Kimber Kables
tommyt21
tommyt21 Posts: 685
edited September 2012 in Speakers
Im sitting in my office when the Medical Director tosses four braided cables on my desk and tells me there mine. On further inspection they are Kimber Kables PBJ interconnects. It just so happens that less then ten minutes before he came in I placed a order for a XPA-3 and 3 X series RCA's.
Should I send the X series RCA's back and just use the Kimber?
Has anyone had any experince with these cables?
I also noticed the Kimbers dont have Rf shielding is that going to be a problem?
Thanks Thomas
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
  • ravaneli
    ravaneli Posts: 530
    edited August 2012
    no, it will not be a problem.
    And it doesn't matter which ones you will use hence better go with the freebies.
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
    EndersShadow Posts: 17,753
    edited August 2012
    The Kimbers are MUCH better IMHO.
    F1nut Posts: 52,373
    edited August 2012
    Yeah, it does matter, so keep the Kimbers.
  • Upstatemax
    Upstatemax Posts: 2,862
    edited August 2012
    Let your ears be the judge...
    If you like the Emo cables better, keep them and Karma the Kimber cables here.
    If you like the Kimber cables better, send back the Emo cables
  • steveinaz
    steveinaz Posts: 19,546
    edited August 2012
    Kimber PBJ is an excellent budget cable, and may be the last cable you'll ever need. I currently use Hero, but I could go back to PBJ's with zero regret. Hero has a slightly fuller mid band, and treble is ever-so smoother than PBJ, but it's extremely subtle in nature.
    I highly recommend PBJ to anyone who wants to buy cables once, doesn't want to pay a boat load, and be done with it.
  • tommyt21
    tommyt21 Posts: 685
    edited August 2012
    Unless there is some unforseen issue i will probably send the emos back (60 bucks) and use these free ones. do i need to worry about placement around other wires since there is no shielding?
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • ravaneli
    ravaneli Posts: 530
    edited August 2012
    heheh, it sounds tempting to rub your nose again but i will skip this time. Here is some food for thought for you though: if interconnects are important, does it mean that receivers have an inherent advantage over separates, because preamp and amp are soldered on the same board and they have the perfect interconnect, which is no interconnect at all? Think about it for a second, Watson, it is an interesting thought.
    BlueFox wrote: »
    F1nut Posts: 52,373
    edited August 2012
    I'll gladly rub your nose in it, each and every time.
    If you think for one second that the pre amp section of an AVR is better than a dedicated pre amp, you're more delusional than previously proven.
    edited August 2012
    ^Rav's got his normal cable dont matter hard-on going on now. We best stop the discussion before he blows :eek:
    That and dont even think about mentioning power conditioners....
  • B Run
    B Run Posts: 1,888
    edited August 2012
    ravaneli wrote: »
    PLEASE tell me you're joking:eek:
    edited August 2012
    Rav man, give it up already. Your not doing yourself or your species any favors.
  • 98Badger
    98Badger Posts: 317
    edited August 2012
    Try both cables. I had some Kimber Heros for a while but felt they rounded off the notes. Changed to Emotivas and have been much happier. Just goes to show people have different preferences. I thought the Emotivas were more detailed.
  • GlennDog
    GlennDog Posts: 3,158
    edited August 2012
    steveinaz wrote: »
    no nonsense advise, I like it. Thanks Steve!
    G
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    edited August 2012
    Did you say Power Conditioner? . . . well, my friend, I recently procured a brand new Furman (at a discounted $$ from Audio Advisors) .. .
    I am pleased,
    G
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    nooshinjohn Posts: 26,133
    edited August 2012
    ravaneli wrote: »
    heheh, it sounds tempting to rub your nose again but i will skip this time....
    I'll have the roasted troll please, with fava beans and a nice chianti.
  • GlennDog
    edited August 2012
    nice quote, Great movie "Silence"
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • mantis
    mantis Posts: 17,658
    edited August 2012
    ravaneli wrote: »
    Before I state my opinion on this line of thinking , guys back off , everyone is entitled to their opinion right or wrong. I lose respect for anyone who bashes people who are not in the know. I believe ravaneli simply doesn't understand the difference Interconnects can make or the real differences between a receiver and separates.
    So first of all , Interconnects like any component in ones system matter just as much as every other part. This connection between an amp and a preamp or a receivers pre outs need to be of good quality and proper build. Failure here will result is lack of performance. I'm not going to go into cables and sound quality but don't skimp here.
    Now lets talk about a receiver. A receiver is a compromise device that crams everything you need into one chassis. This is not always true for all receivers as some sound as good as separates but none I have ran across performs better for a lot of reasons. One huge reason is noise. Receivers also usually have less quality amps then outboard. You get separate power supplies and better quality caps when using external amps. This is a good idea when trying to drive more difficult load speakers which are measured in Ohms and DB.
    Separates are exactly that. They provide isolated chassis in full separation from each other. They don't add noise into each other or share a common power supply. Yo usually have a cleaner signal path and higher quality output stages etc.
