Will Polk RTI A7 Floor Standers output good sound when paired with Denon 1611 5.1 AVR
vprasad84
vprasad84 Posts: 17
edited April 2012 in Speakers
Hi All,
I am planning to buy the polk rti a7 floor standers next month & i am more confused if my current denon 1611 avr which supports 75 watts per channel @ 8ohms & 110 watter per channel @ 6 ohms would able to drive the rti a7
My room size is 11x11 & wish to seek advice if it would fill the sound pretty. Currently i have Polk RM 6750 satellites & planning to replace the fronts. Please provide your suggestion
Post edited by vprasad84 on
«13
  • KYFHO
    KYFHO Posts: 76
    edited March 2012
    Your receiver will run the A'7s but you will be a very long way from experiencing the A7's full potential. Your room seems pretty small so they should sound okay.
    If you want to see what the A7's are capable of you will want to look at external amplification. The problem is that your particular AVR does not have pre-outs to support external amps. Personally, I would see how they sound with your current AVR because once you go down the road of upgrading your AVR it is hard to turn back (upgradeitis) and becomes expensive.
  • mantis
    mantis Posts: 17,324
    edited March 2012
    Agreed,
    I suggest a receiver upgrade as well with your system. Get the speakers first as it will work then look to upgrade to a higher end model with more power.
    Dan
  • vprasad84
    vprasad84 Posts: 17
    edited March 2012
    hi,
    my avr does have preout so i can anytime make it 7.1 can you suggest me 2 channel amp which i can connect to the preout..i am already having a tight budget for the rti a7 but let me see the amps & may be i can get them later
  • vprasad84
    vprasad84 Posts: 17
    edited March 2012
    mantis wrote: »
    Agreed,
    hi,
    can you tell me which avr i should upgrade too...preferable denon & onkyo only
  • gp4jesus
    gp4jesus Posts: 2,016
    edited March 2012
    I agree w/the other replies minus AVR upgrade as I'm not knowledgeable on the finer points of what u have or should buy.
    If used/vintage amps are on your radar, consider Hafler XL280. 145 WPC into 8 ohms, over 200 into 4 ohms; stable into 2 ohms; important because the 'A7 is 4 ohms below 125hz. Similar, Rotel RB 980 or RB 981 about 120 into 8, 200 into 4.
    Another, though much harder to come by, is a Belles series One. A high current amp stable into 4 ohms. Any will do a respectable job driving those speakers.
    Meanwhile, learn what is warm and/or hot for your AVR w/ your current speakers so you'll know when driving the 'A7s to avoid frying it.
    Shalom, Tony
    *all connected w/Premiere ICs
  • vprasad84
    vprasad84 Posts: 17
    edited March 2012
    ok so more it recommends not to go with my current avr. i cannot upgrade the avr as of now. How about going for polk tsi 500 or tsi 400 floor standers. would i face any limits there too?
  • Lego1
    Lego1 Posts: 62
    edited March 2012
    Your AVR does not have pre-outs, so buying an amp will be pointless. The one single pre-out you're seeing on the back of it is for the subwoofer and it is even labeled subwoofer underneath it. If you want to use an external amplifier, you will need a receiver with pre-outs not only for the subwoofer, but for each channel
  • vprasad84
    vprasad84 Posts: 17
    edited March 2012
    Lego1 wrote: »
    hi, i am from indian and its denon 1611 indian version. The preout is for subwoofer and external amp too. It asks if i want to set the preassign to normal or front i.e dts es or dolby pro iiz...i can connect and external amp and make the system 7.1 i mean comeon it's my avr n i know what all it has got :-)
  • michael1947
    michael1947 Posts: 775
    edited March 2012
    I just checked your 1611 and it does NOT have pre-outs so it will not work for an external amp. It would make a nice second system for you if you have already purchased it and if you have not purchased it then don't. What I recommend is the LOWEST receiver in a series of your selected manufacture that has full pre-outs AND THE NEEDED DO-DADS SUCH AS HDMI, USB, WIRELESS, ETC. I know that in the Onkyo line up it is the TXNR 709 and can be had for at or under $500 at club onkyo. com as a re-furb. I have a TXHR 708 with my main system and it passes off the fronts and center to an external amp and the onkyo fires up the rears and surrounds with lots of power and happiness. Something like the 709 will also run your system marginally on it's own for the near term until you get an amp. Best of luck.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited March 2012
    My question is: why do you want something as big as an a7 in a 11x11 room? Especially if your receiver doesn't quiet have the juice to push it well?
