Building 400 wpc Tube Monoblocks....
    nooshinjohn Posts: 25,128
    edited November 2010
    But I am not as thrilled with them as I had hoped. they are "on-spec" but they are rather small in size. They are 450v/470uf 105c Panasonics, but I am thinking of getting some Italian-made Kendeil's of the same values. They are, I have learned, the same brand of Cap used by Krell and a few other very high-end brands. Any input on this?
  • zingo
    zingo Posts: 11,258
    I have used the Ruby Gold caps on my tube amps before with good success. Whether they would be better than the Panasonics, I don't know; but it's something different.
    thanks Zingo... I don't see that the Ruby's are availble in the range that I need, but I will keep looking.
  • zingo
    zingo Posts: 11,258
  • Face
    Face Posts: 14,340
    There's always Jensen and Mundorf.
    Here is the specsheet for the ones I have...
    http://www.panasonic.com/industrial/electronic-components/parametric-search.aspx?src=/www-cgi/jvcr21pz.cgi?E%2BPZ%2B3%2BABA0033%2B4%2B%2BAM
    I may be wrong on this, but these seem a bit weak given the application. These are what I am thinking about...
    http://www.kendeil.com/doc/K02/K02450471__M0G079.pdf
  • Face
    Face Posts: 14,340
    The Panasonic link gives 400+ results.
    looks like the link is no good... here are the specs for the Panasonic
    SMD Not SMD
    Body shape Snap-in type (2 terminal, terminal length=4.0mm)
    Polarty type Polar
    Rated voltage 450 (V)
    Capacitance 470 (micro F)
    Tolerance on capacitance -20 to 20 (%)
    Tangent of loss angle(max.) 0.2
    Leakage current(max.) 1379 (micro A)
    Category temperature range -25 to 105 (Cel)
    Body diameter 30 (mm)
    Body length 50 (mm)
    Lead(terminal) pitch 10 (mm)
    Rated ripple current-1(freq.) 120 (Hz)
    Rated ripple current-1 1740 (mA)
    Rated ripple current-1(unit) mA r.m.s.(root mean square)
    Impedance-1(frequency) −
    Impedance-1(max. value) −
    E.S.R.-2(freq.) −
    E.S.R.-2(max. value) −
    Endurance 2000 (h)
    Forming & packaging feature Bulk(no lead/terminal forming)
    Appearance Sheathinges other than a P.V.C. sleeve(metal case)
    Quantity(min. packaging unit) 100 (PCS.)
    I have selected ViaBlue Tri-Absorbers to be used as feet for my amps...
    http://www.viablue.de/com/absorber_tri_black.shtml
    I think for the money spent, that these should be a beautiful addition to the Statements.:cool:
  • AudioGenics
    AudioGenics Posts: 2,567
    incredible
    parts and inventory lists for the space shuttle...
    The first tube, test fit through the granite deck... The effect is even more stunning in person.
    478.JPG 103.3K
    483.JPG 97.9K
    482.JPG 109.4K
    479.JPG 116.9K
    EndersShadow Posts: 17,543
    looking good....
    Thanks man! I should have the 12ax7's and the feet next week.
  • SolidSqual
    SolidSqual Posts: 5,218
    Where's the solder?
    SolidSqual wrote: »
    Where's the solder?
    The wiring begins next week.:smile:
    edited December 2010
    OK guys... another update. The wiring has been pretty straightforward, and looks pretty good. I just recieved the KT120's today, so final positioning and bonding the granite to the chassis will be getting done sometime this week, and I am working up a parts list for ordering the smaller caps and resistors and such that I will need to finish the wiring.
    The bottom plates and the wood inserts for the sides are being cut this week as well. I have chosen Chinese Burled Elm, mirror matched for the sides.
    More pics to follow, so stay tuned!
  • ecod123
    ecod123 Posts: 379
    John,
    Looking real good!!
    Those Viablue feets are great looking. Where are you ordering yours from?
    And for some updated pictures...
    tonyb Posts: 32,908
    Holy crap John, those look awesome. Can't wait to see the finished product.
  • zingo
    zingo Posts: 11,258
  • kawizx9r
    kawizx9r Posts: 5,150
    Looks sexy!
    You're not going to run those tubes though when you first fire it up are you? :eek:
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    They look phenomenal (my favorite and most overused word according to the wife). Now that I am able to drive I may have to come up for a visit in the next week or so to see them in person. I promise I will bring my own rag to wipe the drool from my face. :tongue::wink::biggrin:
    Just so I know would Saturdays work ok for a visit (dont have a particular one in mind as of yet, and provided you dont mind company)? My wife works on that day so she wouldnt mind if I go missing for a couple hours to drive up and hang out. PM me to let me know so this post stays clean :biggrin:
  • steveinaz
    steveinaz Posts: 19,522
    Very cool, it's coming together pretty quick!
    Thanks again guys for the encouragement. I have another 6 weeks or so worth of work before I have them completed, and then they will be inspected by the Man before I plug them in for the first time. I can't wait to finally hear them sing.
    Packing them up is a huge concern of mine, and I have already begun work on designing their packaging. This task is almost as big a pain in the **** as working out the parts list was....
  • SolidSqual
    John get foam inserts for the packaging with wood paneling. I got amps from Quicksilver recently with this kind of packaging at it is amazing.
    F1nut Posts: 49,855
    Why would you do that?
    Until now, I was intimidated by the thought of redoing my 'xovers in my SDA's.:eek:
    It is probably best to let BC go through them first. I do not want to take down the power grid on the East Coast when I plug them in.:smile:
    Here are a few pictures of the bottom plate amd the wood side panels. They are both nekkid for now. The bottom plate will have a screen over the ventilation holes to prevent things from getting inside.
    edited January 2011
    Got all the parts, minus transformers, together finally. These are the final mock-up pics before final assembly.:biggrin:
    txcoastal1 Posts: 13,134
    edited January 2011
    beautiful...do you have an estimated completion date...I think most of us are almost as excided as you are
