audio racks
I picked this up at walmart for my office, wheels dont move just looks. Works good in my office.Speakers: SDA-1C (most all the goodies)
Nice racks
Beautiful ZLTFUL!
What kind of feet did you use for the racks?
I've been looking at these racks for awhile, love that there modular and you can get different spacing. Looks like you have the BL series which is the one I want, I prefer MDF boards over glass, only problem is theres no cable management. Wish VTI would add the cable management of the BLG series to this one.
You can buy optional cable management hardware for the BL series. I would have to rotate the racks 90 degrees to install it. The backs of my racks are positioned against the TV. I rototed mine because of space limitations.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
Rack I built with unistrut and leftover glass for my simple upstairs AV system
and Basement audio racks; left is newer oak unit to hold Amps, right is my 80's era holdover....
classic carl wrote: »You can buy optional cable management hardware for the BL series. I would have to rotate the racks 90 degrees to install it. The backs of my racks are positioned against the TV. I rototed mine because of space limitations.
Wasn't aware of that, I'll check it out Thanks -
A very good selection of Racks and Stands, both commercial built and self made. I have an old cabinet that I had made several years ago, I need to find something new also.
Nice setup Mike!
That looks like a clone of the Salamander Synergy racks, which I own. Very nicely done.Main System: Denon DP-59L | Audio-Technica AT33EV | Marantz SA-11S2 | Classe DR-10 | Classe CA-300 | Classe RC-1 | PSB Stratus Gold i's | DIY Balanced AC Power Conditioner | Acoustic Zen and NeoTech cables | Oyaide and Furutech power connectors | Dedicated 20A isolated ground line.
Party System: Laptop #2 | Audioquest Dragonfly USB DAC | Technics SU-A6 | Acurus A-250 | Radio Shack 15-band EQ | Pioneer SR-9 reverb | Cerwin Vega DX9's | Dayton 100° x 60° horns with titanium HF/MF compression drivers. -
Been wondering where the finished product was ZLTFUL, very nice!!! I still haven't finished my shelves yet and you're all done. What kind of speakers are those?
Those are beautiful speakers. What do I know, at first blush I thought they were Vandersteens of maybe 2ce .I guess the logos on top which Vandys don't have should have clued me in better. Again they are very nice2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Old standAttachment not found.
I know this is an old thread and I actually finished these quite sometime ago but I wanted to share the finished product. This website is a lot different than before and I'm not sure how to attach photos here.
I found it easier to load your pics at a hosting site such as Photobucket, then attach here.
A rack I built after this thread was started.
Thanks Mike, beautiful job on the rack, really nice set up. I think I have it figured out now, hopefully pics to come.
Very_ nice setup Mike, love those acoustic panels!
I finished the shelves and now I am upgrading my Polk SDA SRS 2's as many of you have done and suggested. They will then be used in a completely different set up. The second picture is of the set up with my Acapella La Campanella,s and is still in a state of transition. Each of the shelves weighs over 70lbs and are 4 inches thick and solid wood. Each leg consists of 17 pieces of wood and the maple is harvested from my woods when I had it logged several years ago.
Stately!2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
from this to this.The open rack I found at the dumpster and added a few shelves. It became quite the dust collector so I ditched it for the black lacquer multi shelve that has enough clearance for my tt to operate w/ the cover open all the way.
That is one HEALTHY rack, cool that the material came from your property. Appears to be housing some very nice gear! First set of lamps that I've seen that are larger than SDA's !!!
Good job! -
Very nice, I'm jelly over the Acapellas..
Thanks for the comments. Yes, the SDA's are huge and I am anxious to upgrade them, especially the tweeters. The Acapellas are actually as large, much heavier but have a different footprint. They play very nicely with the McIntosh gear. I really wasn't looking for them in particular but came across a deal I couldn't refuse, and I'm very happy to have them.
I'm thinking of building my own out of oak plywood. My wife wants a nice glass panel though to combat dust. I just don't see how a standard rack would look good, my room is flat black with antique wood highlights. How is a modern metal shiny rack not going to stick out like a sore thumb? I'm not sure what to do.
That's a sweet rack, drgalexo. Quite beautiful.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
One I built a while back.
Because I am The Pumpkinking
