Your "BEST" best speaker cable to date!
pearsall001
pearsall001 Posts: 5,231
edited May 2011 in 2 Channel Audio
Just as the title says...what speaker cable have you found to be the best in your system. Was it bi-wired or a single run, what made you choose it over others you auditioned, new or used, price or anything else you can add to the discussion. I'm not looking to open up a can of worms here...just looking for personal preferences & the reasons why you choose them.
Post edited by pearsall001 on
«134
  • ben62670
    ben62670 Posts: 15,969
    edited November 2008
    AQ CV4's with the DBS on the lows, and I use my Silvers on the highs. I am awaiting the MIT Demo:) I snagged up some AQ type 4's, and the CV4's at a real low price. I Made some Silvers, and found them to be sweet on the highs, but the bass was not as full as the AQ's. I have used many types of wires, but this setup allows the detail to come through. Negatives is that it makes bad recordings sound bad.
    Ben
    Ben
  • ShinAce
    ShinAce Posts: 1,194
    Coat hangers. The plastic kind. Wood is ok, but lacked bass.
    Honestly though, I'm more anal about the connections(terminal cups, and internal speaker wiring) than the external stuff. It's like running a 4 gauge piece of wire for an amp in a car when the car's own battery ground is 10 gauge. You need to rewire the whole system to see full benefits.
    And with that said, I'm out.
    treitz3 Posts: 19,945
    AQ CV-8's w/ the 72V BP. Used, single run.
  • markmarc
    markmarc Posts: 2,309
    A slight nod to AudioArt over Zebra cables (single). Super flexible and they play nice with any amp/speaker I've hooked them up to.
    Former Staff Member TONEAudio
    2 Ch. System
  • Face
    Face Posts: 14,340
    MIT AVt MA. Besides incredible clarity, definition, bass response, tone, and soundstage, who would have thought a cable could also improve 3D imaging?
    Alpha Core/Goertz AG2. Not very far behind the AVt MA, but having a slightly different overall tone, the imaging isn't as defined. But for less than half the price, I'm not going to complain.
  • beardog03
    beardog03 Posts: 5,550
    I went from the standard Monster cable from BB to AQ type 4`s and noticed a more full sound , all around..
    A solid cable in the price range, IMO
    I currently use AQ Bedrocks ~ Bi-Wired..
    I first bought them because of the good things that I had heard about them, and they were on sale at AA..
    These cables do all I want from a speaker cable.....It was like taking the kink out of a garden hose !
    The Bedrocks are much bigger guage than I had expected, and the terminations are rock solid.
    I highly recmmend these to anybody looking to upgrade.... to maybe the last speaker cable they may want to get.
    The only way I will change them out , is when I get the MIT Shotguns to match my I/C`s
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • jmwest1970
    jmwest1970 Posts: 846
    I started out with Monster Cable and after reading lots of discussions about speaker cables decided to try IXOS XHS806 twisted pair cables. I chose IXOS primarily because they were available from one of the last two non big box audio stores in the area, and the price wasn't too bad at $1.50/ft. The difference between the Monster Cable and IXOS was immediately evident. There was more sparkle and midrange no longer sounded like it had a quilt over the speaker.
    I used the same IXOS cables when I built the 2 channel system and the dynamics were certainly there, but the Totem Rainmakers seemed bright compared to the audition that I had with them. Having been told that the Rainmakers sounded better in a bi-wire configuration, I decided to try the IXOS XHS756. In the beginning, the change was obvious, but after a decent break in period the Rainmakers sounded much better.
    F1nut Posts: 51,674
    MIT Shotgun S1
  • Ricardo
    Ricardo Posts: 10,636
    MIT Shotgun S3
    Have been debating if the jump to S1 would be worth it; maybe some day.;)
    SOPA
  • beardog03
    MIT Shotgun S1
    Some day !!!
    Soon , I hope !
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    I am with Ricardo
    MIT Shotgun S3
    Did wonders for my system.
    Now it is Power Cord time.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • pearsall001
    Well, so far it looks like MIT is the most popular...then AQ. Interesting, I'm suprised there's no one using Nordost, Cardas, Signal, or even lamp cord (maybe there is). There's so many cable vendors to choose from to say the least. Keep 'em coming!!
    Another question for you...if you're happy with what you're running now, what brand did they dethrone from your rig?
  • Face
    Face Posts: 14,340
    Goertz AG2 dethroned Signal and MIT AVt MA dethroned Goertz. FYI, MIT Shotgun S1's did NOT dethrone Goertz AG2's.
  • Ricardo
    Audioquest Type 4, Signal, MIT (with a few not worth mentioning in between....)
    SOPA
    F1nut Posts: 51,674
    IIRC, the S1's were not fully burned in.
  • wingnut4772
    wingnut4772 Posts: 7,519
    DH Labs Q10.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Face
    Face Posts: 14,340
    It's possible. I've been asking the owner to bring them by again.
  • george daniel
    george daniel Posts: 12,096
    MIT and Signal
  • fbm211
    fbm211 Posts: 1,488
    I used Heartland cables first (canare4S11) with vampire gold bananas.
    Later moved up to DH Labs T-14 terminated with cardas silver plated spades.And wired them in a shotgun config of course.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • pearsall001
    DH Labs Q10.
    Hey Darla,
    How do you like the DH Q10 speaker cables. Any comments on what they replaced.
  • W WALDECKER
    W WALDECKER Posts: 900
    I liked the Audioart silver over copper designed by DH labs.I have a 6'pair of MAC CUQ soundpipes ordered and they are pure copper 8AWG with BFA bananas on the amp end and Vampire gold over copper HD 5/16' spades on the speaker end....WCW III :)
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • mantis
    mantis Posts: 17,316
    Audioquest CV-8's. Best all around cables I have ever used.
    Dan
    Dan
  • Early B.
    Early B. Posts: 7,900
    I've been using MAC CuQs for a while now and see no reason to even consider upgrading. They replaced CV-8s, but to me, both cables sound virtually identical. So I'll have to say that my best speaker cable to date is MAC simply because they are about one-third the cost of CV-8's.
    "God grooves with tubes."
  • read-alot
    read-alot Posts: 812
    MIT Shotgun - no need in even mentioning the rest.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
    heiney9 Posts: 25,403
    MIT Terminator 2; both IC's and speaker cables in the main rig.
    Home made Canare 4S8 double run shotgun style terminated with 'nanners for the office rig. WOW......what a difference over zip cord. I waited way too long to get some decent cables in the secondary rig.
    tonyb Posts: 33,065
    Gregg Strailey Reality cables,bi-wired.Stiff as all hell,but sound is awesome.If you have the room,and don't have to turn into tight area's,give these a whirl,pretty darn cost effective too.Gregg is a local guy here in chicago and can meet all your needs.I know he has demo pairs that he floats around too.
  • janmike
    janmike Posts: 6,146
    While I have not tried tons of different cables (about 5 or 6 different ones) the MIT S1's are by far the best and currently use them in my 2CH rig. Signal Cable has the presence in my HT.
    Michael ;)
    NORTH of 60°
  • steveinaz
    steveinaz Posts: 19,545
    Single run of Kimber 8TC v.2 (white/clear jacket) bananas on both ends. I have no desire to replace it with anything.
  • Hawkeye
    Hawkeye Posts: 1,313
    Single run of Mapleshade Double Golden Helix. Not a lot to look at, but I'm into it for the sound.
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • BigMac
    BigMac Posts: 849
    edited December 2008
    Luminous Audio - Synchestra Cables. I previously had the Prestige but sold them to someone here at CP.
