Your "BEST" best speaker cable to date!
24
  • Montoya
    Montoya Posts: 506
    edited December 2008
    monster ultra 1000 pre terminated
    j/k audioquest Gibraltar
  • danz1906
    danz1906 Posts: 5,144
    AudioQuest Mont Blanc single bi-wire 72v dbs
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • gdb
    gdb Posts: 6,012
    Up till now I just use 12awg outdoor lighting cable, but as soon as I upgrade my SDAs with XO re-work and RDOs I'll start trying new ICs and speaker cables. My finances won't allow me to go too high up the chain plus my gear doesn't really rate top notch cables anyway. I think Signal or Bluejeans will be more than good enough to reveal all the other flaws in my system!:)
    (carver tfm-35, c-11 & sd/a 450,srs2p/b & pioneer pd9010x)
  • lakesailor
    lakesailor Posts: 319
    steveinaz wrote: »
    Single run of Kimber 8TC v.2 (white/clear jacket) bananas on both ends. I have no desire to replace it with anything.
    Kimber gets my vote
    I am currently running Cardas but would agree; for the money I think Kimber is very had to beat. I plan on going back to Kimber in the near future.
  • steveinaz
    steveinaz Posts: 19,545
    I really like the Kimber line. Very good build quality, top-notch materials without too much snake oil engineering, reasonably priced, and excellent performance.
  • marvda1
    marvda1 Posts: 4,936
    i second the straley reality speaker cables. i am using single runs with audio art sc-5 jumpers. i started a thread on audio circle asking people what speaker cables they replaced their straley's with and the ones that replaced them, went to much more expensive cables. i think the straleys are priced $250-$280 for an 8' pair.
    i also like the audio art sc-5 speaker cables.
    Puritan PSM156
  • hearingimpared
    hearingimpared Posts: 21,136
    MIT MH 750 Shotgun bi-wire.
  • rlmacklin
    rlmacklin Posts: 46
    Grover Huffman "SC" bi-wires with carbon-nickel shielding and silver wire terminations.
    tonyb Posts: 33,065
    steveinaz wrote: »
    Not even the new 12tc cables ??
    C'mon Steve,let your hair down and shake it up a bit.:)
  • pearsall001
    pearsall001 Posts: 5,228
    Anyone ever try any cables from LAT International? They get dynamite reviews & are priced for us mere mortals.
    http://www.latinternational.com/index.php/home/home%20-%20about%20lat.html
  • vonnie123
    vonnie123 Posts: 326
    Homemade Canare 4S11 bi-wire. Boots from parts express; bananas from GLS audio.
  • I-SIG
    I-SIG Posts: 2,243
    I think if you aren't sure what kind of synergy your system may have, AQ PSC+ IC's and SC's are a damn good place to start.
    Silver, though, is what seems to be making the biggest difference nowadays. I have Ben's silver bi-wired on my tweeters, MAC AgQ's (pre to amp) and KAS silver (CDP to pre) as my main conductors and noticed immediate, positive differences over the AQ and Vampire copper products.
    FWIW, I thought the Vampire CCC IC's did everything the AQ Diamondbacks did for half (or less) the price.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • mdschlayer
    mdschlayer Posts: 209
    Really enjoyed the Tara Labs RSC 500, then RSC Reference Gen 2+, and now have MIT Shotgun S2. The MIT's have better openness and clarity, but the Tara matched with my LSi15's had the low-mid/high-bass impact that got my foot tapping, where the MIT doesn't. I know its probably artificially bumping that frequency, but its still pleasant to listen to.
    I would like to compare the Tara Air 1, but haven't seen any in biwired configuration.
    LSi15's, LSiC, LSiF/x's, LSi7's, vr3 crossover upgrades, SVS PC-12 Plus, SVS SB-16 Ultra, Marantz AV8805, Parasound amps, LG OLED65C9PUA, Clarus Crimson, Signal Cable, Atlas Cable, Shunyata and Synergistic A/C conditioning, dedicated Cardas 30A and Furutech 20A AC lines, Box Furniture, Solid Tech ROS, Symposium roller blocks
  • phuz
    phuz Posts: 2,372
    The dried skin of heroin addicted Ukranian hookers.
    Really fleshed out the mid-range.
    OOPS I'm sorry just had a flashback to when this place was fun.
    *runs and hides*
  • dragon1952
    dragon1952 Posts: 4,907
    Audioquest Midnight. Thicker than s@#t and hard to work with. Used to sell for $10 a foot way back when but you can find it for peanuts these days.
  • O'Shag
    O'Shag Posts: 76
    Transparent Ultra, QED Genesis Silver Spiral, QED Silver Anniversary XT. Don't hit me over the head, but I think most of the cable stuff is massively hyped.
    Polk SRT HT System
    Polk CS1000p / FX1000
    Sony KDS-R70XBR2
    Yamaha RX-Z9 Processor
  • Conradicles
    Conradicles Posts: 6,325
    edited January 2011
    Old thread back from the dead.
    treitz3 Posts: 19,945
    edited January 2011
    treitz3 wrote: »
    AQ CV-8's w/ the 72V BP. Used, single run.
    Well, not much has changed in my rig here with the exception that now I have two pair of AQ CV-8's w/ the 72V BP. I feel no need to upgrade on this front. Like Mantis said, it's a good all around cable.
  • mantis
    mantis Posts: 17,316
    edited January 2011
    mantis wrote: »
    Audioquest CV-8's. Best all around cables I have ever used.
    Dan
    Ditto
    Dan
  • TNRabbit
    TNRabbit Posts: 2,168
    edited January 2011
    My current setup is bi-amped with 3 meter PS Audio Preludes on the ribbons:
    & 12 gauge outdoor lighting wire on the woofers:
    ...best I've heard......SO FAR~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • madmax
    madmax Posts: 12,434
    edited January 2011
    Old thread but a good one! MIT Shotgun S1
    Vinyl, the final frontier...
  • samnor
    samnor Posts: 155
    edited January 2011
    speltz anti-cables
    Fronts: Wharfedale diamond 9.6
    Sub: Wharfedale sw250
    Rears: Wharfedale diamond 9.1
    Center: Paradigm cc-350
    Pre-amp: Oppo dv981hd
    Amp for fronts: Parasound hca-1500a
    Amp for rears: Adcom gfa-5400
    Amp for center: Marantz MA500 monoblock
    Polk multimedia speakers for PC setup
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    Still running the AQ CV-4's and also have been running some Canare S411. I have tried many cables in my system and heard many others in other peoples systems. The S411 is a real cheap way to get into better cables. When I get my speakers convert from an active XO to a passive XO I will be looking to give MIT another shot.
    Ben
    Ben
  • Systems
    Systems Posts: 14,873
    edited January 2011
    Nordost flatline.
    Excellent bang for buck!
    Testing
    Testing
    Testing
    F1nut Posts: 51,673
    edited January 2011
    MIT Shotgun S1
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2011
    MIT Shotgun
    RT1
    Toolfan66 Posts: 17,983
    edited January 2011
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited January 2011
    MIT Shotguns S3
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • Polkitup2
    Polkitup2 Posts: 1,640
    edited January 2011
    MIT Shotgun S2
  • Hawkeye
    Hawkeye Posts: 1,313
    edited January 2011
    WireWorld Eclipse 6.0 and matching jumpers. A well rounded cable from top to bottom. Tends to do everything without emphasizing any particular freq.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
