Does high quality digital cables matter?
While, I can appreciate the trouble you are going through to set up this blind test and make sure it's fair, efficient, and "get rid of the bias". Isn't it easier to simply listen for yourself and judge for yourself to distinguish any differences between Ethernet (or any other cable(s))? Or, is/are your motive(s) not as pure as you are trying to make it out to be?
I spent time with my AKG 701's and this setup going over my sound interface. If there is a difference to be heard it's beyond me.
JRiver even has a nifty option of "Play file out of RAM". They can use up to 1GB of RAM and move the complete file to RAM. So one long initial fetch vs a bunch of smaller fetches.
I've copied an entire CD over the wire in ~7 seconds. And that wouldn't even fill the 1GB of RAM being used. After that file is in memory it's the CODEC's turn. Again in first 7 seconds of your favorite track the entire album can be brought over and played from RAM. Disconnect the Ethernet cable for the entire album.
In the video I shot I didn't have that feature enabled. I just used the default prefetch. You can check it out in any of the popular media players (Foobar, Media Monkey, JRiver). They expose the various audio subsystems' native feature set.
You could go through the machinations I have just posted a video about. Be honest with yourself and have someone pull the plug as you kick back and listen on some nice headphones.
Please keep in mind I am not speaking about the audibility about any other type of cable. Just Ethernet. -
Yes. As I said many posts ago, this is a BS test. All it can demonstrate is that in this test scenario one person can or can not tell a difference between the cables used. No matter which way it turns out the result can not be used beyond this particular setup.
I've posted the video of the setup working. Flawlessly. Nothing BS about a box with zero switching latency. The song just keeps on playing.
And I agree:
I'm not intending this to be an indication of reliable discernment outside of the person that believes they can pick Ethernet cabling as it relates to audibility. -
As long as the test conditions are mutually agreed upon and mutually honored, I don't think motives matter.No matter which way it turns out the result can not be used beyond this particular setup.
I think that is also true of most stereo equipment reviews. All we can take away from any small sample, short duration, stereo equipment test is the potential result under a given set of conditions.Habanero Monk wrote: »Please keep in mind I am not speaking about the audibility about any other type of cable. Just Ethernet.
I think it's a good experiment topic.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Habanero Monk wrote: »I spent time with my AKG 701's and this setup going over my sound interface. If there is a difference to be heard it's beyond me.
I do not listen to audio through a computer system (with lower quality resistors, capacitors, etc.), from a buffered RAM source as you do. I have already stated (numerous times) that a buffered, RAM sourced, computer generated audio file will reduce resolution and detail making it more difficult to distingush differences between cables (Ethernet or otherwise). It does not suprise me that you cannot distingish differences in a computer audio system, especially with regards to listening to headphones where image weight and soundstage are not as clearly defined.DarqueKnight wrote: »As long as the test conditions are mutually agreed upon and mutually honored, I don't think motives matter.
Yes, I agree that motives don't matter with regards to experiment results (In this single case) if the test conditions are mutually agreed upon. Unfortunately, as I brought up near the beginning of this Ethernet cable debate, that it is Habanero Monk's computer system, BJ Ethernet cable, and test conditions that are being suggested. It has yet to be determined if this will be the final test conditions. My suggestion of HM's motives lead to his suggestions of how the test be conducted and one (motives) directly affects the other (test conditions). That is what I am suggesting here. In TRUE SCIENCE, that would not be the case. Motives would not affect the test condtions and/or result(s) you are trying to achieve.
That said, if both parties agree to listening to buffered audio files from a computer then it is what it is............
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
In some aspects, audio has not changed at all in 40 years. 15 pages of the merits of digital cables making a difference in sound....or not.
Seriously guys ? When all one has to do is try a few different ones for themselves, if you can hear a difference....cool. If not....also cool and keep rocking what you have. Done.
BTW DK....love the analogy of the classroom clown. Gonna have to swipe that one from ya.HT SYSTEM-
lsi 9's -
I don't even know what to say to artists and recording engineers that use DAWs'. Your headphone comment strikes me as particularly uninformed.
I know you are one of the gang so no one here is going to point out your ignorance. There are a lot of people here doing computer based audio.Yes, I agree that motives don't matter with regards to experiment results (In this single case) if the test conditions are mutually agreed upon. Unfortunately, as I brought up near the beginning of this Ethernet cable debate, that it is Habanero Monk's computer system, BJ Ethernet cable, and test conditions that are being suggested.
