Id like to modify your crossovers...
You're welcome. :biggrin:Vr3MxStyler2k3 wrote: »hehe -- The Clarity Cap MR is like crack for speakers, thats all I can say... if they were not so expensive I would put them everywhere.. lol"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Shoot me a PM K-Daugh
You can mail them to me, I can tell you what parts you will need - give you a list and a price and then get them ordered for you.
Thanks- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Reported Spam.
. Ok will do I'm just going to wait a week or two before I send them ....thank you so much ......I will drop you a pm a few days before I send .....I know you probably don't want to. Do this but I have absolutely no idea what this would actually cost and I'm perfectly fine with you needing the crossovers before you can give me a price .......but is there anyway you could give me a ballpark ......I will not hold you to it ......just looking for a rough ideaVr3MxStyler2k3 wrote: »Shoot me a PM K-Daugh
ThanksBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
Hey K -
I replied to your PM! Look forward to working with you, if you do plan to do this and the above sounds good - just paypal me the total we come to and I will preorder your parts. This will allow me to expedite this process for you!
Just a funny for you guys
The Monitor series from Polk has virtually the same tweeter network as Def Tech speakers!
And I thank you! Have a good night- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3m? What do you think re: my post? Anyone else? Bumpity.
Capacitors have about a 20 year shelf life before values change and they just start going bad...
What I would tell ya -- if you modify them with good quality parts you will NOT be dissapointed.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Hot...
Mine is a fixed rating, I forget what it is... its pretty fool proof as long as you dont keep it on there to long- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I keep mine cranked up almost all the way and work quickly."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I dont need clarity caps but I do want a high quality cap for my LSi25s, LSiC, and LSiFXs. What brand(s) do you recommend? And where can I find the schematics for the C and FX? I already have it for the LSi25.- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
Clarity Cap ESA is awesome and not really that expensive. I understand it is 85% of the MR- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
How about for my antique allison 6's??Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Man if any of you guys are thinking of modding the FX's, they are expensive! I got the schematic from Polk today and there's a lot in there.- Computer Rig -
- Main Rig -
Any idea of cost etc....??
Will see what i can do with taking the plate out...Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
I would suspect that you would need to open it up and see what value the components in need of upgrade are. That way, you can look them up individually, add the quantity needed and then tally it up for a total.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
What would be a good 260uf cap to use? Does it make a huge difference if you have to mix in a cap from a different line or brand? I was thinking about doing everything I could with Clarity ESAs but they dont have a 260- Computer Rig -
- Main Rig -
two 130 strapped together would work...
Clarity PX -- even a Solen would work ok for that- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »Definitely...
Not sure - you would need to send me a parts list...
You might want to think twice about doing the RTi A7's or any of that line. There's no room on the stacked stock boards and there's no practical way to remote mount anything.Political Correctness'.........defined
President of Club Polk -
Well rats, its not going to work as the parts are glued to the rear of the speaker..no way of taking them out "easily". Guess i will just deal with the classic soundComputer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
This is making me get the itch I wonder if my usher x-718 would benefit from a crossover upgrade. If I did it I would want the best.
just curious, are LSi9 mods on the table here? been considering it though not desperate as I love how they sound as is. though can't help what they will sound like "improved"Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
I'll mod them... No issues- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
As awesome as the thought of modifying these crossovers is fun... Apparently an individual is pMing people inquiring and discrediting me. Personally I'm ok with that but it's not cool.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I will not be modifying crossovers until some people grow up- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
If I have spoken to you previously I will honor any and all offers.. I will contemplate new inquiries until further notice.. I will still help anyone with questions of course- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Vr3MxStyler2k3 wrote: »As awesome as the thought of modifying these crossovers is fun... Apparently an individual is pMing people inquiring and discrediting me. Personally I'm ok with that but it's not cool.
WTF?
Who cares if there's some a$$hole out there. Let me know if you want to do a pair of RTi8's and I'll ship them to you._________________________________________________
Hmmmm I'm in australia so shipping would be a ****. but hey if theres gonna be a decent difference then yeah i really dont mind aye.
But do you do crossover mods and what not for old polks (particularly old monitor series polks)?
I think there is a problem with them (speakers sound all quiet now, drivers stuffed up at the same time too).
A ballpark figure of the cost would be nice, but i understand it's not final until you'd get them.
Heres a photo
http://img508.imageshack.us/img508/9669/photo2ir.jpg
Nice and simple i think.
edit:Vr3MxStyler2k3 wrote: »I will not be modifying crossovers until some people grow up
I just read that, dam it always takes some idiot to spoil it all for everyone.
If your not happy to modify them for me, what would you suggest i get done to these, i have SOME electronic knowledge, just never ever touched speaker parts before in my life.
