Rogue M-180's on the way.
tratliff
After careful consideration I have decided to purchase a pair of Rouge M-180's. This will be quite a change as I have not yet ventured into tubes.
I will have my A21 for the next few weeks and will be performing A/B comparisons as I break them in. So be on the lookout for a SS vs. Tube shootout.
Something continues to pull me back into the rabbit hole. Every time I make it to the top something grabs hold and pulls me back down.
you, once you go......ah, tubes you can't go back
Puritan PSM156 -
Marvin, once I get setup you will have to stop by for a listen.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
i also have some 12au7's that i had up for sale you can try.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I'm sure testing various tubes will be on the shortlist of to-do's.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
Looking forward to your comparisons, I would love to hear both of these options first hand!
Congrats... I love Rogue gear.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Congrats!
Since these are used (I bought my M180s used, too and bias was all over the place) I recommend checking the bias after the first hour, then again in 5 hours & then about every 10 hours of listening to make sure the output tube are solid.
I'm sure the Focus SEs will sound fan-frickin-tastic!
G
ps Marvins right, you'll wanna roll some input and driver tubes, too!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I doubt you'll be disappointed.
Did you grab the pair from Matt out at Echo?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
No I got them from Josh at The Music Room.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
One upgrade begets another my friend....congrats. Sweet amps for sure. Start reading up on user reviews to see what tubes are floating their boats. Buy some now, keep extra's on hand. Looking forward to your review.HT SYSTEM-
lsi 9's -
Congrats man.. I'd love to hear them one dayMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Dang FedEx Freight. I have been tracking the shipment and they have it at the local facility.
The plan all along was for me to pick it up at the FedEx loading doc. But they will not release it today unless an additional $105 are paid. I understand that it was not sent as priority and was originally scheduled for tomorrow but they transported it and will hold it until tomorrow unless I pay the difference for priority shipping. Seems like a bad business model to me but rules are rules. At least thats what the dispatcher told me.
I guess as long as it is ok when I pick it up I can wait another day. I don't want a PFB shipping mishap.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources. -
"shipped PFB" is a bad thing!
Is there anything much worse than waiting for new toys and it's juuuuust out of reach?
I’M OFFENDED!!!! -
Congrats! I found using the xlr connection was better than rca on the m180
Thanks for the feedback. That kinda stinks since I just got new RCA's yesterday but I also have some XLR's I have been using. I will try both.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
When using rca, I had to use the ground lift switch to lower the ground loop hum
I always get a ground loop hooking up the larger tube mono's with rca in my listening room.
I don't get ground loop hum with more expensive tube amp like Mcintosh or Ayon
I got ground loop hum from my Plinius SA102 before. But it has a little switch and wallah, ground loop hum gone.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
From my experience it is real dependent on the installation, location/house, electrical circuit and equipment. But I don't have any experience with larger tube amps only SS. Based on what everyone is saying tubes are more prone to picking one up.
I'll just install them as planned and start working backwards if needed.
Thanks for the advice everyone.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources. -
how does that song go? party all the time, party all the time or something like that.
todd, did you ever try pulling the speakers out into the room some more to see how they sound?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Nope, everything is apart at this point. Will do that when I get everything back together.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
the one thing i hate about the rogue amps is that they hide the tubes. watching that glow in the dark is part of the fun.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I think I will still be able to see it slightly without being front and center.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
Well. I picked them up Friday night and spent Saturday rebuilding the setup to accommodate them. I had to rebuild all 3 of my racks. Still waiting on one set of pillars. Had to move the TV up about 3 inches.
I also received the new interconnects from Doug last week. Everything is connected and sounds really good. Not sure how to compare to the A21 yet. It is different. The mids and highs are liquid smooth. The bass is very impactful but not sure at the same level as it was.
Overall I'm pretty impressed. I have to give it some time to settle in.
the bass will be different leaning towards the ss amp but put some acoustic music on and then compare.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Yep, it's tough for a tube amp to equal a SS in bass.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
I dunno Skip, speaking for myself.....reduced bass on big speakers that do bass well isn't an afterthought for me.....it's one of the first thoughts.
I know exactly where Todd is coming from. Maybe some tube rolling is in need here....maybe not. If you want some of that tube tone and flesh with power to grab that lower bass by the balls and squeeze.....McCormack DNA 500.....Bat VK500-600.
Trust me on that, haven't steered anyone wrong yet.
Still, I'd give everything some more time to settle in, roll some tubes, before making final judgments. Your cabling is also going to play a bigger part in all this.HT SYSTEM-
lsi 9's -
I wouldn't say the bass is a problem. It is just different and will take time to get use to.
I am going to give the new amps sometime to settle down and for me to get use to them. Once I get everything figured out I may try both the A21 and the M-180's. A21 on bass, M-180's on mids/highs.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
