My emotiva amp wont fit my mit bananas
polkfarmboy
polkfarmboy Posts: 5,703
edited July 2011 in The Clubhouse
After buying a ML stage center and deciding the receiver wont power it proper I decided to hook up my emotiva up5 channel .Well none of the terminals bar 1 accept my MIT banana's and it seems like the holes are defected and I snapped my speaker wire trying to fore it in .During the process one of the binding posts just came right off the amp ? I swear it was if it was made of cardboard the way it just crumbled .I have never even used this amp longer than 4 hours since I bought it and previously had it hooked up with bare wire
Post edited by polkfarmboy on
«13
    heiney9 Posts: 25,496
    edited July 2011
    Another reason NOT to buy Emo :biggrin:
  • polkfarmboy
    edited July 2011
    heiney9 wrote: »
    Well I just got off the phone with emo (nice guys) but no soluotion given and they close in 7 minutes so I gotta call back tommorow to speak with a tech to find a solution .The rep told me to use spades because bananas dont really enhance performance and its just for ease of use ? I said thats gona cost me an extra $125 dollars but he then said he would send me some spades but mit spades only work with mit cables
    The rep told me this has never happened one time but its happening to me right now .Only 3 terminals fit a banana plug and the rest wont even let me put the bananas in just a little .
  • halo71
    halo71 Posts: 4,637
    edited July 2011
    heiney9 wrote: »
    Be careful, don't fall off your mighty horse now! :wink::biggrin:
    --Gary--
    Toolfan66 Posts: 18,167
    edited July 2011
    Emotiva has great customer service, and I'm sure they will take care of you.
  • polkfarmboy
    edited July 2011
    Hopefully thats what they will do tomorrow when I call back but I get the feeling its gona cost me about $60 shipping. Its kinda sucky because I dont really see it as a user fault and more of a bad QC control issue but I shall wait patiently and find out everything tomorrow
  • BlueFox
    BlueFox Posts: 15,250
    edited July 2011
    My MIT speaker cables came with both spades and bannanas.
  • polkfarmboy
    edited July 2011
    BlueFox wrote: »
    I bought the cheapo ones on offer :smile:
  • stuwee
    stuwee Posts: 1,508
    edited July 2011
    I'm curious, why did you force it? I've snapped plugs being careful with big unweilding wires with the 'Death Grip', aren't you the dude asking about red/white which is right??
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • polkfarmboy
    edited July 2011
    stuwee wrote: »
    Yep I was just asking about L/R rca then this happened :biggrin:
    But to be fair I was not forcing it too hard I was just being firm and I am not the type of guy with a strong handshake .Nearly every connection wont accept the banana plugs, its like they are all too small and I even try'd various bananas but with no luck
  • stuwee
    stuwee Posts: 1,508
    edited July 2011
    Ah, big bummer then, I hate that!
  • DMara
    DMara Posts: 1,434
    edited July 2011
    That's strange. Both of my old XPA-5 & XPA-2 accepted all kinds of banana plug with no problem.
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
    edited July 2011
    I hate to be an ****, but I have to ask, what part of the post did you try pushing the banana into ?
    I only ask because I don't think I ever heard of someone snapping a post on an amp. Stripping a post,sure, bending a post...yep, but not snapping it off from trying to connect a banana plug.
    Since you previously had a bare wire connection, you obviously saw the hole on the post of the amp, tell me for my own satisfaction that you didn't try pushing a banana plug into that hole on the post. I know I'm making a stretch of an assumption here, but just trying to figure out how you did this in my own mind.
    If I'm wrong,then I apologize in advance.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited July 2011
    I'm trying understand how this happened too. Can you post some pics for us?
  • sucks2beme
    sucks2beme Posts: 5,691
    edited July 2011
    I've had some tight RCA connections with locking
    RCA connections. But bananas? Loose, but never too tight
    to seat. Something really wrong there. I take it no problems
    using the nanners with your receiver? Sounds like the posts
    provided by EMO were maybe of lesser Chinese specs?
  • cstmar01
    cstmar01 Posts: 4,424
    edited July 2011
    I've used MIT exp on emo amps before and never had an issue
    F1nut Posts: 51,970
    edited July 2011
    tonyb wrote: »
    Got me a fiddy on that one.
  • marvda1
    marvda1 Posts: 4,962
    edited July 2011
    does emo use those plastic plugs on their binding posts for european sales that you have to remove before you insert banana plugs? its there because their electrical plugs look like banana plugs.
    Puritan PSM156
  • polkfarmboy
    edited July 2011
    Polkie2009 wrote: »
    I will do just that, I will have to get my camera
    To answer the rest of your questions I do know where to put a banana plug and yes I have used the MIT's for quite some time now on other speakers and both receivers that I have. I used them on the tube amp and have never encountered a single prob until now . Like I said previously, I'm a little fellow with skinny fingers so I never muscled this plug in and I cant even get these naners to go in the rest of the binding posts .It seems like all the holes are too small. I bought this amp brand spanking and its just sat under the rack for months
    When I first bought this I used mono price bare wire just to make sure the product was in tip top .After getting the full martin logan rig finished I decided to watch source code and fire up the amp in some 2 channel spotify before hand and this happened :eek:
  • polkfarmboy
    edited July 2011
    The snapped binding post pic file is too large but here is the amp
  • halo71
    halo71 Posts: 4,637
    edited July 2011
    Why did you put it in from the side? Did you put the other one in from the side when it broke? Damn dude....lol
    --Gary--
  • Polkie2009
    edited July 2011
    Wow man, really sorry to see that on a brand new amp. I can imagine how disappointed you are. hopefully Emotiva will ship you out a new one.
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited July 2011
    halo71 wrote: »
    He's using the missionary position.
  • polkfarmboy
    edited July 2011
    Polkie2009 wrote: »
    I think the upa is a discontinued model so I dont really know how thats going to work out ? I try'd to join the emotiva forum tonight and ask around there but it wont let me in until some one over there approves the membership
  • halo71
    halo71 Posts: 4,637
    edited July 2011
    "EmoStyle"? :tongue:
    PFB....you seem to be ignoring the direct questions of what you did to break your amp. Good luck getting it fixed though.
    --Gary--
  • polkfarmboy
    edited July 2011
    Here's the binding post on my table instead of stuck firmly to the back of the amp
    Right now I'm fighting it to get my banana plug back
  • polkfarmboy
    edited July 2011
    halo71 wrote: »
    Sorry I thought I answered the question . What I did was put my banana plug into the back of the amp and it snapped right off
  • polkfarmboy
    edited July 2011
    halo71 wrote: »
    I had to unscrew the banana plug and put the pin into the side of the binding post .Only 3 of the 10 binding posts will accept the banana termination and every other hole is too tight . I really needed to take some of the load of the receiver so I had to hook it up like the pic in the previous post
  • pearsall001
    pearsall001 Posts: 5,325
    edited July 2011
    Do yourself a favor & ditch the MIT's!
  • stuwee
    stuwee Posts: 1,508
    edited July 2011
    Are the amp posts on those Emo's cast pieces? If so that looks like a stress fracture to me, like the metals used weren't cast properly, there could be others defective like that out there :eek:
    I hope the company comes through for ya PFB, I'm sure they will. So that banana plug is still in that post? You might want to think about leaving it there until you hear back from Emotiva, they might need to see it like that for various reasons. Just a thought.
  • polkfarmboy
    edited July 2011
    I know they might but at the same time its needed in my rig because I dont have any other secure terminations for the MIT's
    I dont think I will be ditching the MIT's pearsal as I kinda like having them for listening to audio but thanks for the suggestion
