The AI-1 Dreadnought Project Pt.1
12357…12
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2012
    To be clear, it is the WIDE blade on SDA-2B blade/blade models (and of course wide is the only blade on pin/blade models) that is the ground leg.
    SDA-2B serial numbers BELOW 14115 for the LEFT channel, and BELOW 14124 for the RIGHT channel shipped from the factory with the blade NOT CONNECTED to ground.
    You need to manually connect the wide blade to ground for the SDA drivers to be energized with an AI-1 in place in those lower serial number cabinets.
    Also noteworthy is that factory polyswitches in the lower serial numbers were RDE050A .5 ohm, and then Polk switched to RDE090A .22 ohm polyswitches in the models where the blade was grounded. Coincidence or important? I don't know, but my belief is the ground leg of the interconnect was being accounted for.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Malbec
    Malbec Posts: 558
    edited January 2012
  • nspindel
    nspindel Posts: 5,343
    edited January 2012
    Nice! Thanks.
  • nspindel
    edited January 2012
    Ok, serial numbers verified on the 1C's and CRS+'s, I'm all set. Thanks for posting that.
    FYI, note of interest - When I get around to putting this together, I'm actually going to be using this with my Krell, which is a common ground amp. DK and I messaged about this quite a while back, and he seemed to thing that using the AI-1 could be beneficial even with a common ground amp. We'll see...
  • RickTfromAZ
    RickTfromAZ Posts: 122
    edited January 2012
    I ordered my enclosure from par-metal on 12/21. It was just shipped out yesterday. Two weeks exactly.
  • drumminman
    drumminman Posts: 3,396
    edited January 2012
    nspindel wrote: »
    I've thought about doing this too w/ my common ground amp. Interested in your observations when you get it finished and installed.
    Toolfan66 Posts: 18,410
    edited January 2012
    Building your own AI-1 makes a world of difference in sonic sound IMO, let alone it's a fun and easy project to build. I also believe building your own SDA cable with quality wire is the only way to go as well..
  • headrott
    headrott Posts: 5,496
    edited January 2012
    drumminman wrote: »
    Technically my Aragon 8008bb is common ground, but the impedence is about 20.5 ohms and is so high on the binding posts that it required me to use an AI-1. Otherwise I get the Aragon goes in and out of protection mode. Not exactly the same as using it with a common ground amp that does not have this problem, but I can say the AI-1 sounded infinitely better than strapping the negative binding posts. The soundstage, tone and even (by ear) dB level increased by using the AI-1 rather than strapping the amp.
    Greg
  • Schurkey
    Schurkey Posts: 2,125
    edited January 2012
    headrott wrote: »
    Greg
    I'm jealous. I can't use the AI-1 with my 1Bs, so I've jumpered my 8008BB...but then I never had it go into protection mode without the jumper, either. Just sounded terrible (distorted in the midrange) at any volume level--but no popping, shut-down, stray hums, etc.
    If it sounds better with the AI-1 rather than a jumper wire...I don't understand why. I'm very curious.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited January 2012
    If you are going to orient the case resting on its bottom, the retaining bolt, top plate and rubber pads are adequate. If you are going to orient the case resting on its side, then a center piece or some external brace similar to what is shown in post #33 of this thread would be a good idea.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited January 2012
    I bought a used AI-1 someone had built here at CP a couple of years ago. At the time, I thought about buying a used Aragon 8008BB amp because I had heard a lot of good things about them. Doing more research on the amp,I contacted Rick Santiago over at Indy Audio Labs to find out if theAragon amp was common ground and could be used with my Polk SDA/SRS 2's.Got the same info headrott mentioned above so I decided not to buy an Aragon. Went with a Parasound 1200 mkII ,which is definitely a common ground amp:) Now I'm curious about trying the used AI-1 with the Parasound to see if it sounds any better than the stock interconnect.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited January 2012
    This is a solution to house the Avel transformer I came up with in mid 2008 to match my SDA2BTL's. I painted my 2B's end caps black so I made this black oak box to house the transformer. In early 2009 I cut some scrap 20 oz roofing copper to shield the transformer after the potato thread of the time. Since then it has basically been out of site out of mind for me.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • PolkMaster1
    PolkMaster1 Posts: 847
    edited January 2012
    Replacing the stock interconnect with binding posts and a heavy guage speakerwire (say 12 guage or higher) with spades will expand the soundstage over and beyond the stock interconnect. I hope to receive my AI case soon to start building the dreadnought and take the soundstage even further.
