Oppo 105 Blu ray player
24
  • Christo
    Christo Posts: 30
    edited May 2014
    I have the much older BDP-83. Has anyone compared how this fares against the newer 105?
    gudnoyez Posts: 8,161
    edited May 2014
    Christo wrote: »
    I believe the The 95 was the model before the 105 and the 83 was the model before the 103, I love my 105 darbe and think it's the best purchase I have made in quite some time. I can only imagine the 105 fairs better than the BDP 83, perhaps someone who has stepped up from the 83 to the 105 will chime in.
  • BlueFox
    BlueFox Posts: 15,251
    edited May 2014
    I went from the BDP-83 to the BDP-93 to the BDP-103, and each one was better than the earlier model. This is soley for video since I have other gear for music.
  • Christo
    Christo Posts: 30
    edited May 2014
    Good to know, thanks. My 83 is a bit long in the tooth and so I'm considering the 105 as my next player.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2014
    If you have the 83-SE then the 105 is a pretty big upgrade. If you have the regular 83 then the 105 is a massive upgrade, not even close.
    Toolfan66 Posts: 18,055
    edited May 2014
    This^^^^^^
    I have a 95 and 105 and neither one will be leaving me any time soon. "If ever" both have been purchases that I never regretted..
  • Sumerian
    Sumerian Posts: 490
    edited May 2014
    Does the DAC in 105 stand against stand alone DACs? Is it best for the money or does it really come neck to neck with mid priced stand alone DACs (1500$ to 2500$) did any of you guys did a back to back comparison?.
    I am currently using the Asus Xonar Essence sound card for D/A conversion to feed my Cary SLP05 thinking whether to wait and a take a bigger leap or get the Oppo 105 for the time being (If it is a considerable improvement)
  • Sumerian
    Sumerian Posts: 490
    edited May 2014
    Hmmm DAC has been and will be most difficult purchase (at least for me) too many things at play...
  • AsSiMiLaTeD
    edited May 2014
    You can get reasonably close to the DAC quality of the 105 for less money as Skip mentioned. However, you can't really get a much better sounding DAC in the price range of the 105. You'd have to drop quite a bit more coin on something like the Hugo to get a materially better sounding DAC.
    The DAC doesn't have to be a difficult decision. It's pretty simple, if all you need is a DAC then the 105 is probably overkill. If you can use the features of the 105 then it's a great option. If you have $1200 to burn I'd still recommend the 105 even if you don't think you'll use those features now. What you're NOT going to find is another $1200 option or standalone DAC that sounds much better than the 105.
    tonyb Posts: 33,072
    edited May 2014
    Eh, not so sure pal. Used...maybe, new...You may be right. Still, for what the 105 offers aside from the dac alone makes it a no brainer. OPPO hit the sweet spot with this one.
  • AsSiMiLaTeD
    edited May 2014
    I was referring to new, apples to apples comparison price with the Oppo. The used market obviously brings in a bunch of options, some of which would sound better.
  • ALSATIAN in USA
    ALSATIAN in USA Posts: 127
    edited May 2014
    TOOLFAN66 Do you use your 105 as a pre-amp also? does he sound as good as a high end pre-amp... But if not, why you spent more than one grand for a player witch sound as good than a $70 sony Player (if your pre-amp decode the DTS-MA, etc...)
    edited May 2014
    I use my 105 in my 2 channel rig, no I have not used it as a pre amp.. Where did anyone say it sounds as good as a $70 sony player or did I misunderstand the question?
    VPI Scout 1.1 with Dynavector.
    Jolida JD9 Phono Pre.
    Wyred 4 Sound STP-SE
    Wyred 4 Sound SX-1000 monos
    Wyred 4 Sound DAC 2
    OPPO 105
    MIT Shotgun cables through out.
    Polk Audio 1.2tl's fully upgraded
    I have and do use both the DAC 2 and 105 now and then, I can't say I like one over the other.. I use a laptop for my stored music, backed up on a external HD.
