emotiva xpa5
w_coyote
w_coyote Posts: 66
edited December 2009 in Electronics
I'm thinking about purchasing the emotiva xpa5 amp and was wondering what everyones thoughts were about this amp. Good or bad. I know this is all subjective but was wondering. My equipment is a sony 40v3000,denon 988,sony bdp-s300,comcast cable box and i have both klipsch(rf82,rc62,rb61) and polk speakers(rt55ix4,cs400ix2). This will be used for mostly HT. Thanks in advance and don't hold anything back. And Begin
Post edited by w_coyote on
«13456789
  • bklynNupe
    bklynNupe Posts: 728
    edited November 2009
    w_coyote wrote: »
    Search xpa5 on this forum and you will have a phone book worth of info.:)
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
    nooshinjohn Posts: 25,906
    A search of the forum will reveal a wealth of information about this amp. My opinion is that it is a decent entry level amp, but for the money you could find much better gear if you are willing to try pre-owned. The Rotel RMB-1095 and Sunfire Cinema Grand come to mind...
    Do not let the fanboys of any brand convince you to spend your money. Do your homework and let your ears decide.
  • suprafantx
    suprafantx Posts: 249
    I saw you have Denon 988 so XPA-5 may work well with your system. I used to have Denon 988 and XPA-5 power LSi series speakers and I like it alot.
    Living room
    Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
    Player: Oppo 95.
    Amps: Bryston 4B SST, B&K Ref 200.7 S2.
    Pres: B&K Ref 50 S2, Paraound P5.
    Subs: Dual Rythmik F15HP subs.
    Man Cave
    Speakers: Martin Logan Vistas.
    Player: OPPO 105.
    Preamp: B&K Ref 50 S2.
    Amp: B&K Ref 125.2 S2
    Sub: Rythmik F12.
    Sub management: SMS-1.
    Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
    Room treatment: GIK Room Kit #1.
  • TroyD
    TroyD Posts: 13,124
    I spit on Emotiva.
    BDT
  • dkg999
    dkg999 Posts: 5,647
    TroyD wrote: »
    I spit on Emotiva.
    BDT
    After it bursts into flames spitting will help, but a good fire extinguisher is recommended.
    DKG999
  • mmadden28
    mmadden28 Posts: 4,283
    w_coyote wrote: »
    There is nothing wrong with the XPA-5--Sounds awesome in my setup. Is there better out there--I'm sure, but it is certainly no slouch.
    Bottom line-If you're looking for Emotiva advice, ClubPolk is NOT the place to look for it.
    ____________________
    Pool: Atrium 60's/45's
  • thuffman03
    thuffman03 Posts: 1,325
    I never heard an Emotiva amp but it would not cost you much to try one and see for your self. Last time I looked they had a 30 money back so you would only loose your cost of shipping.
    Though if you want to go with an amp that has been around for years I would look at Sunfire, Adcom and Rotel. With some looking on eBay and Audiogon you can pick up a used amp for the same price as the Emotiva.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • w_coyote
    w_coyote Posts: 66
    Ok, thanks for all of your thoughts. I forgot about the search feature,thanks. I haven't done anything yet and I am looking on audiogon and craigslist but was just curious what everyone thought. I'm in no hurry and will keep looking. Thanks for all your replies.
  • concealer404
    concealer404 Posts: 7,440
    I think it's a decent buy on the new market for HT, that's for sure. And as mentioned, if you don't like it, send it back.
    I think if you're open to used stuff, you can get quite a bit better for your dollar, though. Thuffman threw out some good suggestions. :)
  • PSOVLSK
    PSOVLSK Posts: 5,379
    I'm very happy with mine, but I probably wouldn't pay full price for one. If you can pick up a used one, I think it's a good buy.
    As mmadden mentioned, Club Polk is not the best place to get information about Emotiva. Not a lot of middle ground info. You either get those who love it and think it's the best amp you could ever hope to own regardless of price (which it isn't) OR you get those who say it is a total piece of junk (which it isn't). I don't have tons of experience with amps, but IMO it's probably one of the better entry level amps.
  • Montoya
    Montoya Posts: 506
    If you are looking for a cheap amp and you have to buy new it is a great choice. But if you want quality and are willing to take the risk of buying used the choice of better products is endless in the 700-800 price range. From my experience with the XPA-5 I would have to say it is a good amp for the going price when not compairing it to used market. It is not by any means a giant killer as some here would have you beleive. The amp suffers from higher background noise than other amps I have used and the transformer has some light audible hum also the RCA jacks are not the best I have bent two and the amp has only been moved twice.
  • TroyD
    TroyD Posts: 13,124
    I think you will find that it's not so much that people think Emotiva is crap.....it's that there are a few folks who take offense to the notion that there are better alternatives.
    BDT
  • concealer404
    TroyD wrote: »
    BDT
    And those folks ruin the brand for the rest of us.
    If the OP tries it, and loves it, that's great! Nobody here will hold that against you. It's when we're told that it's better than what we have, hands down, is where the **** hits the fan. ;)
  • suprafantx
    I love fire ants because when I piss on their mount they run around like crazy and spit out my urine.
    Living room
    Player: Oppo 95.
    Man Cave
    Player: OPPO 105.
    Sub: Rythmik F12.