What does this have to do with the price of tea?It has yet to be determined if this will be the final test conditions. My suggestion of HM's motives lead to his suggestions of how the test be conducted and one (motives) directly affects the other (test conditions). That is what I am suggesting here. In TRUE SCIENCE, that would not be the case. Motives would not affect the test condtions and/or result(s) you are trying to achieve.
If you have a better, some how, unmotivated: motherboard, Intel NIC, 8GB Kingston RAM, PNY SSD, ASROCK Mainboard, AMD CPU, Radeon video card, Microsoft OS, JRiver Media Player way of doing this... Well I'm all ears.
Science is not motive driven? That's a new one. -
One of the few times I am going to agree with Monk on something...so everyone take note of the date and the time. :redface:
But a good headphone setup can be every bit as good as a good stereo rig. And while the soundstage is moved to more "inside" of the listeners head, there is definitely solid imaging and soundstage to be had.
In headrott's defense, he is correct in pointing out that this experiment is in no way neutral but is weighted very heavily in favor of you, Monk. Not copping out in any way but you have dismissed pretty much every suggestion I have made towards the test and how it is going to be executed. Most recently, the NIC thing.
My other issue is that by "playing out of RAM" you are pretty much taking the Ethernet cables out of the equation. I would prefer a direct/constant stream from source (NAS) to DAC. My assertion isn't that I can hear a difference between RAM to RAM but that I can hear the difference between which cable a song is being streamed over.
I need to you list any items that are material in merit outside of physically making a disconnect. You wanted cable A/B/C vs A/B: You got it. You wanted 30 trials: You got it. You wanted your own DAC: You got it.
These are all concessions that I made as a deviation from the original proposal. You will only have 4 incorrect guesses allowable out of 30 rolls of the dice. 86% period.
To say that this is somehow weighted in my favor is misleading. At best.
On the playback stream. There is simply no direct way to 'Play' from an Ethernet cable. Everything is buffered and the amount of buffering depends on the sub-system: MS's WASAPI or ASIO. The buffering is also tweakable like a many things in the operating system. You would have to take up that issue with Microsoft or a particular vendors ASIO implemenation.
I can't change how the fundamentals work. I can only work within their confines.
I'm not going to use the 'Play from RAM' function in JRiver. Do you want me to use Media Monkey? Although I don't like it's layout it is serviceable. -
Habanero Monk wrote: »I don't even know what to say to artists and recording engineers that use DAWs'. Your headphone comment strikes me as particularly uninformed.
Your comment is actually the particularly uninformed one.
Most recording artists and recording engineers have no interest whatsoever in producing audiophile quality recordings or even above average quality recordings. This is one of the greatest frustrations of being an audiophile: you assemble a high resolution stereo system but so many of your favorite recordings are low resolution due to poor recording practices.
Before the digital era, the standard practice was to use tons of compression so that recordings would "sound good" on AM and FM radio. In the digital era, low resolution MP3s dominate the market. High resolution digital music files and SACD are niche markets. Most consumers don't care about sound quality, therefore most music producers, engineers, and recording artists don't care either.
Digital Audio Workstations (DAWs), like any recording production tool, come in various levels of quality. You can even get versions that run on a smartphone. Computer audio generally has a poor reputation with audiophiles because of the generally low production values.
With regard to the headphone comment, you again appear to be misinformed because headphone sound is not stereo sound, it is binaural sound, and therefore unnatural because people don't listen to music under normal circumstances with one ear isolated from the other. As I said in my review of the Philips' Golden Ear Challenge, the tests were designed to be done with headphones, but some of the exercises were easier to hear when listening through my computer's stereo loudspeakers:DarqueKnight wrote: »The test is designed to be taken with headphones. For some tests, such as spatial impression and timbre, I would use the computer's loudspeakers. I am not a regular user of headphones.
You continue to display a common trait among blind test for stereo proponents: a lack of basic knowledge of how stereo works. Indeed, some of the most published and most well known stereo blind test proponents, like Floyd Toole, Stanley Lips-h- i- t- z, and Arnold B. Krueger, don't even like stereo because they consider it inferior to monophonic sound. (Part of Stanley's last name was hyphenated because the forum censoring software thinks it is a "bad word" and will star it out.)One of the few times I am going to agree with Monk on something...so everyone take note of the date and the time. :redface:
It us unfortunate that you picked this particular point to agree with HM.
