MIT Exp 2 Results
135
    Toolfan66 Posts: 18,036
    edited April 2011
    I am hoping for a nice improvement from my crappy homemade cables and cant wait to get my hands on them . Does the bananas you see in the add come bundled with them ?
    I'm kinda getting tired of childish behaviour and un-opinioned thread de-railing .
    One thing we all have PFB and that's the choice to not read it or be part of it.. You have the power to leave and or stay but it is a public forum and not everybody is going to see eye to eye or have a perfect day!!
    Best regards,
    Larry.
  • jinjuku
    jinjuku Posts: 1,523
    edited April 2011
    Yes they do along with the connector boots. Slide the boots on over the connector, slip them all the way up, screw the connector onto the leads and slide the boots down.
  • PolkClyde
    PolkClyde Posts: 662
    edited April 2011
    My question is about the burn in of the cables being around the 200 hours mark.
    Is there a certain volume you have to put through them .Can I leave music on really low when I go to work and still give them the proper burn in ?
    I'm not the one to ask either,but I Played(and still do) Loud when I go to work.I leave it on,with a burn in CD Playing... NO,WAF HERE.
    PolkAudioClyde
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited April 2011
    What would be a good burn in cd ?
    Is there any upgrades one can buy to replace the stock banana plugs ?
  • PolkClyde
    edited April 2011
    What I used, is The Sheffield/XLO Test & Burn-in CD... Don't know anything about stock banana plugs.
    PolkAudioClyde
  • jinjuku
    edited April 2011
    The stock bananas are quality electroplate, spring loaded. You should be fine.
    The only way to replace them is to re-terminate the cable.
    nooshinjohn Posts: 25,910
    edited April 2011
    Just received my cables, and I must say that I would not have paid full retail for them based on their appearance. Underwhelming to say the least... very similar to my Canare wires in this regard. For the money spent however (75 bucks/20 footers) they look to be a good value. I will be plugging them in tonight when I get home from work.
  • polkfarmboy
    edited April 2011
    I wish they had the option to come with spades and bananas .I took a sick day so as soon as it hits 12 pm i'm going to crank the flock out of my system and hopefully get a knock on the door from ups
  • cstmar01
    cstmar01 Posts: 4,424
    edited April 2011
    you can buy spades for the cables if you need them. Thats the nice part of using the ICONN system. It will run you about 30 bucks or so for 4 of them from a dealer normally.
  • polkfarmboy
    edited April 2011
    Well my cables arrived and I am excited to give them a try
    I was not expecting much from these as far as appearances went but when I opened the very heavy box I was very surprised to see a quality made cable .I cant seem to find what the defect was ?
    I was amazed how big the 40 foot cables were and I put them in the pic posted to show compared to a 10 ft
    edited April 2011
    Agreed PFB... the cables are very well made, but the runs you and I have would have been $300 bucks plus and for that kind of coin at retail, there are other well made cables that are much nicer in terms of looks. But it is not about looks as it is the sound that counts.
    Anyone know where I can get the nylon tube coverings for these? I want to combine two sets for bi-amping to the SDA's.
  • B Run
    B Run Posts: 1,888
    edited April 2011
    Check the arrows, they should be facing the wrong way. Other than that they should be perfect and still labeled "amp" and "speaker".
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited April 2011
    Thanks for the pics, they look pretty nice and the price was good:)
    edited April 2011
    I have replaced the Monster Cable in my two channel setup with the MIT's and letting them burn in a bit tonight before I get some time in the sweetspot.
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited April 2011
    Man, mine are supposed to be delivered today, but it's 7 and I am getting sick of waiting here just to sign for them. I dunno what's worse, going shopping and missing them, or waiting here only to find out they aren't actually coming.
    edited April 2011
    mine were delivered no sig required....
  • cokewithvanilla
    edited April 2011
    edited April 2011
    guess you should wait then:eek::tongue:
  • B Run
    B Run Posts: 1,888
    edited April 2011
    Mine say sig required too, i'm not excited about that but we'll see. They don't come until tuesday so i'm living vicariously through everyone elses posts and pics.
  • jinjuku
    edited April 2011
    I had to sign for mine
    edited April 2011
    jinjuku wrote: »
    What color crayola did you use?:tongue::biggrin:
  • cokewithvanilla
    edited April 2011
    well, you were right. They just arrived.
    Okay, am I the only one who had difficulty with those plastic cover things? I only installed two because it was so hard to slip them on.... is there a trick to this?
    Anyhow, got them hooked up... no noticeable difference, but I've never used banana plugs, so that was mad convenient compared to my bare wire.
    At least now that I have these I don't have to worry that my sound is being destroyed by my cheapo wire.
    edit: man, just signed a few minutes ago and tracking is already updated online... that's fairly impressive
  • mrbiron
    mrbiron Posts: 5,721
    edited April 2011
    Ups tried to deliver at 9 this morning....who the hell is home at 9?! jack@sses
  • jinjuku
    edited April 2011
    Slip the boots on over the banana, push it up till you see the bottom of the plug and screw on. Simply pull the boot down.
  • jinjuku
    edited April 2011
    Since it was UPS: Brown.
  • cokewithvanilla
    edited April 2011
    mrbiron wrote: »
    don't you mean who's awake at 9? :tongue:
    jinjuku wrote: »
    I managed to find nothing simple about this process lol...I'll try again :)
    edited April 2011
    Mine went on real easy, but they sat in the hot car all day:tongue:
    Initial listening impressions using my Maggies, Sunfire Tube Pre, Carver Silver 7t's and my Yamaha turntable show a nice improvement over the Monster Cable Ultraflat wire that were replaced. The soundstage is more natural in depth and width. Voices are clearer than before and there is a touch more bass from the little Maggies. I am pleased with the purchase, and for two channel listening, I can say that yes... cables matter. I must admit to being a bit more skeptical of the need for high end cables for HT use, and probably will not go further than this into cables for home theater use. For my two channel rig however... well lets just say that is another rabbit hole entirely.
  • polkfarmboy
    edited April 2011
    There is a method to attach the plastic. First you should put the small side on then screw on the banana plugs .
    tonyb Posts: 33,072
    edited April 2011
    Whew....If you had intended on using those monster cables with those nice tube amps your building, I would spend the gas money to come down there and slap you upside the head.:biggrin:
  • nspindel
    nspindel Posts: 5,343
    edited April 2011
    Mine arrived today, but no time to try them out until next week.
