A nice upgrade... hopefully...
Interesting space. Is that a hallway/entryway or a sitting room? Looks a little like condo architecture to me? Which is fine. My sister used to have something like that and I gave her my wife's old RACK system to put in there because she didn't have any music system at the time and I'd moved to an early '90s Kenwood Prologic receiver (TOTL 35lb unit) and the JBLs. (still around here somewhere, and a possible "garage receiver" Karma in the near future?).
Very clean look! I see that listening chair creeping forward!
Enjoy!
Enjoy!
cnh
Yes looks much cleaner than when the whole wall was lined with speakers.
The black pair on the stairs above the 3A's are SVA1800 as a temporary holding place.
This is a house and a nicely designed one except the location of the door to basement that I hate in the other family room because it doesn't let me put couch all the way back to the wall because of the door.
Here is the front of house from Google maps.
Front door (the one next to small white curtain) opens to the hallway with stairs seen on the left in the image below.
Right room from the front entrance is a long room that has both dining and living areas (where the speakers are now).
On the left of front hallway through the opening, there is family room (my HT room), bathroom and directly on the opposite of stairs is kitchen. You can see kitchen area and sliding door of family room on the right through the opening from dining area.
There is basement but I want main system here as I don't want to spend too much time in the basement.
Basement has 2nd system ready with 3 pairs of speakers so that's enough when I go there.
The right speaker is moved little more to the right since I took this picture.
Sound anchor of that speaker is next to the arch so they are even further apart now.
You may have noticed unfinished steps on the hallway.
Flooring guy had issues with his car and after that, he is in the hospital with kidney stones problem.
I think next time, I'll hire someone younger with newer car.
Post edited by Mystery on
I don't like their current placement honestly. Have you thought about throwing the rig in the corner and putting a bass trap in the actual corner? If that's not an option, I think you'd be better off flipping it 180 degrees. Sitting at the base of the stairs will eliminate reflection points and probably give you a more balance sound due to the solid wall being behind both speakers. I'd suspect the left side of the current setup to be a tad thinner than the right side?
You mean moving the left speaker all the way to the left wall like this below?
I can try that but it'll block some entry way to the room from front hall.
Or go back to the original opposite wall?
By corner I mean putting the entire rig centered on the corner wall opposite the stairs and dining room. It seems that would give you the most symmetric setup in the room, but you might have some trade offs doing it like that. One thing I'd expect would be a lot of standing waves in the actual corner since both speakers would essentially be firing into it.
Opposite of dining room is the window pocket.
Problem is left speaker will be against the wall.
If I remove the couch and put both speakers within the pocket, both will have exact same corners but they'll be too close and I think will sound boomy due to the closed areas on all three sides.
My initial setup with all my speakers was on the long wall opposite to the stairs and that setup is great but it uses a lot of area in that room and the whole room looks narrow.
That's why trying a different setup but looks like I'm pretty much back to where I started.
I don't want to go back to this.
or this:
Mystery, it seems you were right and the review is for the 2ce from
Jan 07. I did hear the 3As @Audio Connection and was impressed.
Lest we forget my mini herd and 2Bs.
http://www.stereophile.com/floorloudspeakers/107vandy/2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
I just crapped my amplifier.
I put the 'Welcome to Atlanta' by Ludacris and cranked the volume really high.
Everything was shaking and still sounded great until after a minute or so amp went wheezzzzzzzz whining and stopped outputting music except loud hum.
Quickly turned the amp off hoping nothing else got damaged.
Turned the volume down and turned amp back on.
Everything is working.
Looks like 3A's pushed it to it's limits.
I also noticed the jumper is thick/stiff wire.
I'll need to make bi-wire with what I have immediately.
Was that the Rotel? What ohms and power rating are the Vandersteens?
Yes, the Rotel.
It's playing fine now but now I'm afraid to crank it now.
May be time to bring in the Crown XLS1500.
Vandersteens are 6 ohms nominal 4 ohms minimum.
Recommended Amplification: 100 to 200 watts per channel into 8 ohms, the amplifier must be stable into a 4 ohm load.
I had Rotel with Boston A400's that are 4 ohms and never shut down.
Looks like Vandersteens dip a lot lower at high volume with bass heavy tracks.
That track by Ludacris has a lot of bass.
I have had my Rotel pushing some real difficult 4 ohm loads Loudly and other than becoming a space heater (but it does that all the time) it never shut down. You might have a potential problem you might want to look into before you go cranking them again. I want to say that Rotel built this for dips to about 2 1/2 ohms but have to double check.
It's late tonight to crank up again but I made bi-wires from a 50 ft spool of 16 awg copper wire.
