Does high quality digital cables matter?
145791027
  • headrott
    headrott Posts: 5,496
    edited May 2014
    If ZLTFUL can't hit the 86% mark on what cable the dice indicate that is indeed data. I still don't know what possible, real world based objection you could have.
    Given that typical GB Ethernet runs can certify out to 20 meters the lengths we are talking about are trivial.
    Plan also on making sure the same nic silicon is used.
    Once again (I believe we are marking a record number of times in one thread of stating that) any type of blind test should not be used in sterephonic evaluation. What do you not understand about this statement? You just have no other comeback than your irrational "well it wasn't design for it's use, but it still can be used to evaluate it." Please tell us WHY blind tests SHOULD BE used?
    Why was any type of blind test not to be used for stereophonic evalutation (but was designed for monophonic, low resolution evalutaion)?
    1) The test type used should be able to evaluate all the aspects of stereophonic reproduction (i.e. soundstage width and depth, detail level, transparency, imaging, tonality, image weight, and a number of other spects). A blind test, as you are suggesting is only testing to see IF there is a difference. That is not sufficiet for a valid test in stereophonic audio.
    2) It has been shown that (in the past) when audiophiles who do blind tests and correctly identify a change or no change in a piece of audio equipment that naysayers simply state "they got lucky" and dismiss the results. Also please see #1 again, as regardless of whether audiophiles "got it right" there is no definitive answer as to HOW two pieces of gear are different. What good does this do for furthering stereophonic audio listening sessions?
    Please learn something about listening to stereophonic audio from a high resolution system before trying to submit others to a test that should not be used in a stereophonic (high resolution) system (for the reasons above).
  • polrbehr
    polrbehr Posts: 2,854
    edited May 2014
    Wow. Another Energizer Bunny cable debate thread.
    Don't see nearly enough of these anymore... LOL
  • Habanero Monk
    Habanero Monk Posts: 715
    edited May 2014
    Hey ZLTFUL,
    I don't have any issue with the CAT5e cable other than, just like your CAT6 cable, it needs to be certified to hit or exceed it's CAT5e rating.
    F1nut Posts: 52,054
    edited May 2014
    Why is it always the naysayers that try to shove their beliefs on others? Be it cables, gear or whatever audio related, it's never the other way around. It's a curious attitude that someone into audio would think that with all the various options available they would not result in differences, be it for the better or for the worse. In fact, it is a belief completely devoid of any sort of logic and borders on the lunatic fringe.
    edited May 2014
    To justify why they won't spend over 40 bucks on cables I guess. Then they seem to define a whole industry by a few bad snake oil companies which is like saying Ford sucks because of one bad model.
    It's also can be contributed to a generational thing when applying logic. Today, it appears the desired outcome is first thought of, and then the logic created to achieve that outcome. Applies to more than audio too. Forcing beliefs on others ? Look around....pretty evident in todays society isn't it ?
    The thought of someone being able to hear things they can't isn't logical to them, when logic clearly dictates the opposite. Then they result to making wagers which also only entices people to lie. Logic Jess ?? Unfortunately there's a lot of people devoid of using any or even knowing how.
  • 11tsteve
    11tsteve Posts: 1,166
    edited May 2014
    a former buddy of mine, whose audio life focussed more on pro audio rather than home applications, claimed he was arguing with me for my own good. It was his effort to be a good friend, and to stop me from throwing money away on useless audiofool cables and doodads. Wire is wire, every 10 ft. run of 10 gauge wire is the same.
    His entire stance started with .... "Well, if it makes a difference, why don't sound companies use better wires in live situations"....
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
    edited May 2014
    11tsteve wrote: »
    Because live situations aren't about the SQ. Most have mixers to enhance the sound. A home environment, a live stadium, and a recording studio are all different in their own way. To achieve good sound in each takes a different approach.
    A lot of sound companies have their cables made specifically for a certain purpose too. They aren't using off the shelf Wal-mart suff. Plus the majority of cables used are balanced, and they make up for any sound characteristics with the mixers or enhancers costing a lot of coin. Can you do that in a home environment....on the cheap ? Hardly....