    Make sure to use quality speakerwire to get the best results.
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
  • PolkMaster1
    edited January 2012
    MLS - very nice work indeed!!! I hope you are enjoying the results!!!
  • drumminman
    edited January 2012
    Very nice! I thought about making my own box as well. Where did you get the copper roofing material from?
  • PolkMaster1
    edited January 2012
    Lasareath wrote: »
    I'l be using MIT Shotgun S1 Bi wired speaker cables with my 1.2tl's
    Nice cables. I am not certian yet whether to use my own custom cables or use something less expensive - like MIT Shotgun Cables. :cheesygrin:
  • PolkMaster1
    edited January 2012
    drumminman wrote: »
    I too would be interested in the copper roofing material. Could aluminum be used as a cheaper substitute, or are the properties of aluminum covering inhibit the effectiveness of shielding compared to copper material?
  • PolkMaster1
    edited January 2012
    Sal -
    Very nice work!!! I placed the order for my enclosure over the weekend and hope to have it as quickly as you did. My transformer arrived 14 months ago. I was entangled in a "small delay" on purchasing the enclosure at that time. :cheesygrin: I hope my enclosure project comes as close as yours in the results department.
    Will you be using any feet on the enclosure? If so, where are you getting the feet from?
  • PolkMaster1
    edited January 2012
    Lasareath wrote: »
    I want to use spikes and I think I'm going to use 3 in a triangular pattern. two in the front and one in the back.
    Where do you plan to get the spikes from? And what binding posts do you plan to use?
    EndersShadow Posts: 17,753
    edited January 2012
    Lasareath wrote: »
    It's just too hard to pass up........
    That's what she said :smile:
  • drumminman
    edited January 2012
    Hey Lasareath,
    What power amps will you be using with your new Dreadnought? Common ground or not?
    Nice work BTW.
  • DarqueKnight
    edited January 2012
    Lasareath wrote: »
    I think I want to use copper a well. Where can I find it?
    Aluminum is 40% less conductive than copper and is 9% less conductive than gold. Aluminum has the advantage that its conductivity to weight ratio (specific conductivity) is twice that of copper.
    An aluminum wire with the same conductivity, or current capacity, as a copper wire will be 40% larger, but will have half the weight and lower cost. Aluminum typically costs 7% to 100% less than copper depending on market conditions and the application requirements. That is why aluminum is widely used for electric transmission lines, transformers and electronic gear cases that must have shielding properties.
  • drumminman
    edited January 2012
    Lasareath wrote: »
    Thanks.
    Musical Fidelity Tri-Vista 300. It's a dual mono design on one chassis.
    Would I be correct in assuming it's common ground?
    F1nut Posts: 52,377
    edited January 2012
    It's two.
    It is not common ground.
  • PolkMaster1
    edited January 2012
    Sal -
    I am thinking of using handles for my Dreadnought. Assuming you got the handles from Par-Metal, what is the part number?
    Thanks.
  • PolkMaster1
    edited January 2012
    Not to hijack this thread, but -
    Recently I replaced the stock interconnect cable with binding posts and a custom made speaker cable. All I can say is WOW!!! WHAT A DIFFERENCE!!!! I notice a HUGE improvement in the SDA effect over the stock cable. I would go as far as to say that the SDA 3D effect is on steroids!!! Its really like being there - the SDA effect feels like a full 360 degrees.
    I do admit that the sample set is small at the moment as I am using Blu-Ray movies as the source of playback. But damn it is good!!!
    I am going through with the dreadnought project though, so this question is for Darque Knight as well as others who may have went down this path. What improvement should I expect going from the custom binding post-custom cable solution to the dreadnought?
    Thanks all.
    PM1
  • DarqueKnight
    edited January 2012
    Something like this would work well:
    Thermally Conductive Epoxy Potting Compound
    It is available from Mouser:
    MG Chemicals 832TC-450ML
    edited January 2012
    I built 6 chassis's this last week, I am keeping 2 of them, they are built out of aluminum with all mounting holes for the binding post's, feet or spikes as well as the hole to mount the transformer, they are powder coated black and the face plates are at the plater for black anodize.
    The one I built about a year ago was built out of steel and has worked just fine but I will be interested to see if the aluminum will make a difference. Pics to come later today.:smile:
    edited January 2012
    edited January 2012
