signal transfer. Same thing can be accomplished by replacing those stock brass jumper plates that came with your speakers. Some use different wire jumpers, home made ones, or just use bi-wired cables. Ideally you want to use the same wire as your speaker cable, hence the appeal of bi-wired.
  • specd_out
    specd_out Posts: 505
    I have to agree with the jumper removal being the only really improvement. I never really noticed much of a difference. I have gotten more improvement from spiking the speakers and proper placement. I did it for the looks mainly. I love the way 4 wires run to the speaker look vs only two to the top or bottom
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • pumpkinman
    pumpkinman Posts: 10,212
    I've done a number of combo's bi-wire w/ 2 runs, with jumpers made from the same wire and jumpers with a larger gauge and so on. I personally could never hear a diff. I never use the factory jumpers and the stock ones that came with my 3.1 TL's were laughable.
    Because I am The Pumpkinking
  • ukcolin99
    ukcolin99 Posts: 286
    Thanks all, mixed bag of benefits although gotta believe Polk would not recommend bi-wire if it didn't help. For the record below is pic of the jumpers that came with my recent Polk purchases.
    F1nut Posts: 51,709
    Your crossover has a separate high and low circuit. The jumpers bridge those circuits. Bi-wiring replaces the jumpers as the bridge and depending on the jumpers may effectively increase the wire gauge. You can do the same by replacing your stock jumpers with ones of higher quality, which would generally also mean an increase in the wire gauge.
  • PolkieMan
    PolkieMan Posts: 2,446
    I would think rewiring the inside of the speaker with the highest quality wire would make more of an improvement than the bi-wire of course do it complete and also change the jumper wires too. I think Polk does it because other manufactures do it also and your trying to sell product so you best have what the other guy has too because that consumer is going to think wow this is High End.
  • Nightfall
    Nightfall Posts: 10,084
    edited May 2015
    Isn't this a two way street? The argument that if you think something is going to change the sound it will for you. How about if you're already biased that changing a certain item won't change the sound then it won't for you. So who's right? How about both?
    xcapri79 wrote: »
    I and others have yet to see any laboratory measurements
    Not everything can be measured, or we haven't found a way yet, as far as sound quality. Can sound stage and imaging be measured? No. By your logic every setup should have the same sound stage and imaging capabilities, no?
    The instruments that measure sound CANNOT be compared to what we hear with our ears and brain. They're not even remotely complex enough.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 51,709
    The following link is very beneficial to read if you are the gullible type and put your trust in a hypocrite.
    Fixed it for ya.
    SCompRacer Posts: 9,090
    edited May 2015
    I bi-wire cause I had the wire cause I horizontally bi-amped with an active crossover with a different pair of speakers and sold the speakers and amps but not the wire. If I could get matching terminations, I'd un-internal bi-wire my internal bi-wire pair and sell the others, but Harmonic Technology changed hands and don't supply matching terminations which would devalue the cables if I sold them.
    tonyb Posts: 33,069
    ZLTFUL wrote: »
    Actually, reality is exactly one's perception.
    Everyone's brains are built differently. Look at your ears and then compare them with a friend or spouse. There are clear differences in ears.
    Everyone perceives things differently from everyone else.
    How else do you explain why some people like classical music while other prefer heavy metal? What sounds pleasant to one person may sound grating or annoying to another.
    It is *all* about perception and that makes perception reality.
    Your perceptions may differ from mine but it doesn't make them any more or less *real* than mine.
    Couldn't have said it better myself, good post. Adding to that.....it is the differences in perception, aka reality, that gives us such a variety in gear to pick from too.
    Don't confuse preferences with perception either, they may have some similarities but are not the same.
    I'd still like to know what scientific measurement, exactly, will tell me how a cables soundstage presentation will sound in height,width, depth. Which number on these so called scientific measurements tells me about separation of instruments, placement on a stage, air around notes. If they could indeed do that, they would rate them in each category....but they can't.
    Why ? Perception....our own reality is different between us all. A cable is an "interconnect" between 2 pieces of gear. Depending on a variety of things in materials used, design.....it will react differently to a variety of gear hooked up to it. Not a hard concept to follow.
    After all, the differences in anything, even non-audio related, comes down to quality of parts used and design, build quality. That's what separates a Ford from a Lexus, a Pass amp from an Emotiva, and an MIT cable from Monoprice. Which also btw, dictates that quality costs more. Also not a hard concept to follow.