  • Habanero Monk
    edited May 2014
    So here is where we are at AFAIK:
    1. The testing rig I suggested, modified with one additional NIC and Belkin CAT5E cable. The discrimination will be an absolute pick of either it's BJC, Belkin 5E, unnamed CAT6. All cables certified.
    2. Air fare paid by the person incorrect in their assumption. Haven't heard back.
    3. Who will hold checks in escrow?
    4. Wryed DAC valued at $1600 to be used
    5. Audio Quest Forest USB Cable acceptable?
    6. What are the cable lengths? Need to know this so the computer and network switch can be accommodated out of sight to facilitate switching of cables.
  • Habanero Monk
    edited May 2014
    ZLTFUL wrote: »
    I am also open to Polk Fest being a potential venue for this if that makes it closer for you.
    I already have 3 Intel CT EXP19301CTBLK's and Cisco switch for this.
    Fair enough on the airfare. Perfectly reasonable.
    I have seen so many posts about it 'having' to be on their system that I am not willing to change that up. I think with how much importance that has been placed on this that I would like to honor all those sentiments. I don't think I am off the mark on this one as there are plenty of posts here in that regard.
    I want it to be the most comfortable environment for you. But if you have some fellow PF members that want to come in (I know of at least one). If your o.k. with that and they don't interfere.
    Let me see about getting you the Wyred DAC before hand. It will come to me prior for integration and testing. Looking at the DAC-2 with Femto Recovery Clock upgrade.
    Your USB cable is fine.
    Can the entire setup: Computer, DAC, Switch, me sit on the other side with just line level passing through to your pre or amp?
  • steveinaz
    steveinaz Posts: 19,546
    edited May 2014
    Some people can make a chore out of anything. Hang up the lab coat, and go listen to some music. One thing is for sure, a better quality cable is certainly going to do no harm. Once in awhile you'll run into an inexpensive "performer" like I found in the Blue Jeans Belden 1694A ($16.00/mtr) digital coaxial---and when that happens, I'm all over it. So much for placebo. Now, mind you I haven't compared this cable to super high-end stuff, but I do prefer it over a number of $70-$100 1mtr coax's, such as DH Labs ($89), and preferred the belden.
    edited May 2014
    Absolutely Steve, it can also work in reverse as I too have found in certain instances. More money isn't a guarantee of better sound. That's why I like to try a variety to find my own personal huckleberry....and why I encourage others to do the same. Once I'm happy, I get off the merry-go round and enjoy the tunes.
  • BlueFox
    BlueFox Posts: 15,250
    edited May 2014
    11tsteve wrote: »
    What are 'sound companies'? Recording studios, professionals? If so then, at least, some do. Those that care about the final product.
    http://www.shunyata.com/index.php/reviews-all/professional-endorsements
  • badchad
    badchad Posts: 348
    edited May 2014
    This will be an important aspect of the study. In most types of blind, "discrimination" testing, participants get better with training. That is, if subjects go through several "unblinded" trials of "training", they perform better at the discrimination phase. I think you should start with a basic A/B discrimination as that will make the statistical analysis a bit easier.
    I'm always surprised at the lack of data on the subject. There should be enough data that this isn't really a question anymore.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • Habanero Monk
    edited May 2014
    Also I'm Ok with the Peach Tree DAC in lieu of the Wyred.
    So who would be a neutral 3rd party for escrow?
  • 11tsteve
    edited May 2014
    BlueFox wrote: »
    just to be clear, his views not mine. I meant to demonstrate the stance of his non- belief.
    Polk Lsi9
    Keces DA-131 mk.II
  • BlueFox
    edited May 2014
    I understand. Others say the same thing. Show them it isn't true and they then say the manufacturers gave them the cables for free in exchange for the endorsement. It's just one excuse after the other.
  • polrbehr
    edited May 2014
    I'd be OK wit holding da money for youse guys (less my customary 15% fees, of course).
