whats next?
245
  • marvda1
    marvda1 Posts: 4,943
    edited October 2013
    it was proven a long time age you can have two different amps that measure the same and they still sound different.
    Puritan PSM156
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited October 2013
    thsmith wrote: »
    OP gets it, the other guy dont want to get it or is just a troll.
    Right, after rereading the thread my comments were meant to be directed towards Jestered not the op sky- sorry for the confusion.
    Yes this thread has the signature of troll all over it. I think our responses have been a waste, but only Jestered can decide if he wants to hear for himself the difference. If not then there is no point going any further.
  • ratster
    ratster Posts: 324
    edited October 2013
    Getting the popcorn ready now.
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Clear Day dbl.shotgun
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
    Clear day dbl shotgun
    pitdogg2 Posts: 27,035
    edited October 2013
    Jestered wrote: »
    F1nut- You didn't answer anything. "The amp" is your answer. What about the amp? I've already shown it's putting out the same clean undistorted wattage using either. So what is it that's different? Never mind. I don't need an answer.
    No you didn't you just quoted another, What you didn't show was the current output between the AVR and the Amp
    Amp 99% of the time will put out more current WITH those watts
    Jestered wrote: »
    Tom- I appreciate your responses. I didn't get the answer I was hoping, but at least you provided some good information without the need to feel like you had to get all worked up about it.
    correct you want to hear that your set up is the best....Well it is we all wish we had your gear:frown:
    Jestered wrote: »
    I'll move on. It's a shame. I thought this Polk forum was a little different, but apparently not. The same "agree with the masses and don't question us or else" attitude that every other forum has.
    It's a MUCH better forum than any other on the net it's too bad you are too blind and deaf to absorb some of the best minds on the planet.
    just let me say this the power supply in the AVR was never meant to bank as much energy on reserve as an Amp. Most Amps have a good deal of headroom most AVR's do not. Notice your AVR has say 120wpc in 2 channel and 80 in 5..Well an amp will have 200wpc weather you drive 2 or 5 that is the power supply that F1 speaks of. The power supply in the AVR was NEVER designed to do 120X5 that is why it drops so much down to 80wpc....
  • skky
    skky Posts: 26
    edited October 2013
    I think the whole WPC is a moot point no?Considering most people like myself only use 1 watt or so most of the time...But the current and having the ability to crank up your system without having to worry about distortion is a def advantage over any avr.As of now I'm def looking into an amp, but I don't expect to go with crazy wattage rather just some decent quality built amp like outlaw.
    Edit-man we Canadians get shafted so much when it comes to buying technology, the pricing and choices is just so far off from our US counter parts.Anyone from Canada with some helpful buying advice on AMPS.
  • Jestered
    Jestered Posts: 49
    edited October 2013
    Wow. This has actually become quite amusing! I'm not even interested in the AVR/AMP debate, which should have been a simple discussion, but I'll play along.
    Not sure what you're referring to here. Are you talking about the bench test being for a VSX-52 and I have a VSX-53? If so, they're the same receiver with the same parts, but the VSX-52 had a few things stripped out of it. So the bench tests should be exactly the same between the two receivers. Mine is a higher end model, so we can add some performance to it if you'd prefer.
    I posted the link to the results so you could have checked to see if that was included. I didn't mention it because it makes absolutely no difference in the equipment I was referring to. My AVR and the Emotiva UPA-500 both produce 80 WPC, and it doesn't matter how much current it took to achieve that.
    Current is measured in volts. 1 volt is the amount of current needed to push 1 amp through 1 ohm (resistance). 1 watt is the power that's created when pushing 1 amp through 1 ohm of resistance. That is what creates 1 watt. If you're telling me that a dedicated amp creates better sound quality because there is more "current", you're wrong. Keep in mind, current is the amount of force, or push, it takes to push amps through the amount of resistance in the line. So, if it's actually true that a dedicated amp is using more current, to produce the same wattage, that only means that it also has more resistance and needs more current to produce the same wattage, which I doubt is the case. And even so, it doesn't make any difference because the outcome is still the same wattage/power at the other end.
    Your current comment would only make sense when talking about a more powerful amp over the AVR I'm using, and I've said more than once that both the amp that I was looking at, and the AVR that I have, both create the same watts, regardless of how much current it takes either to create that wattage.
    I'm not even sure where that came from. My setup is clearly posted in my signature. It's a nice setup, but far from what a lot of people are rocking on here. My setup is for me and my family and I could care less if people think it's junk or anything else. I'm envious of a lot of the HT setups that a lot of people have here, but I'm happy with what I have. Your comment can't be backed by anything I've said and doesn't make any sense.