I was afraid to hook them up in case somehow I messed up the +ve and -ve in the bi-wire so I tested with a small speaker first and once that worked, hooked up the 3A's.
Old jumpers had tin type ring connectors so bare wire is better.
Edit: Listened to few tracks and I think they are cleaner and more open vocals with better instrument separation but that could be my mind playing games.
I'm not jumping terminals again just to check that so it's what it is.
At least now they are bi-wired as suggested regardless.
When I had 3A ( not sig) they were sensitive to the tilt and tweeter hight. an inch and make one heck of a difference.
All I know is the Vandy 5's are one helluva speaker, and endgame speaker to get you off the merry-go-round. If you can find the 5's at a good price, jump on them. In the mean time, enjoy the 3's.HT SYSTEM-
lsi 9's -
Placement is kind of a challenge here.All I know is the Vandy 5's are one helluva speaker, and endgame speaker to get you off the merry-go-round. If you can find the 5's at a good price, jump on them. In the mean time, enjoy the 3's.
I got lucky on the 3A's. I haven't seen 5's anywhere locally let alone within my budget.
Back to 3A's.
I'm really afraid to listen to higher volumes with the Rotel now so I hooked the Crown XLS1500 up.
It sounded okay but compared to Rotel, it sounded thin.
The depth/heft is lacking.
I cranked it up and it sounded loud but still hollow and brighter or felt brighter due to lack of depth.
It didn't have the punch in overall sound and I felt like music is more directional.
It's listenable, just not as good as Rotel.
But I'll bring the speakercraft bb275 from the basement and use that instead.
I'm guessing that'll sound better than the Crown.
I'll test Rotel with another pair of speakers and pass on if it works fine at loud levels.
Seriously dude....waste of time imho. Your speakers deserve better, your ears deserve better.
lsi 9's -
I will get something better.
This is temporary just to go with bi-wire recommendation instead of using single wire with crappy jumpers.
And it does sound better I think and I already had them so it's not a total waste to experiment.
You shouldn't be using that standard spool wire from Home depot or the likes, let alone 16 ga. wire. It's all junk....worthy maybe of surround speakers or a garage rig, nothing more.
Find some well made 12 ga. cables, single runs and use extra speaker cable as the jumpers. You can get a roll of most major brands of cable without connectors at a fraction of the price and use bare wire. Try the Cable Company, click on bulk wire or search by brand.
http://www.thecableco.com/Catalog/Bulk-Speaker-CablesHT SYSTEM-
lsi 9's -
Yes, I'm looking at Canare or Furez 4-conductor wire if I do DIY.
I was using single wire from MIT E98771 or something 14 gauge and Proflex 12 (or is that 14, need to check) gauge in wall already but Vandersteen suggests bi-wire so changed it.
That bi-wire cable is 16 awg each cable so bi-wire makes it close to 13 awg I think.
From the awg and feet chart, that should be okay as it's not even 12 feet long.
May be I should go back to single wire and just replace the jumpers with same wire for now until I get better bi-wire cables.
Single run won't work as I'll always be thinking I'm not doing what Vandersteen suggests.
For the amp, any good bad on Hafler, Carver or Arcam or other suggestions?
thanks
Depends on the amp. None of those really make me want to check the bank account though, especially hafler and arcam.
So Carver pm600 (200 wpc) or M400 is better option?
There is one for 2 hundred locally.
In the mean time, I'll try Speakercraft BB275 currently using in basement and QSC 1450 (that is just sitting doing nothing).
Look for a nice B&k or Parasound 2 channel amp for around 4 bones used. The SQ on either is head and shoulders above everything your looking at. Then you'll need RCA's to hook it up too so don't think about 20 buck IC's for that. Signal cable analog 2's or BJC LC1 bare minimum. Dougs cables too are reasonable and should be a big step up.
On another note....with floorstanders that can pump out the low end, you need a bigger gauge cable for that low end . Bi-wire in general doesn't do much....your simply making that split in a different area. The same thing is accomplished with quality jumpers, and they should be the same as the speaker wire....if not better. Some even use 9 ga. even 8 ga. for the lower portion. Depending on the speaker of course.Post edited by tonyb onHT SYSTEM-
lsi 9's -
There is a BK 200.2 in the FM, also billbillw had a older AQ slate cable that he cut in half and sold me for $80. if you interested in it but it measures about 9' 9" and bi-wired with spades on speaker end and banana's on amp end. here is a pic
Okay thanks. Will keep eyes open for those amps.
For the IC's, I have few Taralabs prism 22 and Delta Audio Tributaries so I think they are at least same or better than LC1's.
Also have few pairs of Wireworld Oasis III interconnects. I think these are around a $100 so I'm covered there.