  • Habanero Monk
    edited May 2014
    polrbehr wrote: »
    I was thinking maybe CFrizz, XCapri, WilliamM2.
    That brings us to the next item.
    I think it would as simple as after the results the Escrow Agent is called up and the checks are sent to the proper party.
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited May 2014
    Not me. I don't want to be in the middle holding $3200 should there be any dispute over the results.
    I don't think the third party has to be impartial either, just honest, and willing to do it.
  • polrbehr
    edited May 2014
    Of course I was joking about holding the money. Unless 15% sounds reasonable, in which case I will be happy to... ; )
    IMO this is taking cable debates to new levels of silliness, so with that in mind, I have a better idea. Rather than a monetary wager, how about the loser has his account at Club Polk deleted with the promise to never return even under another username?
  • Habanero Monk
    edited May 2014
    ZLTFUL wrote: »
    Having some third party "hold" the funds is asking for trouble. I would prefer an actual escrow company to hold it or for a trust to be created (Legal Zoom for like $49) for the protection of both parties.
    I would be fine with that. It needs to be discussed if there is a disagreement over the results. I personally have no problem just bringing a cashiers check and trust ZLTFUL to the process.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited May 2014
    badchad wrote: »
    There is no lack of data on the subject. There is a lack of understanding.
    badchad wrote: »
    This question was settled decades ago by Bell Laboratories (the people who invented home stereo systems). There are many peer-reviewed science journal papers on the topic of proper methods for stereo system evaluation. This information is ignored by some people because it does not fit into their belief system.
    edited May 2014
    That's the down side of the internet. There's soo much information, good or bad, you can find anything to fit a narrative you want to portray. Which is why people need to find out for themselves.
  • badchad
    badchad Posts: 348
    edited May 2014
    So where is the information stored? In know that most data related to the biological sciences is in pubmed.
    I know there is a lengthy thread around here discussing the method and merits of double blind testing audio equipment, but I've seen few actual studies of the actual tests themselves.
    Polk Center: CSi A6
    B&K Reference 200.7
    Oppo BDP-103
  • DarqueKnight
    edited May 2014
    badchad wrote: »
    I found a lot of information on this topic in the archives of the Institute of Electrical and Electronics Engineers (IEEE Xplore database) and the archives of the Audio Engineering Society.
    badchad wrote: »
    You can start with the references cited in these threads:
    A-Historical-Overview-of-Stereophonic-Blind-Testing
    A-Survey-Of-Early-Stereophonic-System-Subjective-Evaluation
    Notice-Of-Sensory-Science-Journal-Publication
  • badchad
    badchad Posts: 348
    edited May 2014
    Ah yes, I had seen that initial post before. I vehemently disagree that double-blind testing is not applicable to audio equipment. It may be, however, that prior studies may not have been adequately performed.
    This was well-done. It surprises me that the basic concepts described in the above paper haven't been incorporated into standardized testing methods. I'd suggest testing one person at a time, and the addition of qualitative questionnaires, but overall, designing a double-blind study should be relatively easy.
    Polk Center: CSi A6
    B&K Reference 200.7
    Oppo BDP-103
  • halo71
    halo71 Posts: 4,639
    edited May 2014
    I wonder if Matthew Polk or any of the other powers that be within Polk Audio today read these forums....
    --Gary--
    F1nut Posts: 52,054
    edited May 2014
    Question for you blind test supporters. What other item/product do you use in your lives that you rely on and/or insist blind test results for?
    Be honest.
  • DarqueKnight
    edited May 2014
    badchad wrote: »
    Blind trials require the assistance of one or more other persons. It adds an unnecessary level of complexity to an exercise that is designed for trained subjects. Blind trials are designed for na
  • DarqueKnight
    edited May 2014
    But audio is different. Audio is full of snake oil purveyors. Therefore, in order to protect innocent, gullible audiophiles from being parted from their cash, they need to grab one, two, three, or more people and set up a blind test every time they want to purchase a piece of audio gear. Only then will they know that the piece of gear under evaluation really provides or does not provide a benefit or detriment.:sad:
