just rcvd my Squeezebox Touch!
It's really the worst way to do it the way you are doing it as far as getting the best possible audio stream. How are you using the optical output if you are playing CD's in the disc drive? It's not possible, because it converts the music at the soundcard which means you are using the computer internals for the analog signal. Worst way possible. Now I'm beginning to understand why you were complaining about your rig sounding so bad.
But wouldn't using say digital coax out from a sound card (something $150) bit streamed FLAC filed into a DAC work better then his method? Comparible to USB out when async is not an option?
I've contemplated the above for my setup. Could still run USB... -
Slightly better, the soundcard is the issue really as it's still tied to the nasty compute environment. I'd always opt for USB.
I prefer the SQB Touch/ Synology DS-1511+ NAS combination because I don't have to leave my noisy, wattage hungry PC on all the time as well as I love the convenience of controlling music via apps such as iPeng for iOS and Squeeze Commander for Android. The NAS box runs Logitech Media Server installed via a package provided by Synology; it is in my office room, far far away from any audio electronics, therefore my 2-channel room is as black as possible, no noise at all. NAS => Squeezebox Touch => Wyred 4 Sound DAC22 => Wyred 4 Sound STP/SE pre-amp => Wyred 4 Sound ST-1000 amp.Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
So the USB box must be external to the computer's case for best sound quality, due to the interference from the PC's electronics within the case? I've seen USB adapters that sit a short distance away from the PC and connect to an external DAC in several demos. I believe they work together as a pair.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
So about 52ma total draw as he only needs two.A quick look at a pic of the inards of his DAC seems to show it to have some sort of simple unheat sinked discrete reg for the opamps instead of the standard 3 pin variety .So not sure if it can handle the extra draw without generating too much heat in the devices.SCompRacer wrote: »IIRC the Audio GD discrete op amps pull ~ 26mA ...
I'll put my sceptics hat on and ask $12 for a fully discrete opamp?I wonder about parts quality and the extent of transistor matching ,testing etc which usually translates into $.Just being discrete IMO does'nt necessarily mean it will outperform a good IC opamp, but then again at that price it would be worth trying. -
Most DAC's will have a pulse transformer on their SPDIF input which like USB provides galvanic isolation.... the soundcard is the issue really as it's still tied to the nasty compute environment. -
In that case then the sound should be similar to having an external USB --> DAC dongle?polkaudio RT35 Bookshelves
Dongle?
Not sure of the exact name of it. Has USB connector on the computer's end and sits a short distance away from the PC. Pairs up with DAC.polkaudio RT35 Bookshelves
USB -SPDIF convertor?Only needed if the DAC does'nt already have a dedicted USB input.
I think it was something used to extract the bitstream directly from the computer. Salesman said it was necessary to play high-rez files.polkaudio RT35 Bookshelves
I'm right there with you Fred. But the same op-amps are used the in the Audio GD dac I have (NFB 3) and it sounds pretty darn good. I was just thinking of doing some experimenting on the cheap, but the current draw was a concern.
Sorry the tone was a tad negative but they could also turn out be genuine sonic bargains.I might order a pair myself to try in my various DAC's.
So about 52ma total draw as he only needs two.....
There are three they offer; Earth, Moon and Sun. I was incorrect, two are 28mA and one is 25mA each. Here is a pic of one.
The page...
http://www.audio-gd.com/Pro/diy/OPA/OPAEN.htmSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
No problem with the tone Fred. I might pass until I can atleast get a schematic to see how the PS is laid out for the Keces. The current draw is significantly more than the stock Op-amps.
Dongle?
I've used that term for folks that run a short piece of coax with BNC connector off the PCB of their SB Touch. (Not referring to the people, the cable).:cheesygrin: AKA security key. I'm gonna get brave one of these days and mod Brock's Touch with a BNC dongle.:razz: If I don't mess it up, mines next.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I wouldn't do it if as you say the current draw is "significantly more" just to be on the safe side. Yes, most designs do include some sort of thermal margin of error but I personally would recommend against it. Again, not debating, just IMO...polkaudio RT35 Bookshelves
My fav way is stick an amp meter in series and load it until it smokes. Then you know the limits.:cheesygrin:Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
IMO, I would rather err on the safe side...polkaudio RT35 Bookshelves
But I only error intentionally.:twisted::cheesygrin: We can figure out how much power is available in the circuit and decide if more sink is needed. I've experienced thermal limits before they should have happened. Everything has a tolerance, some meet, some exceed, some don't get as close to meet.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Can you elaborate on this more? You've got me pondering which option to go with. Sound card coax out or dirty motherboard usb out? -
A DAC with a pulse transformer on it's SPDIF coax input will not have any direct connection to the PC (or other transport so) thus providing isolation from PC noise and potential ground loops.Toslink affords similar isolation as does the better USB implementations.
Unfortunately no pics of the single versions.(maybe on purpose?)I see some Dale resistors which are very good assuming they are not counterfits.Brock have you seen any user reports on these?SCompRacer wrote: »There are three they offer; Earth, Moon and Sun. I was incorrect, two are 28mA and one is 25mA each. Here is a pic of one.
I use the quick and dirty shorting the output method of inducing the magic smoke.SCompRacer wrote: »My fav way is stick an amp meter in series and load it until it smokes. Then you know the limits.:cheesygrin:
Maybe Brock has better pics of his but the one I seen in the pic's had no heatsinking on the transistors in the reg section.Adding some would likely be all he needs.SCompRacer wrote: »But I only error intentionally.:twisted::cheesygrin: We can figure out how much power is available in the circuit and decide if more sink is needed. -
Correct.So if I understand what you are saying a better receiving clock in an adaptive environment means nothing when the data is being transfered? It doesn't fix data stream issues from computers clock?
Though not possible with the integrated USB/DAC chips like the PCM 2702 there are some things that can be done further down stream such as the addition of a sample rate convertor like Benchmark and Bryston and some others do. -
I like your way better!:twisted::cheesygrin:Maybe Brock has better pics of his but the one I seen in the pic's had no heatsinking on the transistors in the reg section.Adding some would likely be all he needs.
I'm kind of behind and haven't kept up with his latest escapades, er, forades, into other gear.:cheesygrin:Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I think he's becoming a bit of a DAC ****.SCompRacer wrote: »I'm kind of behind and haven't kept up with his latest escapades, er, forades, into other gear.:cheesygrin:
He picks on me when he visits too. I think he used to do the 'start the lawnmower' motion when I started my Nottingham TT platter spinning.:cheesygrin:Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
As long as did'nt make fun of your dongle.
Maybe a little
SCompRacer wrote: »He picks on me when he visits too. I think he used to do the 'start the lawnmower' motion when I started my Nottingham TT platter spinning.:cheesygrin:
Was that wrong? :biggrin: Now I can do that to Rob since he has your Nottingham now.As long as did'nt make fun of your dongle.
Never make fun of a man's dongle :razz:
Good to know about the heat sinking.
Here is a large thread on Headfi about the op-amps
http://www.head-fi.org/t/397691/audio-gd-discrete-op-amps-reviewed-opa-earth-opa-moon-opa-sun-v-2"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