Taralabs prism 22 retails over $50 and has great reviews at audioreview.com.
Here is one comparison:Last comparison was between AQ Viper and Tara Labs Prism 22.
The Tara cable out did the AQ by a large margin.
The Tara cables were natural and clean. No muddiness in the bass, clear mid band and a shimmering high band. The soundstage was as deep as the AQ cables showed, but the separation and the clarity was much better with the Tara cables.
I have to dig for more pairs of Wireworld in cable boxes but currently I'm using two pairs of Wireworld Oasis III, a pair of Tributaries and a pair of Tara Labs Prism 22 interconnects between the two systems.
I just tested Rotel with my JBL L80t3's and cranked it so high that my ears are still ringing.
No shutdown, no hum nothing so Rotel is good at least for 8 ohms speakers.
Then I brought the Speakercraft BB275 and hooked the Vandersteen's.
It's only 75 wpc but is stable to 2 ohms as per specifications.SpeakerCraft BB275 75-watt per Channel Stereo Amplifier
High Current Stereo Amplifiers
The BB275 is a two channel amplifier that utilizes discrete high current design, which make it ideal for installations that require multiple speakers to be connected to a single amplifier. The high current designs also allow the amplifiers to reproduce and sustain deep bass.
Custom friendly features include
Multiple turn–on modes, so the amplifier turns on automatically when the main system is switched on; Front mounted independent level controls allow you to balance the volume of each speaker to match the volume of the main system, which can vary greatly with different speakers and power ratings; and Pass through inputs to outputs, which allow multiple amplifiers to be daisy–chained together for multiroom applications and future expansion.
High Current Design
The BB275 incorporates discreet power supplies to balance power between channels. A massive toroidal transformer assures adequate power reserves. Discreet output devices allow the amplifier to drive low impedance loads with very low distortion. Huge filter capacitors improve dynamics and lower IM distortion, while providing a sustained energy storage for low bass.
I put the same track and cranked it up.
The punch and depth in the sound came back similar to Rotel and I think this one has even more punch. It is slightly brighter than Rotel but it may be due to punchier sound in all frequencies.
Highs, mids and lows all sound heavier and with more force.
However, I had to turn the pre to 11 o'clock to get 90 dB.
It was louder than I ever listen to.
I even tested it just past 12 o'clock and it got very very loud but the BB275 amp still kept going.
I only listened to few tracks and I think I may like this better than Rotel.
So for now I'm good with BB275 and will watch for good deals on more powerful amp.
Rotel is in the basement with JBL's and Epicures for the moment.
I'll try the QSC later just to see how it sounds but expect similar sound as Crown.
Yes B&K, Parasound, Aragon, I can also suggest ATI.
ATI makes amps for lots of different companies, I got a Niles amp thats a re-badged ATI and thats why I got it and is by no means Bargain bin. http://www.ati-amp.com/AT6000.php
Hmm... so Niles/Sonance are made by ATI.
Do you think Speakercraft also may be the same?
I'm not sure how accurate the price is but it's listed at $739 at newegg.com
http://www.newegg.com/Product/Product.aspx?Item=9SIA2P20UU7794
Not sure, they never tell who they make amps for I just did the research on mine to find out.
Good speakers demand good playmates....isn't any more complicated than that.HT SYSTEM-
lsi 9's -
Not sure, they never tell who they make amps for I just did the research on mine to find out.Find some nudies.
At least the Niles SI275 and my BB275 look pretty much the same.
Even the 'Cascade output' is same on both.
Could be same OEM. That explains why I like them pretty good.
SI275:
BB275:
If you want an amp that generally goes for $300 or less you can't get much better than an Adcom GFA555 w/ 200 wpc ss instant on gratification good w/ SDAs and can push any speaker made that we dudes can afford. I couldn't give a rats **** if some think it's a bright amp that's what a preamp is for to dial it in, so not to me. It works, it clean and it's so powerful that I can't go past the 9'oclock pos on my pre w/o shaking the walls. I got mine at Audio Classics sight and sound unseen shipped for that $300 w/ shipping thrown in w/ a spec sheet that backed it all. It came slippery clean and is still going strong to this day. Many on here have them for a good reason. No affiliation to AC just a customer from long distance.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
leftwinger57 wrote: »If you want an amp that generally goes for $300 or less you can't get much better than an Adcom GFA555 w/ 200 wpc ss ...
I had Adcom GFA-555 II that the Rotel replaced so I'm familiar with it but preferred Rotel. These two have same specs, 200 w @ 8 ohms and 330 @ 4 ohms.
For the price you might check this out http://denver.craigslist.org/ele/4752120259.html
it got some good reviews and has a lot of flexibility for maybe trying bi-amp/ other configurations.
