just rcvd my Squeezebox Touch!
  • Drenis
    Drenis Posts: 2,871
    edited February 2012
    heiney9 wrote: »
    It's really the worst way to do it the way you are doing it as far as getting the best possible audio stream. How are you using the optical output if you are playing CD's in the disc drive? It's not possible, because it converts the music at the soundcard which means you are using the computer internals for the analog signal. Worst way possible. Now I'm beginning to understand why you were complaining about your rig sounding so bad.
    But wouldn't using say digital coax out from a sound card (something $150) bit streamed FLAC filed into a DAC work better then his method? Comparible to USB out when async is not an option?
    I've contemplated the above for my setup. Could still run USB...
    heiney9 Posts: 25,630
    Slightly better, the soundcard is the issue really as it's still tied to the nasty compute environment. I'd always opt for USB.
  • DMara
    DMara Posts: 1,434
    I prefer the SQB Touch/ Synology DS-1511+ NAS combination because I don't have to leave my noisy, wattage hungry PC on all the time as well as I love the convenience of controlling music via apps such as iPeng for iOS and Squeeze Commander for Android. The NAS box runs Logitech Media Server installed via a package provided by Synology; it is in my office room, far far away from any audio electronics, therefore my 2-channel room is as black as possible, no noise at all. NAS => Squeezebox Touch => Wyred 4 Sound DAC22 => Wyred 4 Sound STP/SE pre-amp => Wyred 4 Sound ST-1000 amp.
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • Serendipity
    Serendipity Posts: 6,975
    heiney9 wrote: »
    So the USB box must be external to the computer's case for best sound quality, due to the interference from the PC's electronics within the case? I've seen USB adapters that sit a short distance away from the PC and connect to an external DAC in several demos. I believe they work together as a pair.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • FTGV
    FTGV Posts: 3,650
    SCompRacer wrote: »
    IIRC the Audio GD discrete op amps pull ~ 26mA ...
    So about 52ma total draw as he only needs two.A quick look at a pic of the inards of his DAC seems to show it to have some sort of simple unheat sinked discrete reg for the opamps instead of the standard 3 pin variety .So not sure if it can handle the extra draw without generating too much heat in the devices.
    I'll put my sceptics hat on and ask $12 for a fully discrete opamp?I wonder about parts quality and the extent of transistor matching ,testing etc which usually translates into $.Just being discrete IMO does'nt necessarily mean it will outperform a good IC opamp, but then again at that price it would be worth trying.
  • FTGV
    FTGV Posts: 3,650
    heiney9 wrote: »
    ... the soundcard is the issue really as it's still tied to the nasty compute environment.
    Most DAC's will have a pulse transformer on their SPDIF input which like USB provides galvanic isolation.
  • Serendipity
    FTGV wrote: »
    In that case then the sound should be similar to having an external USB --> DAC dongle?
  • FTGV
    FTGV Posts: 3,650
    Dongle?
  • Serendipity
    Not sure of the exact name of it. Has USB connector on the computer's end and sits a short distance away from the PC. Pairs up with DAC.
  • FTGV
    FTGV Posts: 3,650
    USB -SPDIF convertor?Only needed if the DAC does'nt already have a dedicted USB input.
  • Serendipity
    I think it was something used to extract the bitstream directly from the computer. Salesman said it was necessary to play high-rez files.
    FTGV wrote: »
    I'm right there with you Fred. But the same op-amps are used the in the Audio GD dac I have (NFB 3) and it sounds pretty darn good. I was just thinking of doing some experimenting on the cheap, but the current draw was a concern.
  • FTGV
    FTGV Posts: 3,650
    Sorry the tone was a tad negative but they could also turn out be genuine sonic bargains.I might order a pair myself to try in my various DAC's.
    SCompRacer Posts: 9,271
    FTGV wrote: »
    So about 52ma total draw as he only needs two.....
    There are three they offer; Earth, Moon and Sun. I was incorrect, two are 28mA and one is 25mA each. Here is a pic of one.
    The page...
    http://www.audio-gd.com/Pro/diy/OPA/OPAEN.htm
    No problem with the tone Fred. I might pass until I can atleast get a schematic to see how the PS is laid out for the Keces. The current draw is significantly more than the stock Op-amps.
    FTGV wrote: »
    Dongle?
    I've used that term for folks that run a short piece of coax with BNC connector off the PCB of their SB Touch. (Not referring to the people, the cable).:cheesygrin: AKA security key. I'm gonna get brave one of these days and mod Brock's Touch with a BNC dongle.:razz: If I don't mess it up, mines next.
  • Serendipity
    I wouldn't do it if as you say the current draw is "significantly more" just to be on the safe side. Yes, most designs do include some sort of thermal margin of error but I personally would recommend against it. Again, not debating, just IMO...
    heiney9 wrote: »
    My fav way is stick an amp meter in series and load it until it smokes. Then you know the limits.:cheesygrin:
  • Serendipity
    IMO, I would rather err on the safe side...
    But I only error intentionally.:twisted::cheesygrin: We can figure out how much power is available in the circuit and decide if more sink is needed. I've experienced thermal limits before they should have happened. Everything has a tolerance, some meet, some exceed, some don't get as close to meet.
  • Drenis
    Drenis Posts: 2,871
    FTGV wrote: »
    Can you elaborate on this more? You've got me pondering which option to go with. Sound card coax out or dirty motherboard usb out?
  • FTGV
    FTGV Posts: 3,650
    A DAC with a pulse transformer on it's SPDIF coax input will not have any direct connection to the PC (or other transport so) thus providing isolation from PC noise and potential ground loops.Toslink affords similar isolation as does the better USB implementations.
  • FTGV
    FTGV Posts: 3,650
    SCompRacer wrote: »
    Unfortunately no pics of the single versions.(maybe on purpose?)I see some Dale resistors which are very good assuming they are not counterfits.Brock have you seen any user reports on these?
    SCompRacer wrote: »
    I use the quick and dirty shorting the output method of inducing the magic smoke.
    SCompRacer wrote: »
    Maybe Brock has better pics of his but the one I seen in the pic's had no heatsinking on the transistors in the reg section.Adding some would likely be all he needs.
  • FTGV
    FTGV Posts: 3,650
    heiney9 wrote: »
    So if I understand what you are saying a better receiving clock in an adaptive environment means nothing when the data is being transfered? It doesn't fix data stream issues from computers clock?
    Correct.
    Though not possible with the integrated USB/DAC chips like the PCM 2702 there are some things that can be done further down stream such as the addition of a sample rate convertor like Benchmark and Bryston and some others do.
    FTGV wrote: »
    I like your way better!:twisted::cheesygrin:
    I'm kind of behind and haven't kept up with his latest escapades, er, forades, into other gear.:cheesygrin:
  • FTGV
    FTGV Posts: 3,650
    SCompRacer wrote: »
    I think he's becoming a bit of a DAC ****.:smile:
    FTGV wrote: »
    He picks on me when he visits too. I think he used to do the 'start the lawnmower' motion when I started my Nottingham TT platter spinning.:cheesygrin:
  • FTGV
    FTGV Posts: 3,650
    As long as did'nt make fun of your dongle.
    FTGV wrote: »
    Maybe a little :lol:
    SCompRacer wrote: »
    Was that wrong? :biggrin: Now I can do that to Rob since he has your Nottingham now.
    FTGV wrote: »
    Never make fun of a man's dongle :razz:
    FTGV wrote: »
    Good to know about the heat sinking.
    Here is a large thread on Headfi about the op-amps
    http://www.head-fi.org/t/397691/audio-gd-discrete-op-amps-reviewed-opa-earth-opa-moon-opa-sun-v-2
