The AI-1 Dreadnought Project Pt.2 - Upgrade to 1000VA Transformer
12467
  • transmaster
    transmaster Posts: 428
    edited April 2012
    I popped the cover off of one of these Sunair receivers to see if I could tell who made it, all I could find out is it was made in the USA. In the context of subject of this thread this transformer would be better off used as a fishing weight.:cheesygrin:
    Radio Station W7ITC
  • fjross
    fjross Posts: 183
    edited April 2012
    headrott wrote: »
    Would it actually be the AV-047528? Or just a 1KVA transformer with the potted center and a magnetic screen on it?
    Greg
    Greg,
    From what I understand it would be the same AV-047528 as DK's and Toolfan's. I am really intrested on the results of the Piltron compared to the A-L. I will keep in touch with A-L regarding price and lead times and post it as soon as I hear some info. If the Piltron results are better, I will most likely end up purchasing one of them.
    Dave
    Mcintosh MC-501 mono blocks
    Mcintosh C-45
    Mcintosh MVP-871
    PS AUDIO AV5000
    MIT 3.3 Shotgun biwire speaker interface
    MIT 3.3 Shotgun XLR interconnects
    Polk 2.3TL's Gimpod boards/F-1 modded crossovers/dynamat/JB weld/Larry's rings/Blackhole 5 strips
    Polk 3.1 TL's mint/stock (purchased new)
    Polk SDA-2's
  • headrott
    headrott Posts: 5,496
    edited April 2012
    I'm with you on that Dave. If the Plitron is better I will get that, if not I am definately in on getting the AV-047528 if that's truely is what they are manufacturing. If you could verify with A-L that it is the AV-047528 we would appreciate it. Thanks for doing this Dave. I look forward to Ray's results and news about the A-L transformer.
    Greg
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited April 2012
    I have received the Plitron transformer. I will start the evaluation later this evening.
  • thsmith
    thsmith Posts: 6,082
    edited April 2012
    Jeez, that was fast. Ray, do you plan to use the cable cooker or did that not do much for the testing ?
    Toolfan66 Posts: 18,007
    edited April 2012
    My thoughts on the new Avel transformer that me and Ray got, but mine has got much better in sound after putting some hours on it, The SDA effect is the best it has ever been since I had these speakers. When the wife comments on how good it sounds and points out where she is hearing things I know things are Good...
    I hope his findings on the Plitron are positive just not sure I want to spend the money on another transformer... LOL..
  • FTGV
    FTGV Posts: 3,650
    edited April 2012
    I assume some of you gents are even using these trannies with common ground amps ?
  • DarqueKnight
    edited April 2012
    thsmith wrote: »
    I am going to use the exact same testing and conditioning methods used with the A-L transformer, including conditioning with the Cable Cooker.
    The Cable Cooker did provide improvements, as noted in the first post in this thread.
  • thsmith
    edited April 2012
    Kewl
    edited April 2012
    Well it has to be someone from here, why not sell it here??
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    edited April 2012
    FTGV wrote: »
    I am with very good results.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • DarqueKnight
    edited April 2012
    Lasareath wrote: »
    That's not my design if it only requires 2 hours of burn in.:wink:
    There are a few other technical inaccuracies, but I'm sure someone will drop him a note regarding those.
    Toolfan66 wrote: »
    Maybe it's a lurker with low or no post count who can't sell here. Who do we know in Ft. Lauderdale?
  • thsmith
    edited April 2012
    If you were going to use MIT S3 shotguns with the AI, which end would be the AMP side for the cable, the speaker or the AI or it don't matter?
  • DarqueKnight
    edited April 2012
    I would not use a directional cable with the AI-1 because signals flow in two directions through it (left speaker to right and right speaker to left).
    edited April 2012
    I have been using MIT Shotgun 3's with fantastic results, and have no plans on taking them out..
  • DarqueKnight
    edited April 2012
    thsmith,
    I need to send you a PM and your box is full.
    F1nut Posts: 51,707
    edited April 2012
    I share Ray's opinion on this, but I've been meaning to get MIT's opinion. Hopefully I'll remember to call them tomorrow.
    edited April 2012
    I would like to know what they say Jesse, and I too would have shared that opinion because I was worried about using them being a directional cable but they work great and I have a lot of hours on them with zero issues.
