audio racks
2
  • sucks2beme
    sucks2beme Posts: 5,694
    edited January 2013
    But all I ever here in there is a low bass sound
  • classic carl
    classic carl Posts: 662
    edited January 2013
    I use these VTI racks that I bought from racksandstands.com
    I bought three racks and configured them into two taller ones. They are 24" W x 20" D, but I rotated them 90 degrees to fit. They are very sturdy and versatile. You can configure them anyway you want.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
    EndersShadow Posts: 17,741
    edited January 2013
    Google flexy rack. It doesn't get more customizable than DIY :biggrin:
  • drgalexo
    drgalexo Posts: 159
    edited January 2013
    Beautiful ZLTFUL, curious how you're going to make that like a VTI. Any stability problems with that tall VTI Carl? Great link Enders, very nice, kinda like a Sampson rack.
  • drgalexo
    drgalexo Posts: 159
    edited January 2013
    Excellent, I love zebrawood but I've never worked with it. That should be very nice with the isolation cones.
  • mantis
    mantis Posts: 17,611
    edited January 2013
    I really enjoy Monitor Audio Speakers , nice man.
    Dan
  • PolkieMan
    PolkieMan Posts: 2,446
    edited January 2013
  • decal
    decal Posts: 3,205
    edited February 2013
    Lookin' good Z.
  • drgalexo
    drgalexo Posts: 159
    How did you attach the shelves, dados and glue or are they screwed together and glued? Looking great!
  • Polkie2009
    Polkie2009 Posts: 3,834
    That looks great Z! Keep the pics coming , that zebrawood is gorgeous.
    mhardy6647 Posts: 35,375
    I like the "Flexi-Rack" design. Simple, easy to construct; adjustable, sturdy, and scalable/configuable. The shelves on this one are Baltic birch plywood, with an extra (and not necessarily required) reinforcement underneath.
    avec and sans flash (sorry the photos aren't better and the temporary collection of gear thereupon isn't more neatly configured!)
    The only other racks I have are decidedly "old school"...
  • drgalexo
    drgalexo Posts: 159
    Yea Mhardy, I like that flexirack design as well, the Sampson racks use solid 11/4" rails, what thickness are the one's you show in the photos?
  • steveinaz
    steveinaz Posts: 19,546
    fjross wrote: »
    Same rack I have, pricey but I love the quality/looks. (salamander triple 20)
    I don't know :-)
    I'll check...
  • wkjeffers
    wkjeffers Posts: 139
    that is a great looking piece of decor.
  • RamZet
    RamZet Posts: 792
    I use a Middle Atlantic Rack (slim 5 series 37u). Boring black rack with sides and a door. I love the look.
    uhhhhhh Iphoto wants the image sideways so its sideways... sry
    B&W CM9Classé Sigma
  • Mikey081057
    Mikey081057 Posts: 7,127
    Sanus... cheap, sturdy and functional
    Garage | Polk Monitor 5B's
    What stand is that?
  • Mikey081057
    What stand is that?
    Sanus DFV50 CH1
  • leroyjr1
    leroyjr1 Posts: 8,785
    My HT rack. Nothing special but keeps everything neat. MSRP $1600
  • brianle
    brianle Posts: 572
  • classic carl
    drgalexo wrote: »
    None whatsoever. I do have a concrete floor under the carpet and pad though. I can knock on the marble slabs with my knuckles while records are playing without any issues at all. I have the same slab with spiked cones under both tables. I also replaced the wooden peg legs under the Dual with spiked feet and replaced the stock feet under the Music hall with Mapleshade radiused bottom brass footers. The VTI racks are sitting on the carpet without the spikes at the bottom. I removed them.
    Main System 2.2:
    Home Theater 5.2:
  • classic carl
    mantis wrote: »
    Thanks! Monitor Audio for 2.1 channel music and Polks for 5.2 channel HT.
    Main System 2.2:
    Home Theater 5.2:
  • drgalexo
    drgalexo Posts: 159
    Thanks to all for some really good information and some really nice racks and set ups. Mickey how about some information and close ups of those stringed instruments, they look beautiful from a distance?
  • wkjeffers
    Has anyonetried BOLTZ racks?
    wkjeffers wrote: »
    I guess you'd be **** not to...
    (sorry)
  • Jason_k
    Jason_k Posts: 110
    I've been looking at these racks for awhile, love that there modular and you can get different spacing. Looks like you have the BL series which is the one I want, I prefer MDF boards over glass, only problem is theres no cable management. Wish VTI would add the cable management of the BLG series to this one.
    F1nut Posts: 52,151
    I was hoping to see some pics of your racks, very nice!
  • headrott
    headrott Posts: 5,496
    Yeah ZLTFUL, those racks look very nice indeed!
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    Great Job on the racks.
