Your "BEST" best speaker cable to date!
monster ultra 1000 pre terminated
j/k audioquest Gibraltar -
AudioQuest Mont Blanc single bi-wire 72v dbsLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Up till now I just use 12awg outdoor lighting cable, but as soon as I upgrade my SDAs with XO re-work and RDOs I'll start trying new ICs and speaker cables. My finances won't allow me to go too high up the chain plus my gear doesn't really rate top notch cables anyway. I think Signal or Bluejeans will be more than good enough to reveal all the other flaws in my system!:)
(carver tfm-35, c-11 & sd/a 450,srs2p/b & pioneer pd9010x) -
Single run of Kimber 8TC v.2 (white/clear jacket) bananas on both ends. I have no desire to replace it with anything.
Kimber gets my vote
I am currently running Cardas but would agree; for the money I think Kimber is very had to beat. I plan on going back to Kimber in the near future. -
I really like the Kimber line. Very good build quality, top-notch materials without too much snake oil engineering, reasonably priced, and excellent performance.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
i second the straley reality speaker cables. i am using single runs with audio art sc-5 jumpers. i started a thread on audio circle asking people what speaker cables they replaced their straley's with and the ones that replaced them, went to much more expensive cables. i think the straleys are priced $250-$280 for an 8' pair.
i also like the audio art sc-5 speaker cables.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
MIT MH 750 Shotgun bi-wire.
Grover Huffman "SC" bi-wires with carbon-nickel shielding and silver wire terminations.
Not even the new 12tc cables ??
C'mon Steve,let your hair down and shake it up a bit.:)HT SYSTEM-
lsi 9's -
Anyone ever try any cables from LAT International? They get dynamite reviews & are priced for us mere mortals.
http://www.latinternational.com/index.php/home/home%20-%20about%20lat.html -
Homemade Canare 4S11 bi-wire. Boots from parts express; bananas from GLS audio.[
I think if you aren't sure what kind of synergy your system may have, AQ PSC+ IC's and SC's are a damn good place to start.
Silver, though, is what seems to be making the biggest difference nowadays. I have Ben's silver bi-wired on my tweeters, MAC AgQ's (pre to amp) and KAS silver (CDP to pre) as my main conductors and noticed immediate, positive differences over the AQ and Vampire copper products.
FWIW, I thought the Vampire CCC IC's did everything the AQ Diamondbacks did for half (or less) the price.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Really enjoyed the Tara Labs RSC 500, then RSC Reference Gen 2+, and now have MIT Shotgun S2. The MIT's have better openness and clarity, but the Tara matched with my LSi15's had the low-mid/high-bass impact that got my foot tapping, where the MIT doesn't. I know its probably artificially bumping that frequency, but its still pleasant to listen to.
I would like to compare the Tara Air 1, but haven't seen any in biwired configuration.LSi15's, LSiC, LSiF/x's, LSi7's, vr3 crossover upgrades, SVS PC-12 Plus, SVS SB-16 Ultra, Marantz AV8805, Parasound amps, LG OLED65C9PUA, Clarus Crimson, Signal Cable, Atlas Cable, Shunyata and Synergistic A/C conditioning, dedicated Cardas 30A and Furutech 20A AC lines, Box Furniture, Solid Tech ROS, Symposium roller blocks -
The dried skin of heroin addicted Ukranian hookers.
Really fleshed out the mid-range.
OOPS I'm sorry just had a flashback to when this place was fun.
*runs and hides* -
Audioquest Midnight. Thicker than s@#t and hard to work with. Used to sell for $10 a foot way back when but you can find it for peanuts these days.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Transparent Ultra, QED Genesis Silver Spiral, QED Silver Anniversary XT. Don't hit me over the head, but I think most of the cable stuff is massively hyped.Polk SRT HT System
Polk CS1000p / FX1000
Sony KDS-R70XBR2
Yamaha RX-Z9 Processor -
Old thread back from the dead.
Well, not much has changed in my rig here with the exception that now I have two pair of AQ CV-8's w/ the 72V BP. I feel no need to upgrade on this front. Like Mantis said, it's a good all around cable.AQ CV-8's w/ the 72V BP. Used, single run.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Dan
My current setup is bi-amped with 3 meter PS Audio Preludes on the ribbons:
& 12 gauge outdoor lighting wire on the woofers:
...best I've heard......SO FAR~TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Old thread but a good one! MIT Shotgun S1Vinyl, the final frontier...
speltz anti-cablesFronts: Wharfedale diamond 9.6
Sub: Wharfedale sw250
Rears: Wharfedale diamond 9.1
Center: Paradigm cc-350
Pre-amp: Oppo dv981hd
Amp for fronts: Parasound hca-1500a
Amp for rears: Adcom gfa-5400
Amp for center: Marantz MA500 monoblock
Polk multimedia speakers for PC setup -
Still running the AQ CV-4's and also have been running some Canare S411. I have tried many cables in my system and heard many others in other peoples systems. The S411 is a real cheap way to get into better cables. When I get my speakers convert from an active XO to a passive XO I will be looking to give MIT another shot.
Ben -
Nordost flatline.
Excellent bang for buck!Testing
Testing
Testing -
MIT Shotgun S1Political Correctness'.........defined
President of Club Polk -
MIT Shotgun
RT1 -
MIT Shotgun's
MIT Shotguns S3I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
MIT Shotgun S2
WireWorld Eclipse 6.0 and matching jumpers. A well rounded cable from top to bottom. Tends to do everything without emphasizing any particular freq.
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