    Why not get a nice bookshelf that will sound great with the power your receiver provides and you can always add a 8 or 10 inch sub if you want more low end.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • gp4jesus
    edited March 2012
    Lietuvis91 wrote: »
    ...why do you want something [that] big... ...in a 11x11 room? ...your receiver doesn't... ...have the juice to [drive them] well?
    [paraphrase] your AVR CAN drive bookshelf speakers (or what you have) very well. Add a quality 8 or 10 inch sub to "do the heavy lifting" if you want more low end.
    I have to agree Lieiuvis. I didn't notice your space was that small. Unless you plan to upgrade your space (room size) w/in say the next 12-18 months 'A7s will overwhelm your room.
    That said, consider RTi A3s w/a CSi A4 or A6 CC, across your front; FXi A4 side/surounds should do nicely!
    Tony
  • vprasad84
    vprasad84 Posts: 17
    edited March 2012
    Hi,
    I might move to a new apartment but i am not sure how soon it could be...may be within 6 months or it might take more than year too...its just unsure...till then i dont want to wait for the sake of room size. so my idea is to have floor standers (some great ones really) & use them at moderate levels..i am looking out much from music & guys my avr has 2 preouts 1 for subwoofer & 1 for external amp (have uploaded the image here of my avr back so you guys can be sure ). Another question is the preassign ask me to set to either front heights or normal (surround back speakers) i.e dolby pro IIz or DTS ES so incase if i get an external amp & connect the rti's to that then how could i set the rti to main fronts while watching movies in 5.1 or 7.1. For music i shall listen in stereo mode so no issues & hence pls suggest me a good power amp for rti. As i already have satellites & i feel its time to upgrade the setup as it is pretty mediocre for me & i am really not interested in book shelves as i would feel the same in sometime again. I have a jbl 12" sub which rocks my house...here many people are using floor standers in a small room & they get really good output. Since i would be investing this for once, i dont want to endup getting something & later crave for another :mrgreen:
  • hertz9753
    hertz9753 Posts: 310
    edited March 2012
    The India version of the Denon 1611 is 5.1 and has pre-outs for adding an amp for front heights, not what you for what are trying to do. Try a search of India Denon 1611.
    AVR-Onkyo TX-NR808
    Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
    Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
    Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
    Sub-Velodyne SPL-1000R
  • vprasad84
    vprasad84 Posts: 17
    edited March 2012
    hertz9753 wrote: »
    okie so even if i get an amp it would be for powering either the surrond back or the front heights :sad:
  • specd_out
    specd_out Posts: 505
    edited March 2012
    A reciever can make a world of difference in the sound of a set of speakers. I have Rti A5's which are very easy to run speakers. First they where connected to a old sony HTIB avr, then I purchased a mid level consumer Yamaha avr, then a Pioneer Elite and final got a seperate power amp. Each time I upgraded it improved the sound. Point being that just because a avr can make the woofer move does not mean you are really hearing the speaker.
    As gp4jesus said getting a smaller speaker will be easier on your current avr and will sound better then underdriven A7's
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • unclebiskabobka
    unclebiskabobka Posts: 109
    edited March 2012
    I do totally understand you wanting to buy the best speakers you can, so you don't have to upgrade again, but everyone is right, the a7's are not going to shine with that small amount of power running through them. In all likelihood, they'll be harsh on the highs, and that receiver will have a very hard time moving those woofers adequately..
    TV - LG 42" LED
    Receiver - Pioneer VSX-521
    Front speakers - Polk Monitor 40's Series II
    Center - Polk Monitor CS1 Series II
    Surround - Polk Audio OWM3
    Subwoofer - JBL L8400P
    "I was born with music inside me. Music was one of my parts. Like my ribs, my kidneys, my liver, my heart. Like my blood. It was a force already within me when I arrived on the scene. It was a necessity for me-like food or water."
    ~Ray Charles~
  • vprasad84
    vprasad84 Posts: 17
    edited March 2012
    ok,
    then how about polk tsi 400 or 500 or even RTI A5? or again any of these floor standers i shoudnt go for & stick to bookshelve? does rti a3 sounds well? i heard they are not so good
  • hertz9753
    edited March 2012
    Can you get the Polk Monitor 60's or 70's?
    AVR-Onkyo TX-NR808
  • vprasad84
    vprasad84 Posts: 17
    edited March 2012
    hertz9753 wrote: »
    it's not available in india...but again would my avr support them...i am looking for tsi 500/400 or rti a5 but again would my avr drive them so that i get excellent sound.
  • hertz9753
    edited March 2012
    vprasad84 wrote: »
    The Polk TSi series is an updated version of the Monitors that I listed above. I would go with TSi 400 with your reciever.
    AVR-Onkyo TX-NR808
  • vprasad84
    vprasad84 Posts: 17
    edited March 2012
    hertz9753 wrote: »
    thanks. i am yet to audition it. I heard they are good for movies. Do they well with music also?
  • hertz9753
    edited March 2012
    vprasad84 wrote: »
    Music is what they do best, a close second is movies.
    :wink:
    AVR-Onkyo TX-NR808
  • mantis
    edited March 2012
    If you like Onkyo then I would start here or go higher depending on budget.
    http://www.crutchfield.com/p_580TXN809B/Onkyo-TX-NR809.html?tp=179
    If you want to stick with Denon then I would use this or better.
    http://usa.denon.com/US/Product/Pages/ProductDetail.aspx?PCatId=AVSolutions(DenonNA)&CatId=AVReceivers(DenonNA)&Pid=AVR3312CI(DenonNA)
    Both models will drive your new speakers very well with no amps needed. Neither is what I would personally use if I was going to RTIA series speakers. I would use this.
    http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers/VSX-53.
    Reason is I feel Elite's are better sounding receiver over both Denon and Onkyo , thats a personal opinion and take it as such. Features also dictate which model to go AFTER you have a good quality receiver that will allow your given speakers to shine. Buying the best receiver your money can buy will only yield the best overall sound quality and experience of your system for years to come. This is a place where you want to spend the most amount of money possible.
    Dan
  • vprasad84
    vprasad84 Posts: 17
    edited March 2012
    hi,
    does onkyo 709 have preouts so i can consider it...or should i need higher ver.
  • hertz9753
    edited March 2012
    vprasad84 wrote: »
    hi,
    Yes it has pre-outs.
    AVR-Onkyo TX-NR808
    tonyb Posts: 33,068
    edited March 2012
    Yep, ditto that, but like Dan said,buy the best receiver you can while also leaving some coin for good cables. Everything in the chain matters.
  • vprasad84
    vprasad84 Posts: 17
    edited April 2012
    tonyb wrote: »
    i got polk rti a7...also sold off my denon 1611...now the hunt is for avr. as of now i have finalised marantz 5006 which outputs 100 watts per channel @ 8ohms...it has preouts for fronts so later i can get a power amp...but would marantz 5006 itself output good sound?
    how does marantz goes with the polk speakers. do they well with movies?
  • Upstatemax
    Upstatemax Posts: 2,735
    edited April 2012
    I'm a big fan of Marantz. They have a similar tone to Denon IMO, hell I think they are owned by the same company...
    The SR5006 will push your A7 fine in your current room and in a larger room.
    If you really won't to start pushing your A7's, you can still add a 2ch amp for them with the SR5006.
  • ravaneli
    ravaneli Posts: 530
    edited April 2012
    I just purchased an SR5006 and I have A7s. I am biamping them, and they sound so much better than my old pio. A lot better depth.
    If you have little satelites on the back and use 5.1 and biamp, you will feed between 150 and 200W per channel to the A7s, which is pretty good even for external amp. At least on paper you will, not sure it will be as good as a high current amp.
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
  • tommyt21
    tommyt21 Posts: 685
    edited April 2012
    mantis wrote: »
    Agreed,
    I run mine with a Pio SC-35 and its a beast!
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
