SL -2000 to SL-2500 tweeter upgrade worth it?
I have a different perspective on this one (I just did my 10B XO's): keep two SEPARATE resistors (2 Ohm and .5 Ohm). Why?
1) Allows for easy "change out" later (I ended up sticking w/the .5 Ohm)
2) It does alter the behavior of the 12 uF cap somewhat
It's only a couple of extra bucks...Home Theater/2 Channel:
dhsspeakerservice.com/ -
westmassguy wrote: »The 5s and 10s are two different animals. The 10s have two 12uf Caps, one is shunting the 2 ohm resistor to affect the voicing of the tweeter in relation to the two woofers, if memory serves, while the other is acting as the high pass filter. The 5 has a single 12uf high pass Cap. There's no shunt Cap. Much simpler design.
Ahhh...my bad. In that case: it doesn't matter!Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets -
Ahhh...my bad. In that case: it doesn't matter!Home Theater/2 Channel:
westmassguy wrote: »You're correct with the 10s however. The .5 ohm should be kept separate. It's how I did mine as well.
+1 :biggrin:Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets -
Or replace the poly with a 1 ohm that should do it. You youngsters :razz:westmassguy wrote: »About the only thing I know of to tame the SL2000 is to disconnect it.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Thanks all, I found the Solens and the Mills at Parts Express. I don't know exactly when I will get the xo mod done , but I will post my findings here. I will do one first and AB the speakers.
If anyone is still active on this post just a note I am ordering the new xover parts for the Monitor 5's. I guess I should open a new thread to report on anydifferance I hear, correct?
Oops....I forgot to mention, called Polk and they are out of rdo 194 tweeters until october. I mentioned that everyone on this thread thought the new tweeters were not as bright as the originals. He said flatly the Opposite !! What a hobby! It is all subjective to a point.
