Popping noise from Monitor 70s
mole'
mole' Posts: 3,160
edited September 2010 in Speakers
i just picked up a set of used Monitor 70s in good condition from grimmace19.
i hooked them up to my Brand new Denon 2311ci into my front channel. i used the same speaker wires i had hooked up on my Monitor 50. i moved the M50 to the rear.
i played a movie and watch some tv (Direct TV) and noticed a popping noise coming from my speakers. i did a lil trouble shooting and noticed it was the M70s. i unhooked all my other speakers just to make sure. i swapped the M50 back as there were before and no popping from them.
i tried different wires and still get the popping from the M70s. i swapped them from left to right and still the same thing.
i contacted grimmace19 just to make sure he did not have the same issues and he did not. he stated the boxes were in good condition and the foam was too.
the boxes came a lil beat up and the foam did not look good.
now both speakers are making the same popping noise at higher volume, so make it could be from my Denon?
any input please????
mole'
Post edited by mole' on
«1345
    F1nut Posts: 51,693
    edited July 2010
    The Denon may not have the grunt needed to drive the speakers properly. Not only are the drivers larger, there 2 additional drivers per cabinet. What did grimmace19 power them with?
  • mole'
    mole' Posts: 3,160
    edited July 2010
    that i dont know.
    will find out tho
    mole'
  • grimmace19
    grimmace19 Posts: 1,429
    edited July 2010
    I had them on a Yamaha 565 nothing substantial but also never had any issues. I might not have been driving them hard compared to mole' either... not sure.
  • mole'
    mole' Posts: 3,160
    edited July 2010
    -80.5 to + 7.5 dB is the volume on my AVR
    anything above -10.0 is when it starts to pop
    mole'
  • grimmace19
    edited July 2010
    Guess I never drove the yamaha that far. Anything above -20 got to a volume I didn't care to listen at. How many watts is the denon you are using?
  • mole'
    mole' Posts: 3,160
    edited July 2010
    grimmace19 wrote: »
    735
    2311ci
    mole'
    F1nut Posts: 51,693
    edited July 2010
    mole' wrote: »
    That's too high, turn it down.
    735
    Yeah, right. It's rated at 105wpc and I guarantee it's not even close to that. A big clue is that it only weights 24lbs, which means it doesn't have a beefy power supply. Hell, I've got a CDP that weighs over twice that.
    Even if it did put out a real super clean 105wpc with your 89dB efficient speakers, theoretically...
    89dB = 1 watt
    91dB = 2 watts
    94dB = 4 watts
    97dB = 8 watts
    100dB = 16 watts
    103dB = 32 watts
    105dB = 64 watts
    108dB = 128 watts
    In reality, I doubt you'll get an SLP level higher than 105dB before clipping.
  • mole'
    mole' Posts: 3,160
    edited July 2010
    im new to this stuff and still learning
    mole'
    F1nut Posts: 51,693
    edited July 2010
    I realize that and that's why I'm helping you to understand.
  • mole'
    mole' Posts: 3,160
    edited July 2010
    thanks
    mole'
    F1nut Posts: 51,693
    edited July 2010
    The good news is that your AVR has pre amp outputs, which means you can add an external power amp, if you so desired.
  • mole'
    mole' Posts: 3,160
    edited July 2010
    IT DOES?
    i know it has the sub pre outs, but i did not see the Amp pre outs
    please school me
    mole'
    F1nut Posts: 51,693
    edited July 2010
    Eh, you're right. I didn't notice that the pre outs are for subs. Sorry.
  • mole'
    mole' Posts: 3,160
    edited July 2010
    DAMN!
    i was so hoping i was wrong
    i picked up an Adcom GFA-545 MKII, B&K Ref 10 Pre Amp and an Acurus A200x3
    so ill figure out what works best and go from there.
    mole'
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited July 2010
    mole', which DirecTv box do you have?
    Some of those have had some audio issues in the past. How is it connected to your Denon? (Digital coax, optical, HDMI, etc.)
    Next question, does it do this when watching/listening to another source? (cd, dvd, etc.)
  • mole'
    mole' Posts: 3,160
    edited July 2010
    its the new Direct TV HD/DVR boxes. the front is like a touch screen.
    i have everything hooked up to the Denon VIA gold tipped HDMI cables.
    so far i think it has only been from watching DTV, also when watching DTV the volume will cutout for a few seconds and then come back.
    mole'
  • LessisNevermore
    edited July 2010
    mole' wrote: »
    I'm assuming you are running the audio through HDMI, yes?
    If you have an optical audio cable around,(if not, pick one up tomorrow) try one of those for the audio. Leave the HDMI in place for the video though. Don't forget to enable the optical out in the menu settings of your DTV receiver. I'm thinking this is likely an HDMI issue. (fingers crossed)
    By using the optical for the DTV box, you won't be degrading the sound quality by bypassing the HDMI cable.
  • mole'
    mole' Posts: 3,160
    edited July 2010
    im only using the HDMIs at this point. ill pick up an optical cable and see if that helps. should i try using another HDMI cable?
    BTW
    thanks for your time and help
    mole'
  • LessisNevermore
    edited July 2010
    mole' wrote: »
    BTW
    Couldn't hurt.....
    You're welcome, hope it works out so you can get on with enjoying your new toys.
  • LessisNevermore
    edited July 2010
  • mole'
    mole' Posts: 3,160
    edited July 2010
    Nope, I have some of these. They are very nicely built and have the correct connector. (Toslink)
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10229&cs_id=1022901&p_id=2763&seq=1&format=2
    awesome.....
    $7 for 15' of it.
    mole'
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited July 2010
    mole' wrote: »
    It might not be your speakers. Perhaps it's your eardrums. ;)
  • mdaudioguy
    edited July 2010
    mole' wrote: »
    Best go with those if you're looking for high volume.
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited July 2010
    Only source that causes this is the DirecTv box, via HDMI? Yeah I'd try different sources and I'd also run a coaxial or optical digital signal out of the DTV box for sound. My guess is that it isn't the speakers or the receiver's amps.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • mole'
    mole' Posts: 3,160
    edited July 2010
    mdaudioguy wrote: »
    i do have a lil bit of hearing loss from my time in the NAVY
    mole'
  • mole'
    mole' Posts: 3,160
    edited July 2010
    mdaudioguy wrote: »
    i picked up all 3 of them. looking at upgraded the AVR now too.
    mole'
  • mole'
    mole' Posts: 3,160
    edited July 2010
    i just ordered a optical cable for my TV last night. so i hope that helps out
    mole'
    F1nut Posts: 51,693
    edited July 2010
    How did we get from the volume level being too high to cables? If you don't get the popping with the M50's, it's not a cable/DirecTv box issue.
  • mole'
    mole' Posts: 3,160
    edited July 2010
    ya im seeing that now. i just got off the phone with Denon. i tried all the trouble shooting they said to do.
    long story short, they said its the speakers (Monitor 70s)
    mole'
