Building 400 wpc Tube Monoblocks....
But I am not as thrilled with them as I had hoped. they are "on-spec" but they are rather small in size. They are 450v/470uf 105c Panasonics, but I am thinking of getting some Italian-made Kendeil's of the same values. They are, I have learned, the same brand of Cap used by Krell and a few other very high-end brands. Any input on this?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I have used the Ruby Gold caps on my tube amps before with good success. Whether they would be better than the Panasonics, I don't know; but it's something different.
thanks Zingo... I don't see that the Ruby's are availble in the range that I need, but I will keep looking.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Rubycon if you don't mind ordering from the Brits"
http://modulusamplification.com/CAPACITOR-CAN-470uf-450v-SNAP-IN-RUBYCON-P680733.aspx
There's always Jensen and Mundorf."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Here is the specsheet for the ones I have...
http://www.panasonic.com/industrial/electronic-components/parametric-search.aspx?src=/www-cgi/jvcr21pz.cgi?E%2BPZ%2B3%2BABA0033%2B4%2B%2BAM
I may be wrong on this, but these seem a bit weak given the application. These are what I am thinking about...
http://www.kendeil.com/doc/K02/K02450471__M0G079.pdfThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
The Panasonic link gives 400+ results."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
looks like the link is no good... here are the specs for the Panasonic
SMD Not SMD
Body shape Snap-in type (2 terminal, terminal length=4.0mm)
Polarty type Polar
Rated voltage 450 (V)
Capacitance 470 (micro F)
Tolerance on capacitance -20 to 20 (%)
Tangent of loss angle(max.) 0.2
Leakage current(max.) 1379 (micro A)
Category temperature range -25 to 105 (Cel)
Body diameter 30 (mm)
Body length 50 (mm)
Lead(terminal) pitch 10 (mm)
Rated ripple current-1(freq.) 120 (Hz)
Rated ripple current-1 1740 (mA)
Rated ripple current-1(unit) mA r.m.s.(root mean square)
Impedance-1(frequency) −
Impedance-1(max. value) −
E.S.R.-2(freq.) −
E.S.R.-2(max. value) −
Endurance 2000 (h)
Forming & packaging feature Bulk(no lead/terminal forming)
Appearance Sheathinges other than a P.V.C. sleeve(metal case)
Quantity(min. packaging unit) 100 (PCS.)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I have selected ViaBlue Tri-Absorbers to be used as feet for my amps...
http://www.viablue.de/com/absorber_tri_black.shtml
I think for the money spent, that these should be a beautiful addition to the Statements.:cool:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
incredible
parts and inventory lists for the space shuttle... -
The first tube, test fit through the granite deck... The effect is even more stunning in person.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
looking good...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Thanks man! I should have the 12ax7's and the feet next week.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Where's the solder?
OK guys... another update. The wiring has been pretty straightforward, and looks pretty good. I just recieved the KT120's today, so final positioning and bonding the granite to the chassis will be getting done sometime this week, and I am working up a parts list for ordering the smaller caps and resistors and such that I will need to finish the wiring.
The bottom plates and the wood inserts for the sides are being cut this week as well. I have chosen Chinese Burled Elm, mirror matched for the sides.
More pics to follow, so stay tuned!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
John,
Looking real good!!
Those Viablue feets are great looking. Where are you ordering yours from? -
And for some updated pictures...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Holy crap John, those look awesome. Can't wait to see the finished product.HT SYSTEM-
lsi 9's -
Looks sexy!
You're not going to run those tubes though when you first fire it up are you? :eek:Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
They look phenomenal (my favorite and most overused word according to the wife). Now that I am able to drive I may have to come up for a visit in the next week or so to see them in person. I promise I will bring my own rag to wipe the drool from my face.
:biggrin:
Just so I know would Saturdays work ok for a visit (dont have a particular one in mind as of yet, and provided you dont mind company)? My wife works on that day so she wouldnt mind if I go missing for a couple hours to drive up and hang out. PM me to let me know so this post stays clean :biggrin:"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Very cool, it's coming together pretty quick!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thanks again guys for the encouragement. I have another 6 weeks or so worth of work before I have them completed, and then they will be inspected by the Man before I plug them in for the first time. I can't wait to finally hear them sing.
Packing them up is a huge concern of mine, and I have already begun work on designing their packaging. This task is almost as big a pain in the **** as working out the parts list was....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
John get foam inserts for the packaging with wood paneling. I got amps from Quicksilver recently with this kind of packaging at it is amazing.
Why would you do that?Political Correctness'.........defined
President of Club Polk -
Until now, I was intimidated by the thought of redoing my 'xovers in my SDA's.:eek:
It is probably best to let BC go through them first. I do not want to take down the power grid on the East Coast when I plug them in.
Here are a few pictures of the bottom plate amd the wood side panels. They are both nekkid for now. The bottom plate will have a screen over the ventilation holes to prevent things from getting inside.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Got all the parts, minus transformers, together finally. These are the final mock-up pics before final assembly.:biggrin:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
beautiful...do you have an estimated completion date...I think most of us are almost as excided as you are2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
