in-wall speaker cable?
madmax
madmax Posts: 12,434
edited January 2011 in Electronics
Which in-wall speaker cable should I get? It has to be a type which would pass building codes.
Vinyl, the final frontier...
Post edited by madmax on
«1345
  • ben62670
    ben62670 Posts: 15,969
    edited December 2010
    For surround sound I would go with Audio Quest 14/2 in wall wire.
    Ben
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I used Blue Jean Cables Belden 5000UE (Gray jacket, 12 AWG), been very happy with it.
    Wired for house speakers and surround speakers.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • jinjuku
    jinjuku Posts: 1,523
    Without knowing your run length I would hate to recommend 14/AWG (so what are your runs?)
    Monoprice 12AWG In-wall rated CL2. Check your local building codes for the jacket rating required.
    50 ft is ~$15 and 100 ft is ~$26.
  • John K.
    John K. Posts: 822
    Max, CL2 rated wire, such as the MonoPrice wire which was linked, is always permissible for in-wall residential installations. The appropriate gauge would vary with the distance of the run and the impedance of the speakers. While 16 or even 18 ga would be fine for relatively short runs to main speakers, for longer runs to surrounds 14 or even 12ga would be advisable, following the suggestions in the wire table here .
  • Systems
    Systems Posts: 14,873
    There is a 32ft pc. of the Monprice CL-2 12ga. listed for sale on this forum.
    http://www.polkaudio.com/forums/showthread.php?t=110904
    Testing
    Testing
    Testing
  • Midnite Mick
    Midnite Mick Posts: 1,591
    I think Mantis has experience with different in-wall wire. You may want to pm him.
    Good luck,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • Sherardp
    Sherardp Posts: 8,038
    disneyjoe7 wrote: »
    I second Bluejeans, used it in my HT also.
    F1nut Posts: 51,722
    Here ya go Chuck, goes well with your other MIT's.
    http://www.mitcables.com/available-in-stores/custom-installation.html
  • disneyjoe7
    http://www.mitcables.com/available-in-stores/custom-installation/12/2-speaker-cable.html
    Jesse, do you really think at $1.84 foot for a roll of 250ft of 12/2 speaker wire, would be 3+ times over the Belden 5000UE speaker wire at $0.52 per foot?
    Just wondering.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • mantis
    mantis Posts: 17,332
    disneyjoe7 wrote: »
    Just wondering.
    Stop wondering , it's not even worth it on any level with any level of speakers.
    If you want high quality in wall wire that retains sound quality , Audioquest FLX14-2 is where it's at. For runs under 100 feet this wire is fantastic. I use it good to high end speakers with spectacular results. It doesn't cost non of what MIT wants for their custom wire.
    Year ago I was running Transparent in wall Cl3 rated wire. It was very expensive , they had the same wall plates and custom tails like MIT does. I compared this setup to Audioquest on the same speakers , same length run , same everything and the Transparent didn't do anything better then the Audioquest did at a fraction of the cost.
    Compare these prices and decide if this is a good place to spend that kind of money for no improvement.
    http://www.crutchfield.com/S-UVSKbkgSYgh/p_70314260/AudioQuest-FLX-14-2-14-Gauge-In-Wall-Speaker-Cable-60-feet.html
    Dan
  • disneyjoe7
    Well I'm very pleased with Belden wire, and like it because A.) I used them. B.) many cables runs where I work in a Telephone Central Office are made by Belden. So if it as worked for many many years I find it hard to beat.
    Now saying that, Audioquest makes very fine cables also, as I have some RG6 cable made by them at a run of 30' which feed a whole house audio system from my HT setup. I'm very pleased with that cable also.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • madmax
    Lots of great advice here! Right now I'm leaning towards the Audioquest rather than the MIT. Afterall, its only HT. I have no problem with the cost of the MIT but it seems odd for me to buy twice as much of it than I will use.
    F1nut Posts: 51,722
    disneyjoe7 wrote: »
    Just wondering.
    Why folks like to compare wire at a price per foot strikes me as silly. Do we compare amps at a price per pound or by square inches? Of course not, we should judge them by their sound. It should be the same with cable.
