SDA Custom Circuit Boards
135
  • schwarcw
    schwarcw Posts: 7,358
    edited May 2011
    My boards arrived today safe and sound. They are beautiful! Nice and thick, quality is clearly evident. Thanks so much!
    Carl
  • gimpod
    gimpod Posts: 1,793
    edited May 2011
    Come on guys get them while there hot. (Shameless plug :redface:)
    And Thanks to all you guys who have purchased. :smile:
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited May 2011
    gimpod wrote: »
    Any Mother's Day discounts going on? :smile:
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited May 2011
    If anything, he should jack the price up considering the effort put into and the quality of these boards. Like they say, "Try and find another one."
  • audiocr381ve
    edited May 2011
    Agreed.
    nooshinjohn Posts: 25,890
    edited May 2011
    +10000000
    Now I need to get off my lazy **** and put them to good use.:redface::tongue:
  • Janne
    Janne Posts: 139
    edited May 2011
    Put up some pics of your installations. When I look at my old board with the twisted, piggy backed, bended, squeezed components. I just wonder that it still worked. :eek: The new boards are so nice to work with. Even the soldering looks nicer. :biggrin:: One done last night. One more to go. Once again BIG Thanks to Tony!!!
    HT/2 CH
    McIntosh MX120, MC500, MC206, MEN220
    polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
    MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect.
  • c0redumpt
    c0redumpt Posts: 35
    edited May 2011
    Thanks Tony, the boards arrived safe and sound down here in Aus!! :)
    Now to start procuring all the other bits
  • gimpod
    gimpod Posts: 1,793
    edited May 2011
    c0redumpt Glad to hear that, I always worry about shipping overseas.
    !! BIG NOTICE !!
    I will be going on vacation (kinda:frown:) for at least 2 weeks on the 25th. So if your sitting on the fence now would be a good time to jump on these.
  • mopar paul
    mopar paul Posts: 277
    edited May 2011
    Just sent you a pm on a set, just let me know where to send the money!
  • gimpod
    gimpod Posts: 1,793
    edited May 2011
    ^ Replied via PM and thank you.
  • vmaxer
    vmaxer Posts: 5,120
    edited May 2011
    Well, I have been away from the forum for a while, work is crazy busy and kept me away. Thanks for the PM gimpod, I just sent the money for 2 pair, one for my 1C's and 1 for my 1.2TL's.:biggrin:
    I assume you will be over to install them soon..:eek::wink:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • gimpod
    gimpod Posts: 1,793
    edited May 2011
    vmaxer wrote: »
    Not unless you want to send me a 3000+ mile extension cord and a heavy jacket :wink::wink: Wrapped, Packed and going out in the morning.
  • vmaxer
    vmaxer Posts: 5,120
    edited May 2011
    gimpod wrote: »
    Man, that is very quick service!! Many thanks:biggrin:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • gimpod
    gimpod Posts: 1,793
    edited May 2011
    Your welcome vmaxer.
  • gimpod
    gimpod Posts: 1,793
    edited May 2011
    All sales will end Sunday until I get back in 2 weeks (I Hope)
  • vmaxer
    vmaxer Posts: 5,120
    edited May 2011
    gimpod wrote: »
    I got mine the other day, they look great!! Now I have Larry's rings and the new boards to install, may be a while but I will get it done.
    Thanks a kot!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • gimpod
    gimpod Posts: 1,793
    edited June 2011
    A Refresher if you will.
    These boards were designed to use bigger Caps & Resistors like Sonicap & Mills and work for the following SDA's with a single board crossover and a Pin/Blade IC cable.
    SDA 2B (1987 Blade/Blade IC with single board crossover)
    SDA 2B/CRS+ (Pin/Blade IC)
    SDA 1C
    SDA SRS 2 (1987 Pin/Blade IC with single board crossover)
    SDA SRS 3.1TL
    SDA SRS 2.3
    SDA SRS 2.3TL
    SDA SRS 1.2
    SDA SRS 1.2TL
    Now there are somethings you need to be aware of.
    First: Mounting (This only affects the SDA SRS 1.2/TL and the CRS+).
    Because of the size of the new boards (10" x 5 1/4" vs 5 3/4" x 4 1/4") the only place I can think of to mount them in the CRS+'s is on the bottom of the enclosure and extend the leads (P & R) up to the big 16mH inductor. Now that brings us to the SDA SRS 1.2's, I might suggest that you could mount the board on the crossover plate plug everything in and then slide the top in at an angle then move the whole assembly up so you can slip the bottom in and then bolt in place (it should be able to fit through the cabinet opening measuring 4-3/4" high by 14-3/16" wide) and if that doesn't work you could mount the bare crossover plate first then slide the assembled crossover through the hole for the PR and then bolt in place.
    Second: Let me ensure you that these boards are electrically identical to the originals with two exceptions, there is no place for the 750pF Silver Mica bypass cap(C4) for C3 it's not needed with the newer/better cap's you can buy today and nobody uses it anyway also I added a jumper (J4) for the Non-TL 2.3's & 1.2's to make things a little easier.
    Ordering & Shipping:
    1. Cost $100.00 a Pair including shipping and PayPal fees.
    2. These boards will be for Club Polk members ONLY!.
    3. Payment will be by PayPal (NOT as a gift please) or USPS money order.
    4. Shipping will be by USPS Priority Mail.
    5. Just PM me your order and we'll go from there. Also once you put solder to these THEY ARE YOURS
    If you want more info about the boards, schematics and what parts you'll need go check out www.gimpod.com.
    Thank You ~ gimpod
  • gimpod
    gimpod Posts: 1,793
    edited June 2011
    !! Sorry guys but all board sales are on hold until further notice !!