Stereo sound is based on the same sound localization processes that humans use everyday, whether listening to music or trying to determine the location of an ambulance siren. The human listening mechanism is not designed to have the sound stage moved to the inside of our heads.
I agree that a good headphone setup can provide the same, or even a higher, level of subjective listening satisfaction as a good stereo rig, but when evaluated on strictly stereophonic performance parameters, the headphones will always come up lacking. That is because headphones are not a stereophonic sound medium. They are a binaural sound medium. That is why the vast majority of audiophiles prefer to listen with stereo loudspeakers rather than headphones.In headrott's defense, he is correct in pointing out that this experiment is in no way neutral but is weighted very heavily in favor of you, Monk. Not copping out in any way but you have dismissed pretty much every suggestion I have made towards the test and how it is going to be executed. Most recently, the NIC thing.
One of my chief complaints about stereo blind tests is that they are usually setup in a manner unrepresentative of how the listener listens to stereo. It is as if the blind tester really has no confidence in their methods and always need to stack the deck in their favor.
If you two are not going to set up the test in a manner representative of how you actually listen, why do the test?
HM said one of the reasons he is hesitant to do tests at Polkfest is that he would not want to test people on systems they are unfamiliar with. However, for this test, it appears he is doing exactly that: testing someone on a system they are unfamiliar with.Proud and loyal citizen of the Digital Domain and Solid State Country! -
DarqueKnight wrote: »Your comment is actually the particularly uninformed one.
We will have to agree to disagree. I think you like bending items to appear as absolutes.
You want to point out the ability to edit audio on a Smartphone fine. I'll point out BSS, Lynx, Amarra, RME, Benchmark, Apogee etc.
You want to point out compressed music mastered by engineers for low-fi audience. That's perfectly fine. I'll point out my recordings of Mahler, Dvorak, Rachmaninoff, Holtz, DeBussy then onto Steely Dan, some nice Hendrix remasters, Eric Johnson, Pat Metheny, Eagles, Michael Hedges, .... The list goes on of well recorded and mixed/mastered albums in my collection.
Are all of them gems, most certainly not. Are all of them dogs, most certainly not.DarqueKnight wrote: »With regard to the headphone comment
What did I say exactly about headphones again? Can you find and quote me please?
Headphones are fine for critical evaluation. One of the benefits is they have lower distortion characteristics than most well designed speakers. I know headphones are binaural. That is why only biaural recordings work on headphones and not on speakers. They rely on the ears receiving direct input and uncoupled from each other.
Headphones also take the room out of the equation. We are measuring the ability to discern audible differences in cables. This could be done Stereo, Monophonic, Headphones. If there is a difference it should be apparent across these devices in various configurations if they are of high enough resolution. I'm not evaluating stereophonic performance. I'm just administering the test. ZDTFUL can use his own evaluation methods. I didn't preclude him from this. All I said was his setup.
I've never heard a 2.0 stereo come close to the soundstage and environmental element placement that a well mastered binaural recording does. Pretty trippy. Dolby Atmos hopefully will also do a killer job in a properly setup room with environmental placement of sound elements. You did bring up sound field placement, No?
DarqueKnight wrote: »One of my chief complaints about stereo blind tests is that they are usually setup in a manner unrepresentative of how the listener listens to stereo.
Can you find where I made a determination as to how he will listen?DarqueKnight wrote: »It is as if the blind tester really has no confidence in their methods and always need to stack the deck in their favor.
One, I'm not blind in this scenario. It is SBT. I'm not even testing. ZLTFUL is. Two, anyone is free to point out any gross errors in my setup or testing rig.DarqueKnight wrote: »HM said one of the reasons he is hesitant to do tests at Polkfest is that he would not want to test people on systems they are unfamiliar with.
Wait one second. I never said I was hesitant in that regard. Up till this thread I have seen nothing but entrenchment about doing this in your own listening environment.
The entire point is I offered at something like the PETT Summer Festival to get some seriously high resolution gear together and setup in a hotel room somewhere. Nothing but blow back over that. So what do I do? Offer to bring it to someones own listening room.
Any testing environment, by shear nature of testing, is not a natural act. Sleep studies, drug studies, the Pepsi blind taste test. None of these are natural. I don't recall the last time I stood in the middle of a mall drinking sugared, carbonated product, from little plastic dixie cups.DarqueKnight wrote: »However, for this test, it appears he is doing exactly that: testing someone on a system they are unfamiliar with.
