SDA Custom Circuit Boards ?
Sorry for the lack of updates guys, but I'm still waiting on some of the testers to get off there butts. F1nut got his done http://www.polkaudio.com/forums/showthread.php?t=113339 for his remarks, Lasareath got his done but not mounted yet as far as I know check out his progress here http://www.polkcrs.com/02-CROSSOVERS/index.htm. I'm waiting on the tester because I want to make the best boards I can for you guys.
Also there's a lot going on behind the scenes regarding these boards, Like a site dedicated to these boards (A big thanks go's out to Lasareath for providing the domain name & server space) it's about 75% done. The site design, schematics and parts placement guides are done, The parts list are all most done (90%) and the full guides need to be done still.
I will update here as much as I can and yes this thread will be the place to look for them to be announced.
Sorry it's taking so long guy's, I really want to get these going to.
~ gimpod“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
No need to apologize at all. It's fantastic that you're doing this (and of course the beta testers and Lasareath). I wish I had the gumption and know-how to lay out my own clean socks and underwear let alone a circuit board.
I've been following the progress on PolkCRS.com, and it's definitely got me motivated in a big way. But I'll just subscribe to this thread and sit tight. Thanks again! -
Well I finely got the web site for these boards up and going (A BIG thanks go's out to Lasareath for providing the domain name and server space) you can check it out here www.gimpod.com I've got every thing done except the "Hint's & Tip's" section still working on that, The parts list, part placement guides and schematic's are done. So take a look and let me know what you think.
So when are these boards going to be ready? I don't know still waiting on the testers but I think I'm going to go ahead and order a small run after the first of the month.
That's all folks, for now. And again A BIG thanks go's out to Lasareath.
just checked it out--Outstanding webpage sir--good on you--very good,,indeed.
JC approves....he told me so. (F-1 nut) -
~ gimpod
Great job! will ordering be done through the site? Your layout on the page makes it so easy even a caveman could do it.
Please put me down for a set from the first batch. The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Nicely done.
Good job guys.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
It looks great and lots of useful info. Having parts lists with all the links is a great help for all of us. If you think the boards are ready to go, put me down for a pair for my 2.3TL's.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808 -
Wow... looks like maybe a little bit of work went into that! That parts placement image map is wicked cool. You just really put it out of the park on this.
Spectacular! Thanks Tony.Proud and loyal citizen of the Digital Domain and Solid State Country!
Great job guys!!!SDA SRS 2.3TL's
SDA 2B TL's -
awesome work man.. cannot wait to sign myself up for this.
Great website!! Sign me up for a pair of 1.2TLHT/2 CH
McIntosh MX120, MC500, MC206, MEN220
polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect. -
An attention-grabbing discussion is value comment. I think that it's best to write more on this matter, it won't be a taboo topic however generally individuals are not sufficient to talk on such slim pill To the next. Cheers. weight losing tips
Brilliant! Simply Brilliant! I can't wait to get a set!
How and when can we order?
Thank you very much for everyones' time and effort. Amazing the following the old Polks have! -
post 113 reportedTurntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
The hover-over is nice for a quick reference, but if someone is at a worktable with a soldering iron in their hand, a printable parts placement guide would be a lot more helpful. Just something like a text file that says:
40 mf (total) cap C2A and C2B. Recommended 2 20 mf Sonicaps.
5.8 mf cap C5 (only for TL)
etc. Not really step by step instructions, but those might be handy too to make this upgrade more accessible to more people. Though there's an obvious downside to that as well, since then some people might get in over their head, doing silly things like clipping leads on inductors and such.Turntable: Empire 208
Arm: Rega 300
Not to be a smart **** (but I am oneThe hover-over is nice for a quick reference, but if someone is at a worktable with a soldering iron in their hand, a printable parts placement guide would be a lot more helpful. Just something like a text file that says:
) but there is such a thing it's called a schematic, you can download it and print it and it shows you where everything go's.
I'm working on a general assembly guide and the VERY first section is a list of things not to do. I'm try to do the guide so that it will help out the first timer's the most.etc. Not really step by step instructions, but those might be handy too to make this upgrade more accessible to more people. Though there's an obvious downside to that as well, since then some people might get in over their head, doing silly things like clipping leads on inductors and such.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Since you are being so nice...for those of us who don't like to read and for those of us who are not "hands on", could you just put together a complete kit we can order from you which includes all parts and a detailed full color assembly manual and contact info of forum members who will assemble these for us?
Please, pretty please?
Proud and loyal citizen of the Digital Domain and Solid State Country! -
Maybe he could just build new sda's for us while he's at it. I think between him and Larry(TFL) I think they have all the bases covered.:rolleyes:
DarqueKnight wrote: »Since you are being so nice...for those of us who don't like to read and for those of us who are not "hands on", could you just put together a complete kit we can order from you which includes all parts and a detailed full color assembly manual and contact info of forum members who will assemble these for us?
DK, DK, Your such a bad man.
But now that you mention it sure why not for 20k a pair I'll be a ****. “The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
still waiting on some of the testers?
After talking to the beta testers F1nut, Lasareath, TOOLFORLIFEFAN (haven't heard a peep from the other two headrott and mole' even after numerous attempts to get hold of them :frown:) I've decided to go ahead and order a production run of the boards also I've decided on a price of $100.00 a pair including shipping.
Now there are somethings you need to be aware of.
First: Mounting (This only affects the SDA SRS 1.2/TL and the CRS+).
Because of the size of the new boards (10" x 5 1/4" vs 5 3/4" x 4 1/4") the only place I can think of to mount them in the CRS+'s is on the bottom of the enclosure and extend the leads (P & R) up to the big 16mH inductor. Now that brings us to the SDA SRS 1.2's, I might suggest that you could mount the board on the crossover plate plug everything in and then slide the top in at an angle then move the whole assembly up so you can slip the bottom in and then bolt in place (it should be able to fit through the cabinet opening measuring 4-3/4" high by 14-3/16" wide) and if that doesn't work you could mount the bare crossover plate first then slide the assembled crossover through the hole for the PR and then bolt in place.
Second: Let me ensure you that these boards are electrically identical to the originals with two exceptions, there is no place for the 750pF Silver Mica bypass cap(C4) for C3 it's not needed with the newer/better cap's you can buy today and nobody uses it anyway also I added a jumper (J4) for the Non-TL 2.3's & 1.2's to make things a little easier.
Ordering & Shipping:- These boards will be for Club Polk members ONLY!
- These boards will go on sale in the FM when I have them in hand and ready to ship.
- Payment will be by USPS money order only.
- Shipping will be by USPS Priority Mail.
That's it for now boys & girls, When I get them in my hot little hands I'll put them up for sale in the Flea Market.
So this is NOT an order thread and you are only taking orders once the boards are manufactured?
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
That's correct, I just don't think it's right to start taking orders and money until I actually have product to ship.
BTW: I've got you on the list along with everyone else who has posted here that they would like a pair, you guys are first in line.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
no chance of paypal if we are willing to eat the fees?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »no chance of paypal if we are willing to eat the fees?
I don't really want to use paypal if I don't have to they can be a PITA to deal with at times. What's the fee now days 3%, Let me think about it.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
The man says he wants USPS money orders....what's the problem!?!
Great effort. When do you think these will be available? I'd like to get a set for my 2.3TL if you get enough produced.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Let them pay the 3% or send it as a gift. PayPal is fine from Polkie to Polkie. It's more of a risk dealing with scammers.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