    Everybody's orders have shipped.
    Sorry guy's ~ gimpod
    Toolfan66 Posts: 17,995
    edited July 2011
    Question??? I am working on my CRS+ speakers (I know it's been awhile) any ways I was wondering about the 40uf cap, putting it on the board with two 20uf's would this not be putting them in a chain?? would it not be better to piggy back them?? or am I just over thinking this??
  • gimpod
    gimpod Posts: 1,793
    edited July 2011
    I take it you mean replacing the 40uF Cap with two 20uF Cap's, It's ether a single 40uF Cap or two 20uF Cap's in parallel not both . If your using the stock boards boards yes you need to piggy back them, If your using my boards just put one 20uF Cap in the C2-A position and one 20uF Cap in the C2-B position the piggy backing is done within the board its self, also if your using one 40uF Cap instead of two 20uF Caps you would put the 40uF Cap in the C2-A or the C2-B position and leave the other one blank (i.e, 40uF at C2-A leave C2-B blank).
    Hope this helps.
    Also these boards will be going back up for sale just as soon as I get the shipping supply's I ordered.
    edited July 2011
    I am finding that someone using these boards in the CRS+'s will have to mount the crossover board somewhere else in the cabinet,you will not be able to mount it to the 16mh inductor like it was. Not a big deal to me as I will mount it to the bottom of the cabinet.
    I am taking a set of CRS's (1986) and converting them to a CRS+ (1990) 4.1tl
    I am taking pictures and I will post a full thread when completed.
    Gimpods Boards
    Cardas binding posts
    Sonicaps
    Dueland 2.7 resistors
    My rings (including a ring for the binding post cup)
    and of course the custom stands I built for them..
    I found a set of crossovers on ebay for the 2B's/CRS+'s a few months ago,gutting them for the inductors.
    More later,Thanks again Tony!!!
    edited July 2011
    Tony did you just fly out here??? Dude that was fast!!!
    Thanks,
    Larry.
  • gimpod
    gimpod Posts: 1,793
    edited July 2011
    Boards are back up for sale
    Check post #80 for details
    Thanks,
    Larry.
    Your Welcome, Actually I have a buddy who owns a SR-71 who flew them out just for you. And if you believe that one I've got a REALLY REALLY nice Space Needle I'd like to sell you only $10 million + Shipping & Handling
  • nspindel
    nspindel Posts: 5,343
    edited July 2011
    Larry - I was thinking when I was doing my 1C's that a ring for the binding post cup would have been cool. Got any of those floating around? Sorry for crapping your thread, Tony, but Larry started it :)
  • gimpod
    gimpod Posts: 1,793
    edited July 2011
    nspindel No problem your cool.:wink:
    See post #80 for details.
  • gimpod
    gimpod Posts: 1,793
    edited August 2011
    SDA 1C
    SDA SRS 3.1TL
    SDA SRS 2.3
    SDA SRS 2.3TL
    SDA SRS 1.2
    SDA SRS 1.2TL
    Shameless plug alert.
    Some quotes from those who have bought:
    dorokusai wrote: »
    gimpod(Anthony) sent me a pair of boards for the SDA CRS+ to check out....evaluate I guess and I have to say without question, he's doing outstanding work. The boards are setup very nicely and clearly have had a lot of thought and preparation put into them. The actual traces appear to be well done, since they are sealed properly and the labels are crisp and easy to read.
    This is a must do upgrade for anyone serious about bringing their vintage Polk loudspeakers to the next level. This opinion is not a company endorsement, just one from someone who knows a lot about Polk Audio and I've been involved behind the scenes for many years. Coupled with the well documented posts from our active, crazy about all things Polk, users....I think you get the idea.
    A+
    Mark
    Polk Audio
    got mine the other day--- wow--just wow--anyone owning SDA's should seriously consider these. These boards take all of the "voodoo" out of crossover upgrades,,especially for the first timers,,a must have, even if it's just for the investment alone.Thank you for making these available to the community--guys,, I just cannot stop raving about these boards--get some !!!!
    schwarcw wrote: »
    Folks,
    These boards are of the highest quality and make SDA crossover modifications easy. Especially for the big SDAs. If you are planning to do an upgrade someday, or hope to have a nice pair of SDAs someday. BUY THESE NOW! After these are gone, in a few years these will sell for big money. Look at the prices for the A1-1 cable, crazy money. Get your now!
    mopar paul wrote: »
    Got mine today. What a work of art. If you guys are ever gonna mod your crossovers (which you should!) get these boards-they are an absolute work of art!
    Paul
    How about an annoying perfectionist that simply cannot leave well enough alone?:tongue:
    These boards are just that my friend, simply perfect. Your efforts to make them of a quality that rivals the original manufacturer shows in every way. It cannot be said enough... Well Done!:cool:
    On3s&Z3r0s wrote: »
    Just thought I'd post up a couple of pics of what the boards look like after assembly for 2B TLs. The boards themselves are a godsend (if Tony isn't a Polk God, he's at least the Pope of Polk :wink:), but the website (gimpod.com) just takes all the guesswork out of it. The parts placement flyover graphic is cool, but the schematics go way above and beyond in calling out parts placement as well. So, when all is said and done, here's what they look like. Please don't tell me if I installed my caps backwards... too late to turn back now. :biggrin:
  • gimpod
    gimpod Posts: 1,793
    edited August 2011
    Come get them before they end up in the back of my closet only to be found by some archaeologist in 10,000 years.
  • chandler9a
    chandler9a Posts: 878
    edited September 2011
    Sent ya a pm gimpod, Let me know if I can get some for the SDA 1.2TL's
    thanks!
  • gimpod
    gimpod Posts: 1,793
    Yes you can, Replied via PM.
