SL -2000 to SL-2500 tweeter upgrade worth it?
  • westmassguy
    westmassguy Posts: 6,850
    edited July 2013
    StantonZ wrote: »
    I have a different perspective on this one (I just did my 10B XO's): keep two SEPARATE resistors (2 Ohm and .5 Ohm). Why?
    1) Allows for easy "change out" later (I ended up sticking w/the .5 Ohm)
    2) It does alter the behavior of the 12 uF cap somewhat
    It's only a couple of extra bucks...
    The 5s and 10s are two different animals. The 10s have two 12uf Caps, one is shunting the 2 ohm resistor to affect the voicing of the tweeter in relation to the two woofers, if memory serves, while the other is acting as the high pass filter. The 5 has a single 12uf high pass Cap. There's no shunt Cap. Much simpler design.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • StantonZ
    StantonZ Posts: 452
    edited July 2013
    Ahhh...my bad. In that case: it doesn't matter!
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • westmassguy
    edited July 2013
    StantonZ wrote: »
    You're correct with the 10s however. The .5 ohm should be kept separate. It's how I did mine as well.
  • StantonZ
    StantonZ Posts: 452
    edited July 2013
    +1 :biggrin:
  • PolkieMan
    PolkieMan Posts: 2,446
    edited July 2013
    Or replace the poly with a 1 ohm that should do it. You youngsters :razz:
    About the only thing I know of to tame the SL2000 is to disconnect it.
  • Orangeman
    Orangeman Posts: 56
    edited July 2013
    Thanks all, I found the Solens and the Mills at Parts Express. I don't know exactly when I will get the xo mod done , but I will post my findings here. I will do one first and AB the speakers.
  • Orangeman
    Orangeman Posts: 56
    edited August 2013
    If anyone is still active on this post just a note I am ordering the new xover parts for the Monitor 5's. I guess I should open a new thread to report on anydifferance I hear, correct?
  • Orangeman
    Orangeman Posts: 56
    edited August 2013
    Oops....I forgot to mention, called Polk and they are out of rdo 194 tweeters until october. I mentioned that everyone on this thread thought the new tweeters were not as bright as the originals. He said flatly the Opposite !! What a hobby! It is all subjective to a point.
