Hardware Rings for your Passives and MW6XXX
16781012
    Toolfan66 Posts: 18,069
    edited July 2010
    Guys I need a week to get caught up here at work and I will start another run.. I am getting hit up in my PM box as well.
    Thanks,
    Larry.
  • muncybob
    muncybob Posts: 3,242
    edited July 2010
    That's what you get for taking a vacation!! :)
    Yep, my name really is Bob.
  • Janne
    Janne Posts: 139
    edited July 2010
    toucanet wrote: »
    If anyone changes there mind on rings for 1.2TLs, I will take them... since I am late to the party again.
    Dream on! My rings just left Anchorage Alaska on its way to Shanghai. I had some initial problems with Larry's Export department but after he stepped in and straightened up the staff things are running smooth :D
    Just found out when stripping the sides of my 1.2TL's that they were built by the lovely Mollie Jones at Polk. Probably Assembler of the year judging by the exceptional build quality :) The speakers have now traveled a total of 12079 miles from Baltimore-Riyadh-Bangkok-Shanghai. Still in mint condition.
    HT/2 CH
    McIntosh MX120, MC500, MC206, MEN220
    polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
    MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect.
  • toucanet
    toucanet Posts: 581
    edited July 2010
    Janne wrote: »
    Dream on!
    Go ahead and rub it in... I can take it:(
    Something good will come my way:D
    On another matter, how does your McIntosh Mc500s sound with your 1.2TLs?
    I've never listened to McIntosh products but continue to hear wonderful things about them.
    Just curious.
  • Janne
    Janne Posts: 139
    edited July 2010
    toucanet wrote: »
    Janne wrote: »
    Dream on!
    Just curious.
    Unfortunately I have only had two different amps powering the 1.2TL’s. The first one was a 200 W Denon POA-2800 that kept popping tweeters. It was not a bad amp at normal listening levels but obviously did not have the power reserves and soft clipping like the MC500 for late night duty. What I like with the McIntosh is that it’s built like a tank. There are no compromises and while other companies can squeeze out 500W from half the weight this one need 110 lbs of components. People with more experience than me says it has no sonic signature and due to its weight it's also not equipment you bring over to your friends house and compare to his gear. It drives my 1.2TL’s effortlessly at any volume and when it clips, the sound level is insane but crystal clear. :p
    HT/2 CH
  • blair6878
    blair6878 Posts: 4
    edited July 2010
    Hi, At lower listing levels, did you notice any tangible difference between the 2800 and your new MC500? Another way to ask, would be...did you notice any sonic signature with the 2800? Thanks for any info.
    Janne wrote: »
    toucanet wrote: »
    The first one was a 200 W Denon POA-2800 that kept popping tweeters. It was not a bad amp at normal listening levels but obviously did not have the power reserves and soft clipping like the MC500 for late night duty. :p
  • mrpete64
    mrpete64 Posts: 4
    edited July 2010
    How do I purchase these rings for my speakers?
    edited July 2010
    What speakers do you have first of all??
  • audiobilly
    audiobilly Posts: 351
    edited July 2010
    There is a "For Sale" thread in the Flea Market section of this forum.
    Go Here,
    http://www.polkaudio.com/forums/showthread.php?t=104705
    mrpete64 wrote: »
  • thejck
    thejck Posts: 849
    edited September 2010
    Whats the safest way to pull the existing threaded inserts out of the wood in order to install the rings?
    Use an Allen wrench, they will screw out..
  • thejck
    thejck Posts: 849
  • hutley58
    hutley58 Posts: 3
    edited February 2011
    am i too late to get in on these rings for my 2a's?
    YEP!!!! I don't have anymore!!!!
    F1nut Posts: 51,789
    Time for another run.
    pitdogg2 Posts: 27,064
    and tweeter brackets also.
    I should of bought both when i bought rings but only had the cash for rings
  • PolkMaster1
    PolkMaster1 Posts: 847
    Dont forget to count me in!
    Tweeter brackets and rings for the SDA-SRS 1.2 TLs is what I'm looking for.
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
    It will be awhile as the shop is bursting at the seams with work. I have a project I'm trying to get done for Ben and I told Mark he would be first on the list for rings for his CRS+'s..
    In do time but right now I just can't do it..:frown:
  • george daniel
    george daniel Posts: 12,096
    a GOOD REASON FOR YA'LL (newbees and ringless SDA owners)to hang around and contribute,,, that way you'll know when the rings become available again,, a "must have" for serious SDA owners.
    heiney9 Posts: 25,445
    I'll sell my set for $1K.................supply and demand right :wink:.
    <JK>
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Larry,dibs on a full set of rings,including tweeter brackets for a pair of 1C's...and an additional set for a pair of CRS's...I took a little time off from all things Audio,and missed out on the original run....my bad.
    Thanks,Mike
  • adcomcyclone
    adcomcyclone Posts: 49
    Hello, I am new to the forum, but just picked up a set of SDA SRS and am interested in getting a set of the rings and tweeter brackets. I called Polk to order some replacement MW6503's and the rep on the phone even suggested looking into this!
    I will keep an eye out on this thread, but please let me know when they will be available. Thanks!
    Polk SDA SRS, Nakamichi Pa-5 Preamp, PA-7 Amp, Shenda (Jolida) SD100S CD Player (Sylvania Gold Brand 5751 & Amperex Holland, Orange Globe 12au7 tubes).
    Home Theatre
    Onkyo SR707, Samsung Blu Ray,Sony 400 Disc DVD Changer, Sony 46" LCD (Model?)
    Speakers: Front L/R: JBL L7, Center: JBL LC1, Surround: TBD (likely JBL L1)
    Car: Clarion 9255-DRX, Adcom GFA 4702, GFA 4404, Pioneer TS-A1702c (Front and Rear), 2 Boston Acoustics 12.5LF subs
  • dcoil
    dcoil Posts: 153
    Hi AC and welcome to the forum. Look up the mods for these speakers. I am just finishing up, but the improvement in sound quality of my SRS is simply amazing :biggrin: I did the rings, the XO'r and the tweeters. It is truly hard to describe the improvement. I'll be doing a review once I complete the upgrades.
    By the way, you should be getting a 20% discount on the speakers from Polk since you're a CP member.
    SDA SRS modded: X’ovrd, de-polyed, inductorized, interconnectorized, re-posted, dynamited, RDO’d, spiked, gasketed, ringed (Larry's), and grill cloth blinged! Done this on my own? Not a chance. Thanks to Raife and all who forged easy to follow upgrades. At least a 100% improvement in sound and my personal listening pleasure! :cheesygrin:Pass XP-10 preamp, Parasound A21 amp, Pioneer Elite DV-58AV (Ric Shultz modded), Audioquest Sky IC's, No longer need my Sunfire sub after mods...
  • adcomcyclone
    dcoil wrote: »
    Dcoil, thanks!
    I have been looking at all the mods...lots to do! The ones I got are a little rough cosmetically, but were functional. Going to get them cosmetically sound and go from there with tweets and xover. I did get the 20% discount for the drivers I ordered. Still have to get an amp too....
    Don't want to hijack the thread, but just removed side panels and removing the wood strips to replace grill cloth, then remove tops/bottoms (cracks starting down center of both). Strip side panels and finish all wood to match TV console.
    Home Theatre
  • JimAckley
    JimAckley Posts: 1,138
    I should probably be shunned for asking, but do you think it's possible to have some made for my JBL W15GTi subwoofers? I completely understand if I big "NO!" :biggrin:
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
    nooshinjohn Posts: 25,931
    Janne wrote: »
    Just found out when stripping the sides of my 1.2TL's that they were built by the lovely Mollie Jones...
    Is she still married to Desmond?:tongue:
    Obla-di, Obla-Da, life goes on...
    I ran a few more rings I have PM'ed the guys above and I will give them first dibs to be fair!!
    Larry.
  • Cosmic_American
    Cosmic_American Posts: 114
    I'd love a set for my CRS+ if there's any leftover.
    Thanks,
    Ryan
    2 channel:
    SDA CRS+
    Harman Kardon HK 3490
    Music Hall mmf-2.2
  • PolkMaster1
    :biggrin: Put me on your list Tool as I have been bugging you for several months for rings and brackets for my 1.2TLs. :biggrin:
  • adcomcyclone
    Larry, PM sent back. Let me know cost for SDA SRS set and Paypal email address.
    Home Theatre