All you can do is try to accommodate the setup to close as natural as possible. You do understand that the DAC is receiving a bitstream correct? Are you going to make the argument that a modern computer, with minimal OS and Application software/services foot print can't accomplish this task?
It will be over his AQ USB cable and any CAT5 and unknown high end Ethernet cable ,as long as they are certified, that he brings.
Plus my BJC cable. It will be his DAC, his room, his speaker/s, headphone etc...
How do you know the computer I am bringing isn't better or worse than the setup he has? -
Here is a link with Paul Hales interview much is in relevance to HT, but there are other interesting points about how we listen. This of course is all subjective just like music.
http://www.avsforum.com/t/1478854/the-science-of-the-room-with-paul-hales2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
It isn't that difficult. 3 different "levels" of cable connected to 3 identical NICs. Plain and simple.
Your BJC, my Cat5 Belkin and my "high dollar" Cat6 cable.
We make some baseline comparisons to "get my bearings" and then I tell you, out of 30 runs if it is A, B or C. (I am upping it to 30 to give each cable a "fair shake".)
I am allowed to take notes on each of the baselines and am able to take up to 3 complete albums per cable to generate the baseline.
My proposal of 3 cables was simply to lower the chances of me simply guessing correctly. Taking my chances of "guessing" from 50/50 to a 33.333333...% chance of simply guessing right. In reality, I am weighting the test in your favor. Not sure why that doesn't appeal to you.You're the one that came up with the arbitrary 10 "runs" per cable. I offered 3 cables. Yeah...and...uh...math. :rolleyes:
It's 30 rolls of the dice. Not 10 runs of each cable. If they happen to average ten 1/2, ten 2/3, and ten 4/6 rolls then so be it. Average distribution. I assume a fair shake is as reasonable as even distribution of dice roll.This goes back to the above mentioned me providing everything for the test. Equipment I am familiar with. Equipment I have countless hours of listening to. Why would I volunteer to experiment with system components I know nothing about?
Because I need to be familiar with the testing rig. It's just a point to practicalities. If you want, and have a machine that can accommodate three NIC's I'll just bring a 90 day Win7 eval CD, three Intel NIC's, 120GB SSD and my Cisco Switch.
Do you have ANY objection to those items? I can setup and configure Friday. The Intel NIC's are PCIe 1x. So if you have a computer what is it's configuration? What is the mainboard? CPU, RAM, etc...?
As to the Intel CT series NIC's: They allow for LAG on the Cisco switch. It's a way to play back without interruption while cables are being swapped in/out. So the NIC's and switch have to stay. I haven't heard any push-back on the demonstration video that I posted.Vegas likes them odds. But to say that isn't weighted in your favor is naive at best. Whether I accepted that or not does not negate the fact that a simple majority would balance the "weight" of the experiment while 86% places it firmly, squarely, unequivocally and blatantly in your favor. It doesn't take a mathematician to figure that one out.
What is weighted in my favor? You are the one stipulating that you can stone cold tell me if it's your Belkin CAT5(e?), high end CAT6, or my BJC CAT6. It's a slam dunk for you. In light of your claims my 26 out of 30 (30 being YOUR number) is concession to you.As I explained to nbrowser above, I am fully aware that there is no way to completely eliminate buffering. But my argument is to minimize it to the lowest possible level and to get as close to a "pure" stream as possible. This is going to be where the cable is going to have the most impact. Arguably a tick in my favor but less so when you consider that the whole point of the experiment is to determine if a *CABLE* identification can be made.
Again, not asking you to but I am asking that we get as close to a "live" stream as possible.
Fair enough.I use Media Monkey so I am familiar with it. JRiver, I am not. I will agree that the layout of Media Monkey is clunky though.
My suggestion of JRiver is that a lot of people talk about it's sound superiority. Let me play with Media Monkey.What makes it so unrealistic to think that with all of those senses that it is impossible that there are people out there that can hear better than you?
I didn't say that is or is not the case. What I am saying is we are talking about packet driven data. I've spent time on my headphones with both the BJC cables and a cable I put together and I can't follow the bouncing ball even sighted and knowing which is playing and that a switch was indeed made. -
But to buffer an entire song is the equivalent of removing the ethernet cables from the equation period.
