Led Zeppelin Box Set 50% off
So now there's no difference between comparing and quantifying? :biggrin:Why not, don't you know specs mean everything.
BTW, Jesse, I cancelled your order...
More later,
Tour...
Vox Copuli
Based on the readings at the Steve Hoffman forum, it's as clear as mud. Hopefully today I'll get some listening time in.
+1!
In regards to measuring, I think it is good if we can equate it to our listening experience and apply it to our future gear choices. For instance, I had some tube and SS gear tested for distortion. Not just total, but at what frequency and what amount and what kind of distortion. While it opened my eyes to what I like and don't, someone that doesn't or won't try and understand what second order distortion does would look at the graph and dismiss/bash gear based on that. It's no wonder manufacturers don't or won't provide that kind of detailed info to the public.
Not a new concept of course. Older audio folks will recall the measurement versus listening debates that occurred while we were growing up (or just getting older:biggrin:).Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Listening to LZ I on the office rig. Not bad at all, actually sounds pretty good. Still too early to tell for sure. I'll pull out the original and then the typical remaster and see if I can hear any differences...........well I'm sure I will between the 80's original and this.
I have to say the original release of LZ I sounds mighty fine, mighty fine. Less digital for sure than this box set remaster. But it doesn't have the space around the instruments or vocals. But it's not as "crunchy" sounding up top as the remaster. Glad I hung on to the original releases from the 80's in addition to having this boxset
I have to say the original LZ I is a more enjoyable listen than the remaster. Now if you only had the remaster I think you would be happy, but after listening to the original cd, it's a lot more analog sounding.
The cymbals "shimmer" rather than "crunch"
The boxset sounds good. I really think they are the same masters/pressings as the Atlantic Japan CD's. It's LZ, so higher-fidelity isn't in my set of expectations. I do have a couple of the early 80's radio station kits with all the LZ CD's distributed to radio stations at the start of the LP to CD transition. I've never opened them so not sure if those are the origninal masters or not.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Mine finally arrived today. I couldn't get it out of the shipping carton even after opening the bottom to try and push it out. I ended up pulling the carton open at the side seam. I found that both top, back corners, which would be on the bottom in the carton, have the black coating peeled off and of course the plastic is ripped, which indicates that someone jammed it into the shipping carton. I found the black pieces of the coating inside the carton. I sent Rhino an email, so we'll see what they do. Right now, I'm extremely unhappy.Political Correctness'.........defined
President of Club Polk -
Mine was packed pretty tightly also. I turned it upside down and shook it and it kind of slowly slid out. I would guess that Rhino will send you a new box.DKG999
Yeah, they don't need to send another box set, I would be happy with a new outer box.Political Correctness'.........defined
LZ 3 from the boxset seems to match exactly to "Led Zeppelin III AMCY-2433 Atlantic ~ east west japan 97-11-5.log" when using the bit comparison software after I ripped it to the server. It didn't match to whatever stat file and master dbpoweramp thought it should use for comparison.DKG999
Got mine today and it was packed very tightly also. Luckily no damage to the box set. I'm very excited to listen to these as most of my LZ experience is from the 4 disc box set and the Led Zeppelin DVD. I know all the songs but have never actually listened to any albums except IV and In Through the Out Door.Things work out best for those who make the best of the way things work out.-John Wooden
Have fun listening to the albums in their entirety, should be a new high!
Especially if you start at LZ 1 and continue the journey through to the end! Happy listening! -
Mine came in a larger box with some stuffing and one of those air packs. Not jammed into anything to tight. You'd think with the size of operation Rhino runs and because they are mail order they would have some shipping consistency.
Without any hassle Rhino is sending me a new outer box. I am quite pleased with their customer service.Political Correctness'.........defined
Good to know, and glad they handled it that way for you.
I'm stil waiting for mine! -
Sure, I finally go to buy it and it won't add anything to my cart... awesome
grimmace19 wrote: »Sure, I finally go to buy it and it won't add anything to my cart... awesome
I had to add mine twice to get it to work. Just ordered, thanks for the heads up Jesse. -
Odd that they'd have just a box setting around. Maybe some employee just got a free collection minus the box.
Glad they took care of it...
GBRR...More later,
Tour...
Vox Copuli
I tried to place an order last week but the website wouldn't recognize my address. Finally called the next day and the rep was extremely helpful. He wasn't able to manually place the order because this boxed set is a code/link referral offer, but continued helping me until we figured out the city/zip on their database was referenced incorrectly. Made a change and the order went through. It's worth calling...their CS is very helpful, but he said the only way to get the offer is through the website.
Now, just waiting for the boxed set to arrive.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
reported. Nice links, though.
Just wanted to give a shout out to Rhino for their excellent customer service. I got my outer box yesterday, all nice and damage free. Yay! Stuff!Political Correctness'.........defined
Ordered mine on Sunday last weekend and got it on my doorstep on Thursday, regular free shipping.
Thanks for the heads up! -
Ordered LATE tuesday night and it was in my mailbox today! Very cool package
I ordered on the 27th (9 days ago) and still waiting.....
anybody care to give opinions on the set.
How does it sound?
Same old remasters?
Thanks Glen -
I ordered January 14, 2011 an still waiting. Someone at the border is probably rockingout to my box set!
I emailed them, and am waiting for a response. If I don't hear from them by Tuesday, I will call them. -
Ordered mine on Fri, 28 Jan, and received it today. Thoroughly impressed w/the packaging/reproduction quality. This set is way cool! Takes me back to high school and hanging out in my best friend's basement, thumbing through the albums. I'm listening to the first CD, track 9-How Many More Times, and the SQ is very good.
If you're on the fence w/respect to purchasing, IMHO, it's worth every penny of $87, + free shipping to boot (USPS).➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Could not agree more! Nice box set for sure.
Mine arrived in the mail today, packed very well in bigger box with bubble wrap around it.. -
The first thing that anyone who purchased this box set needs to do is order replacement "**** bags". The original ones are terrible....the glue on the strip is too strong and the plastic is too thin causing the damn things to rip.
Wes at www.soundsourcecds.com sells high quality replacements, actually made in Japan.Political Correctness'.........defined
Is this basically the same as the LZ Complete Studio Recordings Box Set?
