THe Official "Larry's Rings" waiting list
IN for a set for SDA-2Bs and a set for Monitor 10Bs.
Thanks! -
Will using the rings render the existing screw holes useless for any future use? Just curious if the holes need to be reamed. I understand the rings will pull the drivers tighter so wood screws will no longer even be needed but again just curious.
He was spot on with my rings, all screw holes unchanged. The mdf was starting to come loose after 20 years in some places, so I sealed up some spots after installing the rings, but otherwise the holes lined up with the screw holes just fine.
I would like to change my request from 1c's to srs 2. I snagged a pair of sda srs 2's! It has the same number of drivers as the 1c though, so I don't know if it makes a difference.Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- sl9 surround backNHTsuper1's surroundMagnepan SMGParasound 1500pre- Sofia "Baby" tube amp - Monitor Audio Silver RX2 Marantz 2230/B&Kst140Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe -
I think the pictures in this thread will help to answer your question: http://www.polkaudio.com/forums/showthread.php?103241-Steel-Retaining-Rings-For-SDA-Drivers-And-Passive-Radiators&highlight=dynamat
From DK's write-up, it appears that the templates for drilling the holes for the rings are placed in such a way as to make the new hole right through where the old wood screw hole was. Yes, this way would render the existing screw holes useless for any future use, if that future use would entail using wood screws again. However, if one were so inclined - not really sure why they would be though - they could simply rotate the template to a position that put "new wood" (ie. no wood screw hole through it yet) behind the open template hole prior to drilling. This approach would put the driver or PR askew of its prior placement and does beg the question - Why would you want to do it this way?
If you were to get the rings and for some reason (?) would, at a later date, decide that you wanted to go back to using wood screws to couple your drivers/PRs to the baffle, you could then just remove the steel retaining ring and rotate the driver or PR and drill new wood screw starter holes at that time.
I think this answers your question, but again, why would you want to ever go back to using the wood screws? :rolleyes: -
i would do a full set for my RTA 11T's including tweets if possible.Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
teekay0007 wrote: »I think this answers your question, but again, why would you want to ever go back to using the wood screws? :rolleyes:
Yes, answers my question...thanks. Simply rotating the drivers would work. I wouldn't want to go back to wood screws, that wasn't my question.
Wasn't sure if using the rings would keep the cabinets from retaining the factory look. Not a deal breaker though....function far outweighs form here.I understand the rings will pull the drivers tighter so wood screws will no longer even be needed but again just curious.
Was just curious. -
Monitor 10's here
Put me down for a full set for sda crs+ (pin/blade)
I will update asap for the Ring Master.
I hope this helps. Again, I am assuming everyone wants FULL SETS (Pass Rad, Mid Woofs and Tweet brackets), unless specified otherwise.
Thanks gents,
GAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I think Larry is more than capable of figuring out who wants what. After all, he has done this before.Political Correctness'.........defined
President of Club Polk -
Just so you guys know I am working on getting these done!!
Jesse I will call you today!!
Thanks for making another run of these Larry.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
yes, thanks! i am probably just a little more excited than i should be....:cheesygrin:Polk Lsi9
Keces DA-131 mk.II
Let me know when you need to work out counts for mine brother.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Hi Larry. I'll take a full set for the SDA1C and a full set for the RTA11T (tweets and passives included). If you decide to make rings for the CS350 I'd take a full compliment for drivers and tweet (at a one off premium if necessary). I'd also take an extra set of tweets for a pairs of SDA1C.....now where is gimpod?:cheesygrin: The cabs have rested under the bed for far too long.Too much **** to list....
BRGMAN, You better get ready...with all these rings about to be installed the world will need more gaskets. Did I see an official Gasket thread somewhere? HeheToo much **** to list....
I know that he is, just look at the craftsmanship on the latest Dreadnaught boxes . . . Just trying to help. I'll back-off . . . no prob
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Larry,
Maybe you can send the order right from the website to the cnc machine and when you wake up in the morning all the orders from the past night are all cut and ready to ship out!
Sal
+100Too much **** to list.... -
Seriously, GREAT idea . .
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
If people want them i can get a run going.
I'm tapped out.
What extras i had Tour bought and then disappeared.
Not sure what happened to him.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Tweeter brackets are done
rings will be done tomorrow
these will be ready to fly out the door this weekend!!!! -
Larry............... Id like a set for sda1c.Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
Thanks Toolfan66, for takin care of this on the quick. How do we go about paying and do these include the socket head cap screws or should we be shopping for those?
This is gonna be great! Got the Dynamat, spikes, Armacell, etc. ready to go!! :biggrin: :exclaim: -
All hardware is included, I will post later on payment as long as the site is up.
BTW I am loving the new look!!! -
Damn
i hope you have a few extrasMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Larry you are the man:loneranger:SDA SRS 2.3tls; RDO 198's, Dynamatted, Armaflexed, Gimpod Boards, Crossovers by quadzilla: Clarity ESA 630V, Mills Resistors, Track Audio Spikes, Musky's Curly Maple Caps
CSi5, FXi5, Rythmik D15SE sub, Pro-Ject Xpression III/Ortofon MC-3 Turbo. Pro-Ject Speed Box. Pro-Ject Tube Box II -
You are certainly a stand up guy. I dont know if you caught it but i had switched from 1c to srs2. Im ecstatic! Thanks again Larry!Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- sl9 surround backNHTsuper1's surroundMagnepan SMGParasound 1500pre- Sofia "Baby" tube amp - Monitor Audio Silver RX2 Marantz 2230/B&Kst140Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe
When I have everything in order I will PM all of you, and yes I made extras!!!
Larry, I'd like to speak up for four tweeter brackets and two binding post rings!!!
Here is the link to the For Sale ad!!!
Thanks Guys!!
http://www.polkaudio.com/forums/showthread.php?134200-Sets-of-Rings-for-Drivers-and-PR-and-Tweeter-brackets&p=1791095#post1791095