Earlier in this thread, Mr Monk made an interesting statement asking if downloaded files from HD Tracks, etc. can be corrupted. That got me wondering if they could pick up jitter as the signal went through the various transitions of electrical to optical to electrical to Ethernet to whatever before it finally arrived at your house. So, I posed that question on a number of forums, and the answer is no, except for one area.
That area is at your home as the digital signal goes into either the DAC, or the device feeding the DAC. In this case, due to the possible deviation in detecting where the signal transitions from a 0 to a 1, or a 1 to a 0, jitter can be introduced. This brings us back to the beginning. Depending on how bad an Ethernet cable attenuates these signals, and still be within spec, it is possible for jitter to be introduced. A better cable with less attenuation will, most likely, result in less timing errors for the DAC. While the CRC will be correct, the file can have jitter. Of course, if the receiving device that will change the Ethernet signal into the file has sloppy hardware then the problem can be worse, better, or the same, due to the +/- tolerance built into the spec.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
That was my effort to make it unnecessary.
3 cables, 3 identical NICs with no physical interaction with the cables.
Unplugging/plugging cable over 30 times increases the risks of a cable not being seated correctly. Period. I have seen it countless times when cable monkeys are terminating and shoving cables into patch panels, 1 or 5 inevitably end up not fully seated.
I think you're still confused so let me clear this one up..
What habanero is saying is that the sound will be playing with or without a cable connected..eliminating any chance for interaction from varying cables. Therefore it's irrelevant as to which cable is used, or how many are used, and at what times they are used. Unplugging/plugging doesn't matter. Nothing will matter. That's the point. Digital. Not analog. Enjoy the learning experience..it's going to be truly enlightening for you guys!Too many good quotes to list..waiting for some fresh ammo.
Curiuos.... what if you could? Would you then need a DBT to verify that what you're hearing is true?
No, I would just need someone to administer a SBT. I don't care if the person knows what cables they are swapping for me. They probably could care less. Just follow the #'s indicated on the dice. -
I'm not a statistician, so I'll keep my comments broad. However, I would encourage you to work out the trials beforehand.
For example, in a straight A/B discrimination (where the odds of guessing correctly are 50% or a coins flip), I believe one would need to correctly guess 8/10 to reach statistical significance. Many would think 7/10 might be "good", but it doesn't reach criteria if there are only two variables.
I'd hate for you two to go to the trouble of doing this without having the correct # of trials, etc.Polk Fronts: RTi A7's
Polk Center: CSi A6
Polk Surrounds: FXi A6's
Polk Rear Surround: RTi4
Sub: HSU VTF-3 (MK1)
AVR: Yamaha RX-A2010
B&K Reference 200.7
TV: Sharp LC-70LE847U
Oppo BDP-103 -
if I succeed, are you willing to admit that you were mistaken?
I'll sit down with you and go through your discrimination process to learn.
I don't think the back and forth is petty. It's just agreement on an approach to testing this out. I will admit not being a fan of being accused of making the 30 roll of the dice suggestion and also the 10 per cable and then gloss it over when I responded with your post suggesting 3 cables and 30 roll of the dice. But it's all copacetic. -
I want to key on this for a second.
First, this isn't a "fair shake" across the board. The goal isn't to A/B or A/C. It is to differentiate between 3 different cables. To that end, while randomizing which cable is being used at a particular time is completely acceptable, random dice rolls that determine the number of times a cable is used is not.
It should be 10/10/10. Each cable gets a "fair shake". But randomizing the order is fine.
As fantastic as the odds are, what happens if all 30 roles are for the same cable? Suddenly the advantage is blatantly skewed in my favor. Which I am OK with but gives you an "out" at the end. "You didn't detect any difference because it was all the same cable making the experiment invalid." Just seems like too many loopholes and escape clauses to me.
30 rolls of the same # is perfectly valid. First off you won't know that it was 30 of the same. You'll indicate to roll the dice and the chips will fall where they may.
Whose to say that there are 30 rolls of the dice, they are all the same, and 5 times you name a difference where none existed?
I'll take my chances. Lets say your Belden or High End cable only roll 5 out of 30. You should be able to tell me when they come into play. You have to be correct 26 times.
I'll refer you back to my original post of #199 when you suggested A/B/C. I responded with the craps table analogy of a player stating they will roll a hard 10. That is you will state with each roll of the dice:
BJC CAT6
Belden CAT5e (is it e?)
Your high end CAT6
I asked specifically because if it was change / no change then basically your chance with each roll is 66% getting it right that there was a change. Make it four cables and just 'Tell if there's a difference' it's 75%. 10 cables nets you a 90% chance of saying "There was a change" and there indeed being one.
