How does SDA CRS compare with 2B and other SDA's in general?
24
  • TennMan
    TennMan Posts: 1,266
    edited June 2012
    I was just kidding about the CRS+ with 10B components. I have the drivers in the cabinets for storage but they have never been hooked up. However, the CRS+ components in the 10B cabinets sound great. I prefer them over the CRS+ speakers.
    I'm not the only one who has done this. Another member here recently sent me a PM saying he had done the same thing and liked them. He said they were very similar to the pair of SDA2s that he owns. He said he didn't want to mention it here because he didn't want to catch hell from the purist here.
    What is amazing to me that someone can write off this setup as "just silliness and accomplishes nothing" when they have never heard it. And then someone can say that they are 100% on target. Don't knock it until you try it.
  • TennMan
    edited June 2012
    Toolfan66 wrote: »
    I agree as well, but with that said he is having fun and they are his speakers to do as he wishes, and in the end they are just speakers.
    For the record I would like to her the CRS+/10B's and if I still had my 10's I would try it just for the hell of it..
    I wish you had your 10Bs as well. I think you would give an honest assessment of what you thought of how they sound.
    Toolfan66 Posts: 18,155
    edited June 2012
    I guess, but just because I noticed my fist would fit in a blender, I don't believe I would stick it in there :mrgreen:
    LOL!! Thanks Greg I needed that!!
    F1nut Posts: 51,939
    edited June 2012
    The veneer is peeling off mostly on the rounded corners and little bit along the side.
    That's not veneer, it's vinyl laminate and as such does not lend itself to repair very well.
    F1nut Posts: 51,939
    edited June 2012
    TennMan wrote: »
    The problem as I see it is that the crossovers, drivers and PR in the CRS+ were spec'd for that cabinet volume. Putting those components in a larger cabinet will change the carefully designed and tested performance characteristics.
  • Mystery
    Mystery Posts: 2,546
    edited June 2012
    Quick question.
    Sda menu says the receiver must have a common ground. How do I know my receiver has common ground?
    F1nut Posts: 51,939
    edited June 2012
    I don't know of any receiver that isn't common ground.
  • Joe08867
    Joe08867 Posts: 3,919
    edited June 2012
    Me Neither F1.
  • TennMan
    edited June 2012
    F1, when I first got the idea of swapping the CRS+ components into the 10B cabinets, I came to the same conclusion you did, that the CRS+ components were designed for a specific volume cabinet. However, after further investigation I found that was not the case.
    The first thing I wanted to know was if the CRS+ crossovers were designed for a specific cabinet volume or MW spacing. I quickly found the answer to be no on both counts. The CRS+ crossovers are the same crossovers that are used in the 1987 SDA 2B pin/blade speakers. The SDA 2B that has a larger cabinet volume, (even larger than the 10B) and have a different MW spacing, (which happens to be the same spacing as the 10B). The crossover schematic is even has "SDS 2B/CRS+" marked right on it. They were defiantly not made for a specific cabinet volume or driver spacing.
    The next thing I needed to know was if the MW 6511 dimensional driver was made specifically for the CRS+ cabinet volume. Again I found the answer to be no. The MW 6511 was also used in the 1987 SDA 2B speakers which have a different cabinet volume and driver spacing than the CRS+.
    To save some extra work, I didn't change the 10B's MW 6503 stereo drivers that are original to the 10B cabinets. They are the same drivers that were used in the 1987 SDA 2B speakers so they are not unique to a specific cabinet volume either. If I had decided to use the MW 6510 stereo drivers from the CRS+ speakers there would have been no problem concerning cabinet volume as they were also used in the SDA 1C speakers. As everyone knows the 1C had a much larger cabinet volume. So again, the 6510s are not designed for a specific cabinet volume.
    I didn't change the PRs that were in the 10Bs so that eliminates any problem with cabinet volume. I do realize that the PRs have characteristics, weighting being one of them, that are designed specifically for a given cabinet volume. That is the reason (besides being extra work) that I didn't use the CRS+ PRs. The CRS+ PRs are different and have different part numbers. I would expect them to be tuned specifically for the CRS+ cabinets. I would not recommend using them in the 10B cabinets.
    I want everyone to know that I'm not writing all this to be argumentative. To the contrary, I'm simply wanting to point out that the idea of swapping the CRS+ parts into the 10B cabinets is not as off the wall as it appears on the surface. I did a as much research as I could before just throwing a bunch of parts together. I admit that I'm not an electrical engineer or an expert on audio speakers so there may be some aspects of swapping the CRS+ components into the 10B cabinets that I'm overlooking. All I know for sure is that end the result of swapping the parts is very pleasing to my ears. I prefer the sound of the CRS+10Bs over the sound of the stock CRS+. I think that saying this swap is "just silliness and accomplishes nothing" without even trying it is out of line.
  • sda2mike
    sda2mike Posts: 3,131
    edited June 2012
    Toolfan66 wrote: »
    We need to hook up sometime soon!!! Have you come over and get your ears on my 1.2tl's..
    I can also bring over my fully modded CRS+'s and put them side by side to your stock CRS+'s..
    and...toolfan lifts the lid for our hapless newbie!:biggrin:
  • Mystery
    edited June 2012
    Joe08867 wrote: »
    Me Neither F1.
    Thanks for comments.
    May be some old amplifiers used to have separate grounds...
    The manual mentions using AI-1 amplifier interface for those kind of amplifiers.