    And yet, you haven't tried the MIT in wall cable to be able to make that claim. Pffft.
  • jinjuku
    I agree: All cable sounds the same :biggrin::tongue:
  • pearsall001
    pearsall001 Posts: 5,256
    MIT makes nice cables...are they worth the money is the question that only you can answer.
  • madmax
    My biggest concern is if I selected the MIT cable I would probably end up buying the termination boxes and every other accessory they have... :biggrin:
  • zingo
    zingo Posts: 11,258
    I have the monoprice 12g CL2 stuff and it has worked great in a number of applications; plus its crazy cheap.
  • pearsall001
    madmax wrote: »
    Save your money & buy more music.
  • disneyjoe7
    I would like to compare all these in-wall cables to hear what they will sound like.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • madmax
    I'm assuming I will only run the surrounds and maybe the center with this cable. I would use my standard front left and right speaker cables. Does anyone see that as a problem? The surround speakers match the character of my front horns almost to a T other than the bass is lighter and there is a little less definition.
  • pearsall001
    No problem what so ever. Hook 'em up & enjoy! Personally I like to use 12ga for any runs over 30'. That's probably overkill but it sure doesn't hurt.
    F1nut Posts: 51,722
    jinjuku wrote: »
    Let's see, bad teeth, nose full of boogers......yeah, I think it's a safe bet to say that your lack of personal hygiene means your ears are packed as well. :rolleyes:
  • disneyjoe7
    Synergy question...
    If I ran Belden wire from AVR Jacks to back surrounds speaker Jacks, would I lose any synergy? I'll be using Signal Cable speaker patch cables between AVR to Jacks and between back surrounds jacks to speakers, would this work?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Well...by the foot is kinda the way that wire is generally sold.:wink:
    For HT usage, I'd personally recommend going with something cheaper...but still of good quality such as the AQ cable recommended above. HT doesn't emphasize the differences in cabling to anywhere near the extent that music does, and thus...should be budgeted accordingly. IMO, it's not worth it to spend the extra on MIT if it's just for HT surround runs. If you do a lot of music listening in surround...it may be worth it though.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    F1nut Posts: 51,722
    Maybe the cheap audio stuff or electrical wire off the spool at Lowe's, but better audio wire is not sold that way.
  • comfortablycurt
    Well...maybe not in 1 foot increments, but you're still going to pay more for a longer cable than you are for a shorter cable. With most cable manufacturers, you can get custom lengths as well, and presumably the price would be adjusted accordingly.:wink:
    So, you still are essentially buying it "by the foot", whether or not it's advertised as such.
  • mantis
    Really? Lets see , Audioquest , sold by the foot , Cardos , sold by the foot , Kimber Kable sold by the foot , Liberty sold by the foot , Transparent sold by the foot , Belden sold by the foot ,Ixos sold by the foot any custom made wire by anyone sold by the foot. All wire is sold by the foot. The length determines the price hence sold by the foot. How do I know this? Gee lets see my company carries more wire then most people have seen in a lifetime.
    And yes I have heard in wall MIT wire many times. I'm not impressed or the least bit fooled by companies like them. You or anyone else can buy what ever you like. Good luck with all that.
    You should not speak of which you lack knowledge of.
    Dan
  • mantis
    Excellent clean advice.
    Dan
  • mantis
    madmax wrote: »
    And waste your money you will. Dude spend your money elsewhere if you want better performance like room treatments or better quality amps.
    Rule of thumb with wire is follow the American wire standard with gauge and length. Get good quality wire with proper termination. Once you achieve the ability to send the signal from A to B correctly , nothing can improve it.
    Dan
  • mantis
    disneyjoe7 wrote: »
    I would gladly host this even as I can bring a wealth of different in wall cables. I challenge anyone to bring anything they want.
    We can have some rear channel speakers in a home theater room and change out the wire for a Blind listening test. Most of you will be shocked as I have done this more times then I probably should have. For years I craved the highest end wire my wallet could afford. My cravings have changed once I learned the truth.
    Dan