  • BlueFox
    edited May 2014
    Toolfan66 wrote: »
    IWhere did anyone say it sounds as good as a $70 sony player or did I misunderstand the question?
    I read that in his post as a statement, but his iglish are not is best. Just joking. Lighten up. :smile:
    edited May 2014
    bluefox wrote: »
    i read that in his post as a statement, but his iglish are not is best. Just joking. Lighten up. :smile:
    lol..
    tonyb Posts: 33,072
    edited May 2014
    The 105 no better than a $70 Sony ?
    Someone needs to get their hearing checked out....and their eyes.
  • mantis
    mantis Posts: 17,380
    edited May 2014
    Maybe they need a better display and audio system to.
    Dan
  • ALSATIAN in USA
    edited May 2014
    Well!... A 70$ don't decode himself the signal but send it to a pre-amp (or receiver) to decode. Voila! if i'am you, I use this player as a pre-amp, because he sound as good as a krell, ANTHEM or similar (after my reading in another forum, like AVS)
  • Sumerian
    Sumerian Posts: 490
    edited May 2014
    Did I read it right ? Did he say 70$ sony player is as good as any pre amp like krell, Anthem ?
  • ALSATIAN in USA
    edited May 2014
    OK, you use a JOLIDA in your system but you send the signal decoded by your oppo via RCA!... Why? The oppo have a lot of input imself and a volume control! You're JOLIDA is useless and is a parasite! He need to be out of this system by all means!
  • ALSATIAN in USA
    edited May 2014
    Sorry!!! The OPPO 105 sound as good as a ........
    edited May 2014
    I don't send the jolida to the OPPO it goes straight to the pre amp. What are you smokin? Never mind you just mentioned avs.
  • Nightfall
    Nightfall Posts: 10,084
    edited May 2014
    Toolfan66 wrote: »
    I think he's asking why you run analog IC's from the Oppo to the Pre?
    What is IS he smoking? :eek: His posts don't make sense.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • dl090465
    dl090465 Posts: 212
    edited May 2014
    ok, you all have me wanting an oppo. question, does the sound up comvert equally using hdmi or analog???
    Room 1:
    ONKYO TX-SR608
    Polk Complete RT 5000 System
    Polk RT3000p's Front
    Polk CS1000p Center
    Polk FX 1000's Rear
    Room 2:
    ONKYO TX-SR608
    Polk RT2000's Front Someone Please Sell Me Some RT3000 so I can have a second RT5000 setup !!!!
    Polk CS1000p Center
    Polk FX1000's Rear
    Polk PSW 120 front
    Polk PSW 505 rear
  • BlueFox
    edited May 2014
    When people talk about the sound of the Oppo 105 they are referring to the analog section. This has been upgraded over the 103 to be better audio. Any sound from the HDMI is what the AVR produces.
  • ALSATIAN in USA
    edited May 2014
    Frankly, TOOLFAN66 if you use a jolida or not don't bother me one once! and FRANKLY! I DON"T GAVE A DAMN ****!.. Try to plug your OPPO TO THE POWER AMP and listen!... No I don't smoke!..I drink 1664 and eat Choucroute! (sauerkraut)... I write as humorist but not anymore!
  • ALSATIAN in USA
    edited May 2014
    Nightfall is right!
    tonyb Posts: 33,072
    edited May 2014
    ...and frankly, we can see why.
    You assertions make no sense. Pre amps differ in sound characteristics too, to suggest an Oppo is as good as a Krell or Anthem merely suggests you have zero experience with either.
    Running the analog outputs in the OPPO lets you use the decoding and dac in the OPPO, obviously it's strong points. The pre amp section in the Oppo is going to be the weakest link.
    edited May 2014
    LOL, now I see the humorist..
    Angry drunk then..
    tonyb Posts: 33,072
    edited May 2014
    Toolfan66 wrote: »
    Angry drunk then..
    Whats worse than an angry drunk ? An angry drunk on sauerkraut.