    It's working with my HT receiver so it should have common ground. :)
    F1nut Posts: 51,939
    edited June 2012
    TennMan, you made some good points.
    F1nut Posts: 51,939
    edited June 2012
    Mystery wrote: »
    It's not just old amps that are non-common ground, there are tons of new ones as well.
    Your AVR is definitely common ground.
  • Face
    Face Posts: 14,340
    edited June 2012
    Are Pioneer Elites with ICE modules common ground?
    TennMan wrote: »
    Since you're using different drivers, the weighting of the PR may be off. Otherwise I agree, due to Polk's cookie cutter crossovers(before advanced measuring tools were available), CRS's in a M10 may be close enough.
    F1nut Posts: 51,939
    edited June 2012
    I would assume so. I could test mine, but it's too much of a PITA to get to the back.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited June 2012
    Yes the Pioneer's elites are common ground.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited June 2012
    TennMan wrote: »
    You are correct that SDA drivers are not made for a specific cabinet volume. Evidence of this is that the same drivers are used across multiple SDA models across multiple SDA model generations. However, a specific combination of drivers, tweeters, passive radiator, crossover and driver/tweeter/passive spacing is specified for specific cabinet volumes.
    In the case of the 1987 CRS+ and 2B, the stereo and dimensional drivers, tweeters and crossovers are the same, but the passive radiators are different. The 2B uses the SW121 passive. The CRS+ uses the SW100 passive.
    In the case of the 1989 CRS+ and 2B, the dimensional drivers, tweeters and crossovers are the same, but the the stereo drivers and passive radiators are different. The 2B uses the MW6503 stereo driver, the CRS+ uses the MW6510 stereo driver. The 2B uses the SW121 passive. The CRS+ uses the SW100 passive.
    I agree that the most important thing is that the sound is pleasing to your ears.
  • Mystery
    edited June 2012
    Did some listening with these and monitor 7's and still can't decide which one's better.
    I was expecting a dramatic sound improvement in the SDA series from monitor series.
    Are there some tracks, part of a song that can bring SDA effect easily?
  • sda2mike
    edited June 2012
    so...tell us about your room;)
    heiney9 Posts: 25,492
    edited June 2012
    Mystery wrote: »
    There really shouldn't be any comparsion, the SDA's should sound different.
  • leroyjr1
    edited June 2012
    heiney9 wrote: »
    So with some of the Monitor series having the same drivers as the SDA's one would guess they would sound similar but without the Sda effect.
  • Face
    Face Posts: 14,340
    edited June 2012
    heiney9 wrote: »
    +1...much different.
    edited June 2012
    leroyjr1 wrote: »
    Right and a Ford truck with the same 289 as a Cobra shouldn't be any different either. The entire presentation and design is different even if they use the same drivers. The general tone/timbre should be similar, but it stops there
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited June 2012
    As an outsider reading up until now, I would say that the similarities between the two models would cause tonal similarities as described by H9. The main difference will be the soundstage from the SDA effect. The tonal characteristics will also vary but are definitely the difference that makes the SDA's what they are. As requested by SDA2Mike your room characteristics and placement will greatly effect the dimensional effect that the CRS+'s will/ can give you. Keep in mind that all this also is going to pretty much be limited to "sweet spot" listening. Outside that area, you will loose dimensional sensation and the primary enhancement that comes from the SDA's will be miniscule at best. Good luck getting it right and enjoy the road.
  • leroyjr1
    edited June 2012
    heiney9 wrote: »
    Terrible comparison.... If you pull the same MW driver out of the Sda & monitor they sound 100% the same period.
    edited June 2012
    Oh, ok you're right Monitors and SDA's sound almost the same because they use the same drivers. Don't know why I've owned several of both and sold them side by side in an audio store when new and never noticed they are similar. Stupid people should have bought Monitors instead of SDA's, would have saved them a lot of money. Damn Polk trickery to sell something "appearing" to be different for a whole lot more $$$$$$, when the Monitors are almost the same.
    edited June 2012
    leroyjr1 wrote: »
    Terrible statement, as the driver is not what makes the SDA's different.
  • leroyjr1
    edited June 2012
    heiney9 wrote: »
    You wear glasses and still can't read. I never said the presentation of both speakers sound the same but rather the tonal characteristics are similar. Unplug your SDA's and they sound similar to the single mid driver monitors. Just my opinion though.
    Have a great day...
  • Dawgfish
    Dawgfish Posts: 2,554
    edited June 2012
    Can't we all just get along? LOL!
  • Mystery
    edited June 2012
    Thanks for comments and healthy discussions... :wink:
    sda2mike wrote: »
    If you look at the picture above, the speakers are about 5 feet apart and the couch is about 8 feet from them.
    On the right side, you can see staircase and this room is a long open room; main door from north all the way to sliding door to the left of the TV setup. Main door --> kitchen area-->dining area-->living area which is about 14 x 12 ft.
    I listen at exactly center of these two speakers.
    You can see Advents behind the CRS+, Monitor 7's on top of Advents and monitor 4's on top of 7's.
    There is a Niles SPS-6 speaker selector that is hooked up to the 3 pairs of Polk speakers.
    heiney9 wrote: »
    That's what I'm trying/wanting to hear as I read so much about SDA effect but it's almost the same.
    I listened alone and then also had my wife switch from 7's to the CRS+ and it's not that different.
    I'll have to go through that SDA demo song thread to see if any track brings the SDA charisma.
    Dawgfish wrote: »
    It's alright. Brain needs some exercise every now and then. :mrgreen:
