How many listen to 2 channel music with their sub on?
gfong
gfong Posts: 1,079
edited March 2011 in Speakers
Curious as to how many of you listen to music with your sub woofer on when listening to cd's, records or tapes? 2.1 setup
I am not asking about Blu-Ray music discs or any other mulit-channel format!
When listening to cd's or records I have the sub off.
What are some of your reasons that we would use a sub with 2 front speakers?
Post edited by gfong on
«13456
  • Pycroft
    Pycroft Posts: 1,961
    edited March 2011
    I do not listen to my 2 channel with a subwoofer, mainly because I feel my speakers do a great job producing accurate and deep bass sound, so I do not need a subwoofer. I'm guessing if I had a great pair of bookshelf speakers, or floorstander's that did not produce a good low frequency sound, I would want a subwoofer to fill in the blanks.
    James
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
    tonyb Posts: 33,072
    edited March 2011
    I would imagine most do, mainly because most don't have true full range fronts that can dig low enough.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited March 2011
    Yes, but purely in a supporting role. It's not overpowering in any way, just used below 40hz to handle the exceedingly low energy.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • grimmace19
    grimmace19 Posts: 1,429
    edited March 2011
    I use mine because even though the lsi15s can hit somewhat low there is no replacement for my fathom f112
  • coolsax
    coolsax Posts: 1,826
    edited March 2011
    i said no, but that's because currently I don't run a sub with my 2 channel system.. one of these day's I'd like to.. probably a micropro 1000 or 2000..
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited March 2011
    I run bookshelves so I use a sub to fill out the bottom end, but the gain is pulled waaaay back as I'm not a basshead and don't want that to be the primary focus of the musical experience.
  • quadzilla
    quadzilla Posts: 1,543
    edited March 2011
    I've got monster floor standers in the multi-channel rig and CRS+ for 2 channel. Neither needs the subs for strictly 2 channel, but I do listen to some muti-channel music and other than going into the AVR and setting sub to no, there's no way not to have the subs on. And on multi-channel, it sounds fine like that. 2 channel, not so much. Never could get everything to really blend in completely right with the fronts set to small. Bass sounds much better with them off, and they dig plenty deep for any type of music.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • PrazVT
    PrazVT Posts: 1,607
    edited March 2011
    I play music in 2 ch pure direct w/ my RTi A7s. They dig plenty low too.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
    EndersShadow Posts: 17,704
    edited March 2011
    I put yes because normally I do most of my listening by streaming Pandora through my blu-ray player on my main rig, or through my Xbox 360 and Windows Media Player. The Integra sets itself to stereo which adds in the sub. With my Monitor 60's crossed at 60 and powered by an external amp it sounds good to me.
    I tried setting it all to direct but it was quite obvious that I needed the sub to fill in the low end, especially due to the size of the room and that its open to the adjacent dining room.
    My office rig will be getting a sub eventually because I am using bookshelves, but I dont do enough listening there yet to justify the cost and would rather put the money in my main rig downstairs.
    Toolfan66 Posts: 18,039
    edited March 2011
  • dfledezma
    dfledezma Posts: 148
    edited March 2011
    Depends on the situation. When I listen acoustic guitar, or vocals mainly I prefer to rely only on the main speakers. For rock I feel a bit of punch is needed so I turn the sub on but without exaggerating the output.
    In my office and rom rigs is strictly 2 ch and I feel fine with that.
  • BlueFox
    BlueFox Posts: 15,251
    edited March 2011
    Obviously, if you have a sub in the system then you are not pure 2 channel, but letting the AVR filter the signal in some manner. Of course if you have the sub wired via the speaker cables going to the sub first, and then going to the speaker, that is different, but I doubt if many use that method.
    I do not have a sub in the two channel system. In the HT/multi-channel system I rarely turn the sub on for movies, and never for music.
  • jbooker82
    jbooker82 Posts: 1,627
    edited March 2011
    Yes because I dont have an amp to drive my RTI A7's. If I had a 300 x 2 amp then it might be a different story.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Erik Tracy
    edited March 2011
    BlueFox wrote: »
    I run a hybrid setup for HT and music with the sub connected to my AVR via the LFE input, but at the same time to my Integrated Amp (with HT bypass) from the L/R preouts to the sub's Line level inputs.
    So for music - no AVR, no filtering, so technically one could argue it isn't a 2.1 cuz the bass is not synthesized as a separate 'channel'.
    I found this to be better for music - I'm not a big fan of letting AVRs do 2-channel music to the level that a dedicated configuration can.
    It hasn't been easy to integrate the sub for music - I'll admit that, but I've found a very 'happy place'...for the moment. :wink:
  • thesurfer
    thesurfer Posts: 574
    edited March 2011
    No, subs hit the scene mainly for HT, if you are trying to recreate the live experiance useing a sub, its nothing what a live concert sounds like,,, also, most rock music does not go that low,,, off course, if your really into that added thump, and wallop, effect than it might be your cup of tea,, Back in the day, i used Cerwin Vegas for that type of thing, I dont even think they had Subs back then.
    Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited March 2011
    Wow... kinda surprised at how many people do use their sub. I have my HT receiver configured to use the sub for 2-channel also for a few reasons. Mainly, if it wasn't set up that way the sub was being left out of any stereo signal, so even the stereo audio from old DVDs or TV was not using the sub. The fronts are set to Large and the sub set to Plus/Double Bass, so the receiver isn't restricting any part of the signal for the fronts. They get the full meal deal and the sub gets the low frequencies. The sub rounds out the low bass nicely on the M70's, and I can always turn it down/off at the sub more easily than mucking with the receiver settings if I don't like it on certain 2-channel music.
    In my dedicated 2-channel system I don't have a sub.
  • slammin86
    slammin86 Posts: 238
    edited March 2011
    Sometime I do, others I do not. Since I put an external amp on my monitor 70's the sub really isn't needed.
    Receiver: ONKYO 709
    Amplifier: Acurus A200x3
    Front: EmpTek E55Ti
    Center: EmpTek E56Ci
    Surround: EmpTek E5Bi
    Sub: Elemental Designs A5-350
    TV: LG 55"
    Blu-Ray: PS3
  • mystik610
    mystik610 Posts: 699
    edited March 2011
    Depends on what I'm listening to.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
    F1nut Posts: 51,747
    edited March 2011
    Subs? We don't need no stinkin' subs. :biggrin:
  • Knucklehead
    Knucklehead Posts: 3,602
    edited March 2011
    My RT8t's seem to have plenty of low end...no sub needed.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited March 2011
    My receiver doesn't support a sub in "direct" mode, but a pair of RTi10 towers sounds pretty good to me. My future 2-channel plans include a Monitor 11 setup w/ no sub, and a 2-channel Vienna Acoustics bookshelf rig for which I'll most likely be adding a sub.
    Sometimes a pair of bookshelves, although definitely not "full range", sound really nice for 2-channel. A sub might make the audio experience more "complete", but for a lot of music, it's not necessary for casual listening. For example, a pair of LSi7s and a decent integrated can create a very satisfying experience.
  • PolkClyde
    PolkClyde Posts: 662
    edited March 2011
    gfong wrote: »
    I'm not going to let you color my thought, a sub sounds good with 2 front speakers,in two channel.
    PolkAudioClyde
  • JimAckley
    JimAckley Posts: 1,138
    edited March 2011
    Because of the way my system is setup, there's always an active subwoofer. I cross my receiver at 100Hz and let the LSi25s' 10" drivers take all of that information. My PSW receives the same signal, but I cross it at 50 and keep the volume relatively low, so it's just kinda like a low-fill subwoofer. I'm still playing with my setup now that I have the Pio, and might switch the 25s' subwoofers to the L/R preouts for fullrange fronts and use the PSW for just LFE. We'll see.
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
  • PolkClyde
    edited March 2011
    BlueFox wrote: »
    Obviously, Of course if you have the sub wired via the speaker cables going to the sub first, and then going to the speaker, that is different, but I doubt if many use that method.
    That's exactly the method I use.
    PolkAudioClyde
  • gfong
    gfong Posts: 1,079
    edited March 2011
    Awesome points all, I am really surprised at how many of you use a sub for music. I am not saying it is wrong or right, just surprised. Actually as of now the split is 17 yes and 12 no.
    I ran a sub with my Polk satelites and had it hooked throught the speaker leads and not the sub cable. I experimented with that a few times and always went back to the speaker wire hook-up (like you would wire a passive sub)
    Maybe I will try messing around with the sub and 2 channel. I am sure my SVS is up to the task if asked! Who knows!
  • Fongolio
    Fongolio Posts: 3,516
    edited March 2011
    Home theater sub yes
    Two channel sub no
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • vc69
    vc69 Posts: 2,500
    edited March 2011
    Because of the way the question was worded, I had to vote "only with multichannel" but I NEVER listen to music in multichannel even though those formats offer the option. Even my bluray audio discs have a stereo mix.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Gadabout
    Gadabout Posts: 1,072
    edited March 2011
    I don't have a sub in the 2 ch rig. It digs plenty deep, especially since I bi-amped the Audes. I do have a sub in the HT system, but I don't play much music on that system. Only time music gets played on the is when I have guests over.
    I do have 2.1 system in the bedroom. The bedroom is mutipurpose for music and movies. The mains in this system are LSi7's and the addition of a small sub really helped both movies and music.
    I voted no cause there wasn't an option for both. That being said, if I only had one system. I would probably listen to music with the sub on.
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • cubdog
    cubdog Posts: 835
    edited March 2011
    I listen to Dahlquist DQ10s in my main 2 channel system. A sub is kind of a requirement with the DQ10s.
    cubdog
    Shuguang Classic S8MK
    Emotiva XDA-2
    Bel Canto M300 mono blocks
    Bel Canto DAC 1.5
    Squeezebox Touch
    Sony SS-M7
    A/D/S L710
    treitz3 Posts: 19,985
    edited March 2011
    I answered yes. This is at a low level as I do not like boom at the bottom. When used in conjunction with the SMS-1, it's like there is no sub. Just an extension of your speakers when set up right. Like they aren't even there. However, you notice a big change when you turn them off.