I just want this to be above board. -
The 20 "runs" was originally your idea. I added a cable to the mix and upped it to 30. It really is 6 of one or half dozen of another. Semantics really as we were both on the same page...just different revisions of the same manual if you will.
I offered 13/15. 13 right out of 15 tosses. Two cables: BJC CAT6 and your highend CAT6 at least that is where I started. I don't remember my saying 20 dice rolls but will look. -
Don't waste your time Tony...it's like arguing with a tree.
Unless you argue with a running chainsaw in your hands... but you should heed your own advice IMO.
Judging by the way this thread has "progressed", I have a feeling that this comparison will never happen (too many variables/intangibles/rules/criteria/take your pick), and it's probably for the best.
While I have enjoyed reading (some) of the posts here, and even throwing my .02 in every now and then, realistically this has nowhere left to go.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
I could not have said it any better or even as well you stated these facts Ray. Thank you sir.
Also, your last point you brought up regarding setup of the test, is what I was getting at in my last post. Thanks again.
If ZLTFUL agrees to a test that invloves a system (computer audio) that he normally doesn't use to listen to music. This is why this test is not a true scientific test. There are motives going on in the test that are favoring one outcome over another.
Habanero Monk wrote: »If you have a better, some how, unmotivated: motherboard, Intel NIC, 8GB Kingston RAM, PNY SSD, ASROCK Mainboard, AMD CPU, Radeon video card, Microsoft OS, JRiver Media Player way of doing this... Well I'm all ears.
Absolutely; don't use a computer system and headphones to listen to stereophonic music through Ethernet cables. Use a system that ZLTFUL ususlly listens to stereophonic audio through. Fairly simple.Habanero Monk wrote: »Science is not motive driven? That's a new one.
You obviously either didn't undersand what I said, or you ignored it. Go back and re-read the last paragraph of my reply please.
Habanero Monk wrote: »We will have to agree to disagree. I think you like bending items to appear as absolutes.
No, bending items to appear as absolutes is your method, as evident by this statement:Habanero Monk wrote: »I don't even know what to say to artists and recording engineers that use DAWs'.
I am also not the one hanging on for dear life to the absolute fantasy that blind audio tests are perfect for every type of audio.Habanero Monk wrote: »Are all of them gems, most certainly not. Are all of them dogs, most certainly not.
In that case, there was no need to reference not knowing what to say to artists and recording engineers that use DAWs. It's not like every DAWs produces a masterpiece of stereophonic art.Habanero Monk wrote: »What did I say exactly about headphones again? Can you find and quote me please?
Sure. This is from post #445. You were responding to ZLTFUL's comment about image weight and sound stage not being as clearly defined with headphones:Habanero Monk wrote: »Your headphone comment strikes me as particularly uninformed.
There was nothing "uninformed" about ZTFUL's comment. There is no way that a pair of headphones can reproduce a three dimensional sound stage with its accompanying image weight the way that a pair of loudspeakers can. However, since you don't understand stereophonic performance, this concept escapes you.Habanero Monk wrote: »Headphones are fine for critical evaluation. One of the benefits is they have lower distortion characteristics than most well designed speakers. I know headphones are binaural. That is why only biaural recordings work on headphones and not on speakers. They rely on the ears receiving direct input and uncoupled from each other.
If you understand why binaural recordings are not optimally reproduced on speakers, it is bizarre that you cannot (or will not) understand why stereo recordings will not be optimally reproduced on headphones.
It is just common sense that a binaural audio device is not going to be optimal for evaluating the spatial aspects of stereo sound. As far as lower distortion, you are actually just replacing one type of distortion with another when you play stereo music through headphones. Music that is mixed for stereophonic reproduction will exhibit various types of distortion when played back through binaural headphones. That is not to say that the result will not be pleasing, and even preferable, to some people's ears.Habanero Monk wrote: »Headphones also take the room out of the equation.
OK. This is a question for ZTLFUL: Do you take the room out of the equation when you are listening to your stereo?
Again, if ZTLFUL is happy with the test setup, so am I.
If someone says they hear differences in cables under certain conditions, it does not seem scientifically valid, to me, to test that assertion under different conditions.Habanero Monk wrote: »We are measuring the ability to discern audible differences in cables. This could be done Stereo, Monophonic, Headphones.