    When we look at gear, we drool over the latest and greatest tech, dac chip, tube, build quality, volume controls, software, etc.....all things that may change your reality. Why do we fail to present the same criteria for ourselves when it comes to cables ? Because many do not look at cables as "gear". Simply a means to an end.....connecting 2 pieces of gear to get sound.
    Everything in your chain alters the sound to some degree, cables included.
    tonyb Posts: 33,069
    Then I respectfully disagree with everything you just said. Aside from the fact that marketing claims are just that, marketing....everything else is simply a testimony to a lack of experience. No offense meant Kevin.
  • erniejade
    erniejade Posts: 6,321
    edited May 2015
    "kevintomb wrote: »
    To answer the first bolded part.
    A cable has NO soundstage at all. Nor separation of instruments, placement etc. '
    It conducts an alternating current signal.
    It will either conduct the signal fully intact or degrade it some minimal amount.
    The rest is sales talk.
    All facets of alternating current can be fully measured, at ALL levels down to below human hearing.
    Sorry it really is that simple.
    Not everything alters the sound. That is a myth also.
    SOME and even many things alter the sound true, but not truly everything.
    The guys that design all this stuff we listen to, truly know what matters or does not, not the marketing claims.
    I usually do not jump in on this kind of stuff but,........
    Agree but the way it degrades sound will effect everything you just said so yes cables do matter. Some play nicely with certain equipment and some do not.
    That is correct if your system cannot resolve or tell the difference. This statement depends on your system. Some of our systems when we move the speaker an inch in either direction we can hear a difference. If we change a cable, we can hear a difference, if we use the same cd on a different cd player or same cd player with a different dac, we can hear a difference. If you can't, your system doesnt reasolve enough.
  • vc69
    vc69 Posts: 2,500
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
    F1nut Posts: 51,709
    ZLTFUL wrote: »
    Fastest way to lose all credibility on the internet...cite Consumerist or Audioholics posts in your argument.
    Like he had any to begin with.
  • BlueFox
    BlueFox Posts: 15,251
    An interesting point is that while xcapri79 lists gear in his sig, there is no mention of cables, power cords, and power conditioners. From that, one can infer he simply throws money at gear thinking that is all it takes to improve sound quality. While gear obviously has its place, my philosophy is to extract the most audio possible from the gear by improving both cables and power, and then move onto new gear. Build a good foundation, and then your gear, both current and new, will work at its best.
  • ukcolin99
    edited May 2015
    And the beat goes on. Some wag pointed out that not everyone is familiar with the font size on the back of the Quick Start Guide that Polk includes with every new speaker. And because my camera is working right now, here you go. Dime & quarter. P.S. I am going to try & jam the bi'ed-wires into banana plugs instead of wrapped bare around amp connectors.
    F1nut Posts: 51,709
    An excellent philosophy.
    F1nut Posts: 51,709
    I currently use various brands such as Acoustic Research, Emotiva, Pangea, Monoprice, Monster, etc.
    Generally, it's best to use the same brand as they are designed to work together.
    Interconnect, speaker cables and power cords etc. are the least costly elements in the chain, so I don't list them.
    I cannot understand why some folks think that cables are somehow not an integral part of the rig and skimp on them.
    For power conditioners, I use various models of the Monster units and haven't had an electronic equipment failure in my lighting and outage prone area for several years.
    Those are not known for their fidelity.
    F1nut Posts: 51,709
    At first I had very little experience, then progressed into a lot and bought into all the cables and stuff to a moderate amount, then finally with a lot more experience, moved past the hype, fell back on my electronics and audio friends experiences in designing etc, and realized, it was a lot of hype and sales talk mostly.
    I'm just the opposite. The more I got into this hobby, the more I realized the importance of high quality cable.
    When I found out that cables are HUGE profit makers, I asked a lot more stuff. I found out, too much maybe.
    Sometimes TOO MUCH experience and answers can move one back away from something they did love and believe in.
    Let's say for a minute that SOME cables have a huge profit margin because not all do. So flipping what, if they take your rig to the next level, who cares.
    tonyb Posts: 33,069
    Yes it is, and one I also subscribe too. Too many times we wind up switching out gear because it doesn't tickle our fancy when in reality a simple cable change can bring all that synergy together.
    tonyb Posts: 33,069
    If you really want to learn the essentials, try some different cables for yourself and all you need to know will become apparent.
  • nspindel
    nspindel Posts: 5,343
    How'd I know this thread would turn into an argument about cables?
  • nspindel
    Instead of having this argument, how about we just post links to the other 658 threads with the same discussion?
