SDA Custom Circuit Boards Round 2 - Anyone Interested?
I'll take another pair.
I've decided to have another smaller run made, How many I don't know yet I'm still running the numbers, but I'm going to have to wait till after the 1st (Payday) to order them.
Also I made a couple little changes see pics and let me know what you think.
Old Design
New Design
1. Moved P1 down.
2. Move L1 to the right a bit to give you more room around the mounting hole.
3. Added the ability to use a 3 pin connector for P & R if you want. (You'll have to pull the center pin)
Sorry Mark, I misread your earlier post.:redface: So I can put you down for 25-30 sets then? :cheesygrin::eek::razz:
The only problem I see with the changes Tony is if you are using bigger caps than Sonicaps. I know if I was using the redesigned board with the 630V Clarity Cap ESA's I would have a difficult time putting the inductor where it needs to be on the new boards. That is and not having the 18uF cap not haning over the edge of the board. If you are using Sonicaps, it would be no problem though. Also, is there really an advantage to putting the wiring harness for the P and N spots?You can disconnect them from the inductor side, so I am wondering if there is a reason to be able to disconnect the P and N wires directly from the board and the inductor? Unless of course someone was to solder the P and N wires directly to the inductor and get rid of the quick disconnects. Other than that, I'm not sure I see an advantage. Please don't take this too critically Tony as I am simply speaking my mind, but others may see a good reason to have a wiring harness for the P and N spots.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Ooops, I meant to say P and R of course, not P and N.:redface::biggrin: I'm sure you know what I meant though.
Greg
I'm interested there just aren't boards for my speakers. Is there a technical reason there are no 2pc boards? I have SRS 2 B-B.2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
I'll take a set for my 1.2TL.
Gary -
I haven't ordered the boards yet (was going to Friday) as Friday morning the kneeling & ramp on my van took a big dump on me so I had to have it flat bedded over to the shop today and hopefully I'll find out how much this is going to cost by tomorrow $$$$.:sad: So this might have to wait till next month.
Just wanted to keep everyone up to date.
P.S. This will happen.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Sorry Greg, I moved L2 not L1. If you look at the pictures you'll see that L1 and C2-B are in the same place, I didn't move them at all. The connector for P & R is opitional you don't have to use it if you don't want to, it's there for those who want to use the big Solen inductor and want to use a connector for it.The only problem I see with the changes Tony is if you are using bigger caps than Sonicaps. I know if I was using the redesigned board with the 630V Clarity Cap ESA's I would have a difficult time putting the inductor where it needs to be on the new boards. That is and not having the 18uF cap not haning over the edge of the board. If you are using Sonicaps, it would be no problem though. Also, is there really an advantage to putting the wiring harness for the P and N spots?You can disconnect them from the inductor side, so I am wondering if there is a reason to be able to disconnect the P and N wires directly from the board and the inductor? Unless of course someone was to solder the P and N wires directly to the inductor and get rid of the quick disconnects. Other than that, I'm not sure I see an advantage. Please don't take this too critically Tony as I am simply speaking my mind, but others may see a good reason to have a wiring harness for the P and N spots.
Greg“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Tony,
I would be more than happy to pay for mine in advance. -
+1 for me too TonyPolk SDA 1.2 TL
Infinity SSW-210
Integra DTR 7.1
Pioneer SC-57 Elite
Sony X777ES
Sansui BA-5000
Hafler XL 600's in mono w/ George Kay Audio Tube upgrades
Hafler xl 600 stock
Krell FPB 600
Avel 1000VA Dreadnought -
Tony,
I would pay for mine in advance to.
Gary w -
Tony,
You can add me to the list for 1 set. Will pay in advance if needed.
Thanks,
John➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Hey all got the boards ordered Thursday and it's going to take about 3 weeks to get them.
Here's a list of everybody who has first dibs, If I missed anyone just PM me or post here and I'll add you to the list
F1nut 1, brgman 1, Plolkersince85 1, vcwatkins 2, headrott 1, DesertDog 1, Leftplumma 1, woofiepaws 1, fjross 1, nooshinjohn 2, greybeard 1, Dennis Gardner 1, dpgaloot 1, drumminman 1, Mike Reeter 1, WastelandWand'r 1, RickTfromAZ 1, GaryW 1, JayyCee 1.
That makes 21 sets by my count, dorokusai I didn't forget about you I ordered more than enough to cover everyone. Here's a pic the changes I made.
New Design- Moved P1 down.