Again, a basic principle in science is that a thing should be tested the way it is used. If ZTLFUL listens normally to stereo sound, a test with headphones or monophonic sound will have highly questionable application to stereo sound.Habanero Monk wrote: »I'm not evaluating stereophonic performance.
I understand that. Most blind tests for stereo do not evaluate stereophonic performance. The part that is troublesome is that blind test proponents take their non-stereo test results and extrapolate them to stereo.Habanero Monk wrote: »I've never heard a 2.0 stereo come close to the soundstage and environmental element placement that a well mastered binaural recording does.
Some people have a preference for binaural over stereo and some people have a preference for mono over stereo. Just because a stereo sound stage is more representative of "real life" that does not mean it will automatically be preferred by all.Proud and loyal citizen of the Digital Domain and Solid State Country! -
DarqueKnight wrote: »Sure. This is from post #445. You were responding to ZLTFUL's comment about image weight and sound stage not being as clearly defined with headphones:
Ray, I wanted to point out that it was my post (not ZLTFUL's) that HM was responding to regarding image weight and soundstage through headphones for accuracy and clarity.
DarqueKnight wrote: »No, bending items to appear as absolutes is your method, as evident by this statement:
LOL. Keep twisting stuff until it feels comfortable. Oh brother.DarqueKnight wrote: »In that case, there was no need to reference not knowing what to say to artists and recording engineers that use DAWs. It's not like every DAWs produces a masterpiece of stereophonic art.
My response about DAW was to another poster positing that all those capacitors etc in a computer somehow compromised fidelity.
So do you use any computer or other streaming device or are you all discrete analog?DarqueKnight wrote: »Sure. This is from post #445. You were responding to ZLTFUL's comment about image weight and sound stage not being as clearly defined with headphones:
First off it wasn't ZLTFUL, it was HeadRott.DarqueKnight wrote: »There was nothing "uninformed" about ZTFUL's comment. There is no way that a pair of headphones can reproduce a three dimensional sound stage with its accompanying image weight the way that a pair of loudspeakers can. However, since you don't understand stereophonic performance, this concept escapes you.
Talking about being an absolutist. I've never had a stereo pair of speakers put an environmental sound behind my perceived listening position. Take it to head-fi...DarqueKnight wrote: »If you understand why binaural recordings are not optimally reproduced on speakers, it is bizarre that you cannot (or will not) understand why stereo recordings will not be optimally reproduced on headphones.
I understand the difference DK. What I stated more than once is that headphones (and you agree) can be used for critical listening. You are assuming what metrics ZLTFUL is going to be using for evaluation.
My entire point is he can use what ever transducers he currently uses. He could strip of the end of a USB cable for all I care and touch it to the tip of his tongue.DarqueKnight wrote: »It is just common sense that a binaural audio device is not going to be optimal for evaluating the spatial aspects of stereo sound. As far as lower distortion, you are actually just replacing one type of distortion with another when you play stereo music through headphones. Music that is mixed for stereophonic reproduction will exhibit various types of distortion when played back through binaural headphones. That is not to say that the result will not be pleasing, and even preferable, to some people's ears.
You would have to ask ZLTFUL what his criteria is. You're making assumptions.DarqueKnight wrote: »If someone says they hear differences in cables under certain conditions, it does not seem scientifically valid, to me, to test that assertion under different conditions.
The difference is I've made no assumptions with what devices he is going to ears on evaluate with. ZLTFUL is a control, his speakers or headphone is a control. These are all controls. The Ethernet cable is the variable.
We've already went around the testing. Testing is never 100% native. The application of measurement to a degree is also an application of some form of change.
You believe that you can train your bias's down to 0 or near zero. I just demonstrated in video that someone can have a playback system that they have full control of while someone is changing out cables while music is playing back uninterrupted. -
ZLTFUL is going to use his DAC. You are now making a claim about computer A vs B bitstreaming? I know, I know, it all matters. -
I've played around with Media Monkey. Do you use it with a remote, or wireless kb/mouse?
I also have a $350 1.5 meter Ethernet cable coming for my own evaluation. I'll Let you know how it goes. -
Ray, I wanted to point out that it was my post (not ZLTFUL's) that HM was responding to regarding image weight and soundstage through headphones for accuracy and clarity.Habanero Monk wrote: »First off it wasn't ZLTFUL, it was HeadRott.
Thanks for the correction. Headrott said it first in post #443 then ZLTFUL repeated it in post #446.