    I strongly suggest you get your learn on and learn the difference between the 2. I see your thinking on the no Interconnect thing which in thought a receiver should yield the best overall performance and the amp and preamp inside the receiver should be an exact match plus no interconnects that could possibly pick up interference.
    Dan
    edited August 2012
    Dan: Here's the issue. He has got his learn on and because he read this that and the other he will discount anyone who says something otherwise. He refuses to actually try out any of these horrible things called interconects unless they are low end. I dont even think he's put his hat in the ring for the FREE MIT DEMO. Instead he will simply spout study's about this that and the other, but when confronted by someone like DK he simply refuses to admit perhaps his logic or sources are flawed.
    That's why we all take issue with him. He is entitled to his opinion no matter how wrong it is, its just frustrating he wont even consider or try it if someone didn't write up a study about it. Hell the MIT Demo cost me 50 bucks in shipping to try out a set of 2k+ IC's and SC's for 2 weeks.
    He simply refuses to put his money where his mouth is and try to experience something rather than just read about it.
    I can read everything there is to know about Magnepan speakers and how they sound. Doesn't make me an expert on it because I have no real experience to base it off.
    Audio is subjective and requires trying new things.
  • pearsall001
    pearsall001 Posts: 5,392
    edited August 2012
    Free is good...send the Emo cables back, pocket the savings & put it towards a top notch AVR & you're done.
  • ravaneli
    ravaneli Posts: 530
    edited August 2012
    heheh, i said i will skip this one, so i will. Surprised that noone saw the truth in my hint though. That has nothing to do with audio, just logical deduction. If these kimber cables are much better than a pair of cheap RCAs, then a receiver would be much better than the sum of its parts connected by an interconnect. Get it? If you were to split the same receiver to amp and pre, and tie them with interconnect, you would lose quality, depending on the cable. For that reason receivers would always be better than separates (think same units) because of the zero loss to interconnects. Come on, someone here must have the logic to see this and the balls to admit it.
    BlueFox wrote: »
    edited August 2012
    Anybody light the grill yet? I'm gettin' HUNGRY!:lol:
  • BlueFox
    BlueFox Posts: 15,250
    edited August 2012
    ravaneli wrote: »
    Your hint is moronic, and there is no logic involved. Nobody is talking about cutting a receiver into pieces, and then hooking up the parts with cables.
  • mantis
    edited August 2012
    tommyt21 wrote: »
    Thanks Thomas
    As already said , PPJ's are excellent cables. They are entry level Kimber Kable but are not entry level performance. They are a gem in our industry and I would cancel your X order. Not to mention Free is incredible especially for PPJ's. I owned them and I loved them. Even if you paid full retail , they are worth every penny.
    Dan
  • mantis
    edited August 2012
    ravaneli wrote: »
    Balls? This conversation is about a receiver being a SC-35 and using external amps. In this case the thread starter is thinking the external amps are going to be better then the internal ones. Has nothing to do with what connection is better.
    Again I completely think you don't have a good understanding of what a receiver is or how it's built compared to separate components.
    Dan
  • mantis
    edited August 2012
    tommyt21 wrote: »
    I suggest you go to the Kimber Kable website and learn why their cables are designed the way they are. They actually are probably one of the best cables to reject noise.
    On a side not it's good practice to run low voltage and high voltage cables separately , at least 6 inches away from each other when ever possible. If they have to cross paths , try to do it on a 90 deg angle.
    Dan
  • jbooker82
    jbooker82 Posts: 1,627
    edited August 2012
    So I guess a tv, with a built in dvd / blu ray player is the best home theater money can buy. That way you don't have to worry about hdmi cables degrading the signal from the BluRay player. You also don't have to worry about speaker cable, interconnects, or even an AVR, pre amp and external amplifiers degrading the audio because the TV will be producing the sound. Anything extra added just degrades the signal.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • steveinaz
    edited August 2012
    tommyt21 wrote: »
    Tommy, I've never had any issue with them. Use normal wire routing ideas (keep ac away from IC's, etc.)
  • steveinaz
    edited August 2012
    I like the placebo effect, it makes me feel cool having exotic cables even though they suck and are expensive. Are WE really here, or is this the MATRIX, and we're nothin but frickin human batteries?
    I buy what I want, because I can---so...nah..nah...nahnah...nah. :cheesygrin:
  • 11tsteve
    11tsteve Posts: 1,166
    edited August 2012
    if i didn't spend extra money on useless expensive cables, i might have enough money to buy a tube amp.... and we all know just how useless those are.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • mesquitehead
    mesquitehead Posts: 312
    edited August 2012
    Consider that the internal wiring inside a speaker is at best 14 or 16 guage common wire.....not too fancy.
    "Thats great... but how does it sound"
    http://www.burginmcdaniel.com/
    http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
    Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
    2007 Tundra 5.7 TRD DC
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