  • Montoya
    Montoya Posts: 506
    I have a problem with people trying to push the product off as if it is the second coming. I own one and I think it is a great amp but I wouldn't put it in the same league as some of the other mid-fi amps I recently tried and a few I currently own. I put the XPA-5 in my 2-channel setup and thought it was o.k. but not as good as my rotel rb-1080 much less my 500watt mono blocs which would blow it out of the water. My Roksan ka/2 is also a better amp period but some people here would argue that until they turn blue even though the majority of them have never done comparisons. I know from reading post that the larger majority of people who own Emo products are first time buyers so how can they justify that amp A is better than amp B when they have never tried other products?
  • TroyD
    TroyD Posts: 13,124
    Montoya wrote: »
    Nail, head, hit....
    Well said, brother, well said.
    BDT
  • PSOVLSK
    Montoya wrote: »
    Can we just insert this post into every Emo thread from here on out?
    As TroyD has already pointed out, well said!!
    I really like my XPA-5. It's a big step up from my AVR (an H/K 7300) and it's a decent step up from my Adcom 6000 (a lower level Adcom), but it's not, as Montoya said, "the second coming."
  • WilliamM2
    WilliamM2 Posts: 4,807
    The XPA-5 is $100 off with the sale that started today. Might make your choice easier.
    http://emotiva.com/shop/cart.php?m=product_list&c=3
  • speakergeek
    speakergeek Posts: 555
    The XPA-5 is a good amplifier. It does a great job on both HT and music. You can pick one up for $699.
    F1nut Posts: 51,737
    The crux of the biscuit.
  • PSOVLSK
    Montoya wrote: »
    The amp suffers from higher background noise than other amps I have used.
    I've experienced this also and it's really my only complaint with the amp. When I'm listening to music or watching a movie at normal or higher levels, I never notice it. It's only when I listen at very low levels...but it drives me nuts on those few occasions when I can hear it.
    $100 off does make it more appealing.
  • sdcfan18
    sdcfan18 Posts: 95
    Add me to the list of people that enjoy Emo products. Fits nicely in my HT and great for 2 channel.
    HT RIG
    DISPLAY - Samsung 50A550 Plasma
    MAINS - polkaudio RTi10
    CENTER - polkaudio CSiA6
    REARS - polkaudio M20
    SUB - D-Box David 303 (looking into SVS & Velo)
    AVR - Yamaha HTR-6190
    AMP - Emotiva XPA-3 (:D)
    SAT/PVR - Bell HD 6141 1TB HDD
    BluRay - 60G PS3
    DVD - Pioneer 490-V (1080i upconverting)
    POWER - Belkin PF31
    REMOTE - Harmony 880
    PICTURES HERE
    A wise man once said "Friends don't let friends buy Bose"
    I will never buy one... I heard that my homeowner's policy will not cover my house for fire if one comes into my home.
  • PSOVLSK
    Lucky for me, my homeowners policy does cover this. Equally lucky, I haven't had to use it...yet.
  • speakergeek
    sdcfan18 wrote: »
    Me too. Very pleased with it's performance. I'd gladly pay twice as much for the XPA-5. For $799 it's a great deal (but it's on sale for 699 which is even better). Did I mention it does a great job on music as well?:D
  • w_coyote
    w_coyote Posts: 66
    Man, didn't know I was stirring the hornets nest but was just curious. This is not my first amp. My first amp is the one I have now (adcom 5503) which works great and I'm happy with it but it has developed some stactic on the right side (not bad but it's there). I was thinking of getting it repaired but also thought I could take the money for the repair(don't know how much that will be yet) and put alittle with it and maybe get something better. Then I could get the repair done at a later time. That was what I was thinking when I asked the question but like I said I'm in no hurry and I'll keep looking and see if I can find something better thats not going to cost a fortune. Who knows maybe I'll get lucky but if not I can always have the adcom 5503 repaired. Thanks again for everyones replies
    Toolfan66 Posts: 18,031
    I say get it fixed and keep the adcom.
  • PSOVLSK
    w_coyote wrote: »
    This is the most civil, level-headed Emo threads I've ever seen:p:D
    I might tend to agree with TOOLFORLIFE. I don't know how the Adcom 5503 compares to the 6000, but the difference between my XPA-5 and my Adcom 6000 were not what I would describe as night and day. I guess it might depend on how much the repair would cost.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    I really like my xpa5 and for the price, on the new market, i don't think it can easily be beat. At least i have not seen anything priced under $1k with 5ch @ 200w RMS/ch. Most comparable amp's are double the price and the difference in SQ (what ever it is) is not worth the extra money IMO, but it may be to you. Thankfully that is why there are many different brand's ;)
    Used is not an option for me, i don't want someone's abused gear that has no warranty. If a friend of mine had a nice piece of equipment he/she was looking to move then OK i would be more open but buying from a person i have never met and in a completely different place, nah ah :o I like peace of mind and good value for dollar, i happen to be getting both right now.
    Ya know funny thing i have never seen any Emotiva owner claim that their amp is the best, be all, end all. Just that they are a great product for the price....
    I get no background noise through mine, if you have trouble with "bending" the RCA jack's maybe you could try to unplug them before moving the unit? I made the same mistake once after a few beer's and had to straighten out a jack on my Yammie lol
    When i am able to afford better gear i'll explore other option's :)
    For the record: Yes this was my first separate amp purchase. But that does not make my ear's any more deaf than your's haha
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • buymesome
    buymesome Posts: 281
    This guy just wants a fight
    Anyways I never knew about this background noise problem and thought the amps just lacked authority in the balance of the lows . Well I guess emo can suck it and I will unsubscribe myself from the mailing list