Neither Headrott nor ZLTFUL were "uninformed" about the sound staging and image weight reproduction deficiencies of headphones.Habanero Monk wrote: »I've never had a stereo pair of speakers put an environmental sound behind my perceived listening position.
I'll be sure to assess the quality of sounds coming from behind me at the next concert I attend.:rolleyes:
As I said, you do not seem to understand the basic concepts of stereophony. Placement of sounds behind the listener is not a part of the two channel stereo performance specification. Two channel stereo is about creating an illusion of a music performance happening in front of you (and to a limited extent, at your sides). If you want to hear sounds behind you, then a multichannel stereo system with 5, 6, 7, or more channels is required. I have never done a binaural/multichannel stereo comparison, but I expect that I would prefer the more natural presentation of a 6 or 7 channel stereo system to headphones.Habanero Monk wrote: »My response about DAW was to another poster positing that all those capacitors etc in a computer somehow compromised fidelity.
Poor quality capacitors in an amp, preamp or CD player can compromise fidelity. The same is possible for a DAW. DAWs don't all sound alike do they?Habanero Monk wrote: »So do you use any computer or other streaming device or are you all discrete analog?
My two channel system is discrete analog. Sometimes I stream music to my home theater system through my Tivo, but only for background music when I am doing something else.Habanero Monk wrote: »What I stated more than once is that headphones (and you agree) can be used for critical listening.
I agreed that headphones can be used for some types of critical listening. They cannot be used to evaluate stereo sound stage and imaging performance, unless the music was specifically mixed for headphone playback, and even with that, there will be significant compromises.Habanero Monk wrote: »ZLTFUL is a control, his speakers or headphone is a control. These are all controls. The Ethernet cable is the variable.
OK. He must have been playing when he said this:Anyway, the layout was agreed to very early on in this discussion. Let's not go changing things up now.My other issue is that by "playing out of RAM" you are pretty much taking the Ethernet cables out of the equation. I would prefer a direct/constant stream from source (NAS) to DAC. My assertion isn't that I can hear a difference between RAM to RAM but that I can hear the difference between which cable a song is being streamed over.You are correct in that there is a certain amount of unavoidable buffering. Even CDPs have internal buffers. That is unavoidable. But to buffer an entire song is the equivalent of removing the ethernet cables from the equation period.Proud and loyal citizen of the Digital Domain and Solid State Country! -
DarqueKnight wrote: »about the sound staging.... reproduction deficiencies of headphones.
Are you being purposefully obtuse?
As far as concerts and music from behind, never sang along with the entire crowd? Portions of Pink Floyd "The Wall" was in surround sound when they performed it live. YES also had concerts in surround.
Why do you keep going back to stereo imaging vs binaural / stereo left/right vs headphones? Is there a point that you are going to come to?
You dove into sound stage. I didn't. My experience is that sound stage, that panorama, is indeed wider with stereo. My experience with sound stage with headphones, that environmental object placement with purposefully mastered tracks, is pin pointed to a degree of 360 of them.
One bests the other and vice versa. You can't have your cake and eat it too. Either could be used to evaluate cables as the evaluatee deems their best chance at reliable, repeatable discernment is concerned. You are superimposing your hang ups on others here.
Again, I'm bringing cables to test. Not headphones, not speakers, not amps, pre-pros, CDP's etc.
It's also great that you expect you would prefer multi-channel audio over headphones. Good for you. It's your preference. I'm personally looking forward to Dolby Atmos.DarqueKnight wrote: »Poor quality capacitors in an amp, preamp or CD player can compromise fidelity. The same is possible for a DAW. DAWs don't all sound alike do they?
About as much as using various smart phones to record and mix audio on eh?DarqueKnight wrote: »I agreed that headphones can be used for some types of critical listening. They cannot be used to evaluate stereo sound stage and imaging performance, unless the music was specifically mixed for headphone playback, and even with that, there will be significant compromises.
Ok so again, are you coming to a point? Have you even seen a post where I asked WHAT ZLTFUL's critical listening setup is? I don't care. Did you see any post of mine asking him what or how he's going to evaluate? Again I don't care to know. We've agreed as far as the Ethernet cables he's going to be blinded to it.
I used headphones to run my testing rig against. How in the world do you know what criteria I was specifically using to evaluate the tracks I was playing?
https://www.youtube.com/watch?v=3FwDa7TWHHc