- Move L2 to the right a bit to give you more room around the mounting hole and you still have the same amount of room for C2-B.
- Added the ability to use a 3 pin connector for P & R if you want.
- The hole between P & R is for using a 3 pin connector, It serves no other function you don't even solder it.
- Everything else is the same.
For those of you who offered to pay up front, It's appreciated and thank you for the offer but I can't do that, If I don't have boards to ship I can't take your money. I'll PM everyone when they get here.
Thanks Guys.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Thanks Tony!
PM your email so i can PP some cash to you brother.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
That's cool Mike I'll PM you when they get here.Thanks Tony!
PM your email so i can PP some cash to you brother.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Cool! Waiting on the word."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Hey everybody, sorry that I haven't been around much lately life has been getting in the way.
Any way the boards came in late yesterday, Let's just say I'm not pleased:frown:. Of the ones I've checked out electrically there fine but cosmetically there crap I wouldn't even give them away let alone sell them. On the 25 I've checked out the solder mask is really funky, wrinkly in spots and some kind of funky stuff or something that won't come off etc.., The silkscreen on most of the boards is ether offset to the left, bottom or both. I'm going to get hold of the company that made them for me and see if I can get them replaced or get a refund. So It's going to be a bit longer. If you want to see what I'm talking about check out this link for pictures www.gimpod.com/boards/boards.html
Sorry about this and I'll post any updates here as soon as I get them. ~ gimpod“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Give em hell Tony:evil::evil:............ Hope you have a back up if you get a refund:rolleyes:Mcintosh MC-501 mono blocks
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
MIT 3.3 Shotgun biwire speaker interface
MIT 3.3 Shotgun XLR interconnects
Polk 2.3TL's Gimpod boards/F-1 modded crossovers/dynamat/JB weld/Larry's rings/Blackhole 5 strips
Polk 3.1 TL's mint/stock (purchased new)
Polk SDA-2's -
If you can't get a refund, I'm still on for the set I ordered. No need for you to take the hit, you were doing this for us.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Damn Tony I'm sorry to hear the company did a crappy job. What are/were they thinking? Idiots. Well, it's not like you were a paying customer or anything so....... Oh wait!! You are a paying customer!!:rolleyes: I can't believe the board company let these go out of their manufacturing plant. Please keep us informed with regards of the outcome. They had better make it right for you. Otherwise the Polk Forum are going to have to e-mail them and get on their asses about it.
:exclaim::exclaim::mad:
Greg
Those boards are nasty. If they don't make it right, one call to your CC will.Political Correctness'.........defined
President of Club Polk -
Hey Tony,
A couple of thoughts come to mind if the manufacturer balks at making good on your order at no additional charge.
1- If the customer service manager appears unhelpful, take it immediately to the person in charge of manufacturing/production. The pics you posted clearly show the (lack of) quality of the boards. Move up the company's organizational chart as necessary. Surely somone will give a damn.
2- Let them know you'll post pics on other forums illustrating what you get when you order from them. This alone may be enough to create a friendly, helpful attitude as no one would pay for that crappy quality.
3- Have CP members, especially those waiting on these boards, email them complaining about the quality of their work.
Good luck with this annoying problem, and don't hesitate to let us know what we can do to help.
Fred"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Or me and Jesse will just fly out there and open up a can of whoopass on 'em!Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Sorry about the lack of updates but I've been out for the last week or so with some kinda bug that was kicking my butt.
So this is where I'm at, I got the boards sent back a couple days ago on there dime so that they can "reinspect and initiate a remake" they should get them by Wednesday and hopefully I'll know what's going to happen by next weekend. I'll try and keep you guys posted as to what's going on. Hopefully they will make a new batch and do it right this time as that would be the only thing that would be acceptable to me. And yes this is the same place that made the first batch.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Hope you're feeling better Tony!!
Thanks for the update.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Thanks, Tony!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
I got an e-mail from them yesterday saying that "We have received the returned boards and have initiated a remake of this order." so it looks like it will be another 3 or so weeks. Sorry about this mess but I'll keep all informed. ~ gimpod“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
You ok for money brother?
I can send mine if needed.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
^^+1 PM me if you need any up front.>
Thanks for the offer guys but I'm good. They better not charge me for them, They can try but that account has around $20 in it at the moment. It's used for buying stuff online only and never has anymore than what I need in it.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
I would like to buy a set for SDA CRS+ and SDA SRS 1.2TL's please
