SDA SRS 1.2TL just acquired
24
    nooshinjohn Posts: 25,929
    edited June 2009
    Sure it is. Damping and current play a bigger role than rated wpc. However, since you have no problems, then other issues are the more likely cause. Another possibility would be he's cranking the volume too high.
    True... but as I said, I run an identical amp Jesse with no problems, even when the volume is maxed out and have no control issues in my setup. It would stand to reason that he should not have issues from his amp, and drivers are most likely the cause. Phase issues could also have something to do with it, but my bet is a couple drivers need to be replaced.
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    I was pulling your chain about the 'stickler'. I would hope no one would be wanting to spray Karylin on these.
    Sorry Vmax for the derailing.
    Nathan
    I thought you must be messing with F1, no apologies neede...I needed the laugh..I am getting a bit frustrated. I know it will be worth it when I get there....
    I appreciate all the input from everyone a lot!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    vmaxer, didn't you say you had two bad tweeters when you got the speakers home?
    I still have 2 bad tweeters, working on getting a couple more SL 3000's until I can upgrade to the RDO 198-1's?? That wouldn't cause this would it?? By the way, I am now bi-amped, 405 to the tweets and 405 to the low's. No difference??
    The problem is when I am cranking the volume, but certainly not as loud as the LSi 15's have been cranked?? I am sure they should be able to put out more volume than I am able to get. I played each driver at reasonably high volumes connected directly to my speaker output and they all sounded okay???Not sure what to listen for except a difference?? The drivers all checked about the same resistance..the 6511 are about 3.5 and the 6503 are about 7.0.
    I am going to assemble the left unit and try again...I am at a loss, unless I have an amp issue??
    I am open to any ans all suggestions.:confused:
    Thanks a lot.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2009
    The tweeters that are dead are the loudest of the four in each channel. I would think that they could definitely cause your problem.
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    That would make my larger drivers pop?? By the way I swapped the bottom 2 tweetrers out, not the one not working is the very bottom one.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Face
    Face Posts: 14,340
    edited June 2009
    Are you sure there are no air leaks?
  • hearingimpared
    edited June 2009
    vmaxer wrote: »
    I'm confused. Is it the third tweeter from the top that are bad?
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    Face wrote: »
    Nope, not sure. What's the best way to check for them??
    It was, but I swapped them out with the bottom tweeter. Now the bottom tweeter is dead.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • hearingimpared
    edited June 2009
    vmaxer wrote: »
    Nope, not sure. What's the best way to check for them??.
    Press in gently on the passive radiator and hold it in. The mids should come forward and slowly return back to normal over a 2 1/2 to 3 second time period.
    vmaxer wrote: »
    Are you sure the mids are what's popping?
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    That checks out good, about 3 sec maybe a bit more or less??
    I unhooked the input for the tweets and they still pop...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    I'm going to take a break...getting too frustrated and that won't help anything.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    edited June 2009
    take a look at the outside drivers, second from the top... I had to replace these drivers before on my original set of TL's...
  • hearingimpared
    edited June 2009
    vmaxer wrote: »
    When the original owner fried the tweeter he may have fried a component on the crossover.
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    I'm about afraid to ask how to check the crossovers....But I will...
    How??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • hearingimpared
    edited June 2009
    I'm rethiinking this and the chances of both crossovers getting fried is slim. It may be that your amp can't handle the load with the fried tweeters.
    You have to replace the tweeters anyway so you may as well wait to put the new ones in to see what happens. That is unless someone else has a better idea.
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    Lasareath wrote: »
    Unscrew the crossover cover plates and remove the crossovers.
    Check for any visible damage to the caps and/or resistors.
    There is a document here someplace that will tell you what are the values you should get when testing every cap, resistor & choke of the crossovers with a ohm meter.
    I tried to locate it but I could not find it.
    Thanks, I will look for it.
    Meanwhile, I was testing and found that my interconnect cable somehow bit the dust....No continuity from blade to blade, but there is from pin to pin...
    When you have the cable hooked up (and working) which drivers should get input from the cable.
    If I unhook the speaker wires and just hook up the cable, which drivers should play??
    What ohm rating are these speakers?? I thought they were 8??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    Would the fact that these use a interconnect cable increase the chances??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited June 2009
    I think on the pin / blade, the pins only are connected. The blades are dummies.
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    Just another thought to make sure I'm not expecting too much....
    These big guys against a set of LSi 15's with upgraded crossovers by Ben....which ones should perform the best in sound quality and SPL.....
    Currently the LSi's kick the big boys ****......:eek::eek:I just have a hard time believing that this is expected and normal...I realize I have 2 bad tweeters but...........
    I don't have a lot of experience comparing speakers???
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    There is no input from one speaker to the other this way???
    Also, look at this schematic. Don't look like a dummy connection??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • george daniel
    george daniel Posts: 12,096
    edited June 2009
    I thought the blade was connected to the negative speaker terminal.
  • hearingimpared
    edited June 2009
    This is correct.
  • Polkersince85
    edited June 2009
  • hearingimpared
    edited June 2009
    To avoid confusions there is no continuity from blade to blade. The blade side of the socket is connected to the lower negative post.
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    Well, I must have other issues....If I connect the cable and disconnect the inputs from one speaker it is dead. Before it would play some from the interconnect. Now, if I connect the blades from speaker to speaker the disconnected speaker plays???
    Man is this confusing???
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    edited June 2009
    No disrespect to the LSi15's, but the 1.2TL's should completely outperform them on all levels. There are two many things going on at the moment. I suggest you get the two tweeters replaced as Hearingimpaired suggested and put everything together as though you just set them up again for the first time. It sounds as though you are chasing to many gremlins at once rather than focusing on each as a specific concern. Let's just deal with one at a time.
  • george daniel
    edited June 2009
    I think that you may need to step away from them for awhile,,sound like you are starting to chase your tail.Put em' back like they were and start resolving one issue at a time,or some type of methodical approach. Good luck.Don't take this wrong, but have you owned SDA's before,or is this you first set?
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    I agree, but the interconnect thing has me confused now.
    Thanks again
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    This is my first set,,,believe me I need a break from them, but then I am anxious to hear what they are capable of.
    Maybe a beer or two and back at it...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2009
    jerryj12 wrote: »
    Billy I have a couple of 2 channel carver amps here if you need one to test with. Let me know and I will ship you one out.
    Jerry
    Jerry,
    I've been thinking about your offer, maybe you could send the Carver Silver 9t's and Carver Amazings for comparrisons...should have them back to you before you retire:eek:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