    I should add that the network boxs worried me more then the cable it's self using it for the dreadnought.
    F1nut Posts: 51,707
    edited April 2012
    Toolfan66 wrote: »
    Right, my concern is with the boxes, not the cable.
  • fjross
    fjross Posts: 183
    edited April 2012
    Ray, are you getting close to providing the results of the Piltron??? Your time and efforts are greatly appreciated.
    Thanks Dave
    Mcintosh C-45
    Mcintosh MVP-871
    PS AUDIO AV5000
    Polk SDA-2's
    edited April 2012
    I would assume if there was going to be problems I would have experienced them by now. But I am curious to know what there thoughts are on this..
  • thsmith
    edited April 2012
    thsmith,
    Box cleaned out.
    Hope it nots bad news like the Plitron is defective:cry:
  • DarqueKnight
    edited April 2012
    I have completed an evaluation of the Plitron 1000VA 6166 isolation transformer. A full review will be posted sometime next week.
    In summary, the sound quality of the Plitron was between that of the A-L 800VA Y236906 and the A-L 1000VA AV-047528. The 1000VA A-L provided a wider and deeper sound stage, more image weight and more overall clarity and detail, particularly in the bass. The A-L is larger and has better build quality than the Plitron.
    Figure 1. The A-L transformer is 23% larger, 16% heavier and has better construction quality than the
    Plitron.
    Figure 2. The Plitron transformer's metal shield is much thinner than the Avel Lindberg's and is not
    permanently attached like the Avel Lindberg's.
    Figure 3. Initial burn in and listening evaluation setup. The tuner on the floor at the right was used to play
    music overnight.
    Figure 4. The Plitron transformer was burned in for 21 hours on the Audiodharma Cable Cooker.
    Figure 5. Both the Avel Lindberg and Plitron transformers sounded better when oriented vertically.
    My AI-1 Dreadnought sits on its left side behind the right speaker. I would prefer it to rest on its feet, but there is not enough space between the speaker and the wall. When I brought the Dreadnough out front for comparative listening with the Plitron transformer, it was sat horizontally on its feet. There was a small lack of clarity and detail. Setting the Dreadnought on its side restored the sound to its prior quality. Up to then, I had not considered that orientation might affect the transformer's sound performance.
  • headrott
    edited April 2012
    OK Dave, it sounds like you are up in getting a "minimum order" of AV-047528 since it sounds better than the Plitron. Did you make sure it would actually be the AV-047528 transformer and not a potted 1KVA transformer with a magnetic shield put onto it? It will not be the same (sound as good) as the AV-047528. I would estimate it will sound about the same as the Plitron. That said, I am definately in on gettin one of the AV-047528 transformers. Thanks Dave.
    Greg
  • thsmith
    edited April 2012
    Thanks Ray!
  • PolkMaster1
    PolkMaster1 Posts: 847
    edited April 2012
    I have interest in the AL AV-047528 1KAV Transformer.
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
  • FTGV
    FTGV Posts: 3,650
    edited April 2012
    Clearly the flux field built up within the A-L's core is less affected by the pull of magnetic north when oriented horizontally.Though my amplifiers utilize Plitron's I have found it sonically benificial to rotate them approx. 180 degrees.
  • drumminman
    drumminman Posts: 3,396
    edited April 2012
    Thanks to both Ray and thsmith for this evaluation. Lots of time, effort and $ were involved to add to the knowledge base. :cool:
  • fjross
    fjross Posts: 183
    edited April 2012
    headrott wrote: »
    Greg
    I will confirm with A-L that the specs for the minimum order run will be identical to the AV-047528 and not just a modified Y-236956 1000va. I was in touch last week and melonie said that she would check to see how there were coming along with the pricing and lead time. I will check on Monday again.
    Mcintosh C-45
    Mcintosh MVP-871
    PS AUDIO AV5000
    Polk SDA-2's
  • DarqueKnight
    edited April 2012
    FTGV wrote: »
    Did you mean to say "oriented vertically"? Better sound was obtained with vertical orientation (case resting on its side).
    Did you mean to say 90 degrees? A 180 degree rotation would turn them upside down if they were already horizontally oriented.