    Great! So I'll add blind and deaf to the growing list. Outside of this thread, I've thoroughly enjoyed this forum. There's a lot of knowledgeable people in this audio/video area. To say that they are some of the "best minds on the planet" is a far stretch. Knowledgeable in the field, sure, but best minds on the planet... No offense anyone.
    If you took the time to read what I have said from the beginning, you'd realize I was always talking about an 80WPC AVR and an 80WPC stand-alone amp. The fact that there's some in this thread that just now figured out that I'm not even the OP just goes to show how quick people are to jump in without actually reading what was said.
    Samsung 65" ES8000 LED
    Pioneer Elite VSX-53
    Polk RTiA5's - Front Towers
    Polk CSiA6 - Center Channel
    Polk RT15i's - Side Surrounds
    Polk FXiA4's - Rear Surrounds
    SVS PB-1000 - Subwoofer
    URC MX5000 - Remote
    treitz3 Posts: 19,986
    edited October 2013
    I'm out of this conversation. Good Lord, help this man. He has much to learn.....and I'm not talking about the OP.
  • skky
    skky Posts: 26
    edited October 2013
    Jestered wrote: »
    Very sound argument, not much to argue with from the logic point of view.All I can say is maybe you can try out a real amp, and then come back with your result?Although I myself have not done so, but it's hard to deny something every else seems to have experience as a placebo.Emo has a 30 day trial, lucky you are from the states and can test it out so why not give it a try?Would be more resourceful than trying to convince all these people who've actually done it.I can't lie I was and still am very skeptical but surely hundreds and thousands of people can't all be wrong?
    nooshinjohn Posts: 25,915
    edited October 2013
    Where are you located skky?
    You are welcome to drop by and hear the difference for yourself. I am experiencing it right now.
    As for the new court jester's comments... there is nothing "sound" about them.
  • Jestered
    Jestered Posts: 49
    edited October 2013
    As for the new court jester's comments... there is noting "sound" about them.
    Please enlighten me. I'm talking basic Ohm's Law. Not Ohm's Idea, or Santa, or unicorns.
    I have always wanted to know simply how this is happening, not that it was not possible. Before getting a real answer that could be tested and proved, all of a sudden I've been jumped on, called names, and attacked. I'm game!
    Please enlighten me how current, you know that Ohm's Law thing I explained doesn't apply to you. And if there's something outside of that, that can provide a real world difference watt-for-watt, please let me know. I'm still interested in a dedicated amp, but I prefer to learn then buy, not the other way around. As someone mentioned that I don't know what this hobby is about, well I think I know exactly what it's about. If I wanted to follow blindly I would simply call some guy I don't even know and let him determine what goes into my cabinet. Instead, I'd prefer to learn why I'm putting equipment in my cabinet and how and why. Isn't that what this hobby is all about?
    URC MX5000 - Remote
    edited October 2013
    PM sent with my ACTUAL phone number so I can explain things personally. Can't get any better than that. If you want to learn, I could even perhaps get one of the very best in the world to call and discuss it with you. You just need to actually want to learn.
    edited October 2013
    Jestered wrote: »
    Why not explain it where others that have the same question can get that information. I don't need you to explain to me how "current", which is what my response was about, can change the characteristics of a speaker, even at the same wattage. Current changes the speed of flow of electrons. It doesn't add anything to what's going out. The final power of what's received is the same.
    And if this is some sort of intimidation attempt, I'm sorry, but it's not going to work.
    Seriously????
    It has been explained ten ways to Sunday for you. It must be "intimidating to actually hear an explanation that will answer all your questions rather than to simply hide behind a keyboard and remain ignorant.
    Good day sir, I am done here.
    SCompRacer Posts: 9,112
    edited October 2013
    Your 1 watt would be great with a loudspeaker at 104dB sensitivity.
    http://www.chuckhawks.com/speaker_spl_amp_power.htm
  • Jestered
    Jestered Posts: 49
    edited October 2013
    Seriously????
    What would you have said? Why would I need to talk to you on the phone after your condescending interactions through this thread? I appreciate the offer, but had no idea what your true intentions were in the PM. And my response to that being publicized doesn't bother me at all. I said what I said and I'll stand behind it.
    If there was any real intention of help in your PM, I apologize, and can do that publicly without needing someone to put it out there without my knowing, which again I could care less about. The bottom line is that you're one of the people that have hated on me, so why would I want to chat it up with you? Especially without knowing what the real intent behind it was?
    URC MX5000 - Remote
  • Jestered
    Jestered Posts: 49
    edited October 2013
    SCompRacer wrote: »
    Another one that apparently has no clue what the actual question was and has not taken the time to actually read.
    URC MX5000 - Remote
    edited October 2013
    Jestered wrote: »
    Actually, I was the only one in this thread you agreed with.
  • Jestered
    Jestered Posts: 49
    edited October 2013
    nooshinjohn- I've also added "ignorant" to the list.
    URC MX5000 - Remote
    edited October 2013
    Jestered wrote: »
    Pay attention, the thread has morphed beyond that. You contributed to that. You are more on than off. ;)
  • Jestered
    Jestered Posts: 49
    edited October 2013
    That's actually true. And if the rest of the haters in this thread would have actually read and understood the equipment I was asking about, they probably would have agreed as well. Unfortunately, there's not enough listening and too much crap talk here.
    URC MX5000 - Remote
  • Jestered
    Jestered Posts: 49
    edited October 2013
    SCompRacer wrote: »
    I'm only one when the "masses" are on. What does that tell you?
    URC MX5000 - Remote
  • Jestered
    Jestered Posts: 49
    edited October 2013
    DSkip wrote: »
    Jestered, many things go down on this forum, but grudges are generally not held. I've had intense bickering a with quite a few members now, and all but one had the ability to see through the mess and put those interchanges aside and get to the fact of the matter. We try to help people here, but inexcusable ignorance is one that hits a nerve. Experience trumps those notions in your head, you've just got to be willing to lift the veil.
    If John had sent me his number, I'd be on the phone wi him now. He is one of those guys whose opinion I respect so much that I want to do nothing but learn from their experiences.
    DSkip- I'm pretty much the same. And your comment would have been a perfect start to that until this:
    You're either horrible at what you were trying to accomplish, or you really good at it.
    URC MX5000 - Remote
  • Jestered
    Jestered Posts: 49
    edited October 2013
    nbrowser wrote: »
    Hrm Pioneer rates the VSX-53 as 110wpc into 8 ohms x 7 according to its user manual...not 80 like its owner claims...interesting, but how would it perform while powering 7 seperate speaker is a whole 'nother question.
    Seriously! Please figure this out. The 110WPC is two channels driven. The 80 watts is the actual WPC when driving 7 channels. Read up!
    URC MX5000 - Remote
  • Jestered
    Jestered Posts: 49
    edited October 2013
    DSkip wrote: »
    John was willing to take time out of his night and try to put the pieces together for you. You not willing to accept that offer is inexcusable, therefore your ignorance is inexcusable. Again, nothing against you, but the truth nonetheless.
    If John had been washing my hair and telling me stories from the past, the response would have been different. But that wasn't the case. Right?
    URC MX5000 - Remote
  • Jestered
    Jestered Posts: 49
    edited October 2013
    URC MX5000 - Remote
    edited October 2013
    Let me break this down one last time...
    The power supply in your Pioneer is SMALLER than the power supply of a stand-alone amplifier, even though it supports the wattage output of 80 watts you have been talking about. Further, the receiver does not have the ability to STORE that energy in either a large number of or into a large storage output capacitor.
    A power amp may be fed by the power supply, but the actual power is within the output caps. the power supply feeds the caps, which in turn, feeds the speakers. The larger the supply of power, the faster the caps can respond to demand. Can small caps, and small power supply equals the same watt numbers... yes, you would be correct to assume that, BUT(and it is a HUGE BUT!) the small power supply runs out of gas quickly and cannot fill the tank(caps) fast enough to meet the demands of the speakers. It is here that your 80 watts of receiver power smack into the wall and kill your speakers through something called "clipping". A more robust 80 wpc amp however will have the storage capacity to meet the demand and deliver what your speakers are asking for.
    The other thing is transient response. This is when the speakers ask for power, how fast does the amplifier provide it, and recover for the next demand? An amp with the larger power supply and capacitance, will be faster every time, and audibly so. Even if all we are talking about is just a few milliseconds, and yes.. even at low volumes.
    edited October 2013
    Jestered wrote: »
    come on man... do you really think I would offer to help you understand if my real goal was to insult you over the phone?
    I am trying to help you here, as have others and all you seem to want to do is insult anyone that tries.
  • drummer86
    drummer86 Posts: 441
    edited October 2013
    This is so well written and exactly what a lot of the number crunchers don't understand. Posts like this are why I still visit this forum daily.
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
  • Geoff4rfc
    Geoff4rfc Posts: 2,831
    edited October 2013
    Now this would have been nice to have read from the very beginning. Instead, a lot of name calling ensued and a lot of unnecessary insults as well.
    I've been here before, just asking for some information that I could digest. I never got rude or attacking but I sure got attacked from my questioning. I didn't get called a troll but several other insults came my way......over a stupid speaker cable.
    Anyway, there's tact, and there's tactless. I saw very little tact compared to the tactless in this thread. But, I can see where it may be difficult to give an answer, then if it's not received the way it's hoped to, then demeaning behavior soon follows, what a shame.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited October 2013
    God knows what source..
    LOL! It all starts there.
  • BlueFox
    BlueFox Posts: 15,251
    edited October 2013
