Try out a set of Audioquest Type 4
1246710
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited February 2009
    Have they given you an expected ship date?
    Drew
  • Erik Tracy
    Erik Tracy Posts: 4,673
    NJPOLKER wrote: »
    Drew
    My order said 'up to 4 weeks' - I'm there now and still waiting.
    I have my amp back but need either bare or bananas at the amp side to try the AQ Type 4s.
    So...if I'm near the top...just bump me down again :-(
  • Face
    Face Posts: 14,340
  • bikerboy
    bikerboy Posts: 1,231
    Hi,
    I am wrapping up my time with the cables. Who gets them next? Full report on them later. Peace and hair grease.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Erik Tracy wrote: »
    I just sunk some money to get spade to banana adapters from Audio advisor so I could try these out on my system.
    I just realized that my Onkyo won't allow connection of spades...which would pose as a slight problem. Could you point me towards the adapters you got? I searched around on audio advisor a little bit, and couldn't locate them.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • comfortablycurt
    Ok...nevermind, I think I found them. Are these it?
    http://www.audioadvisor.com/prodinfo.asp?number=AQ1002G
    Damn...I hate to have to spend 20 bucks just to demo these cables...I may reconsider this now. Don't take me off the list quite yet though.
  • NJPOLKER
    cambir wrote: »
    If possible, I would like to try these as well. I am close to bikerboy (he knows where I live...:eek:) if it would work out to pass them along. PM sent.
    Well,
    I guess your up!
    bikerboy would,could you get them to cambir?
    Drew
  • bikerboy
    Hi,
    I will pm him and let him have them next. Thanks.
    Bottlehead Eros
    CD: DIY Shigaclone
  • Erik Tracy
    Yup - those are them.
    And I need to confess a mistake.
    My order with audioadvisor was for a set of these adapters AND a set of the bare-to-banana terminators. The banana terminators are the item on back order - not the spade to banana adapters.
    I am probably going to call audioadvisor and get them to do a split shipment so I can get the adapters.
    Sorry for the confusion...
  • NJPOLKER
    Erik
    So if cambir gets them next you should be ready but the time he's finished. Let us know.
    Drew
  • Erik Tracy
    NJPOLKER wrote: »
    Erik
    Drew
    I'm good - keep me on the list after cambir.
    I called audioadvisor and had them split my shipment. Adapters will ship tomorrow - and I added a pair of Black Mamba II ICs at their special price -that's going in between my AVR and Carver amp.
    This is getting expensive! :p
  • NJPOLKER
    Maybe I should have someone who really knows what they are doing replace the existing connections. Maybe bananas all around? Or maybe putting connections on that can be easily changed out. Just an idea, and maybe a bad one!
  • comfortablycurt
    I'm still undecided here now...I really don't know if I want to spend 20 bucks on adapters to demo these...especially seeing as I probably wouldn't have any use for the adapters afterwards.
    If you wanted to change them to bananas though...I'd definitely be in still.
    Maybe some of those connectors that allow you to switch between spades or bananas would be a good idea...like you said.
    I may just end up getting those adapter things...I'm sure I'll run into another situation in the future where they'll come in handy. Maybe I can find something else to add a little weight to the order...
  • comfortablycurt
    Does anyone know what size the spades are on those cables? Leave me on the list...screw it...I'm getting the adapters. I figure they'll be handy to have around anyway.
    I'm gonna get em from parts express and weigh down the order with some Deoxit, that I've been needing to get anyway.
  • Erik Tracy
    Atta boy! :D
    I keep a box of doodads, thingamabobs, whatchamacallits, and odds and ends next to my rig....and find that I'm always diving in to get just the right dongle to hook up or adapt Box A to Box B...well - when I get my spade to banana adapters I will... :)
  • comfortablycurt
    Erik Tracy wrote: »
    Atta boy! :D
    Figures...now I can't seem to find what I need at parts express, which means I'll have to go with the ones from audio advisor, but they don't have the Deoxit that I need...which means that I'll have to place two separate orders...aaaghhh!!!
    I was going to try to find something at PE that I could use for this, but also use on my current speaker cables after I'm done with this demo, and now I don't know if anything they have will work like that or not...
    Oh well...I think there are still a few people ahead of me in the line, so I've got a little time to figure it out I guess.
  • muncybob
    muncybob Posts: 3,242
    Not sure who is keeping track of the "que" but please put me at the end! I'm trying to covince the wife I needs better cables and this would be a great way to do it!:)
    Yep, my name really is Bob.
  • thsmith
    thsmith Posts: 6,082
    Not looking to high jack this thread but I figured some of you could help me with a question on these cables.
    I am looking to try a pair of the Audioquest - Type - 4 Speaker Cable under the no frills offer.
    I am pretty sure the spades will work on my Polk SDA 1Cs but I am not sure about spades working on my Carver TFM-45. Have any of your tried the 1/4 spades on a Carver TFM series amp?
    http://www.audioadvisor.com/prodinfo.asp?number=AQT4NF&variation=15PSPSP
    Thanks !
  • comfortablycurt
    Could we get an updated list if it's not to much trouble? I've gotta order some spade to banana adapters, and I'm wondering how soon I'm going to be needing them.
  • NJPOLKER
    OK Here is the latest
    The cables are on there way to me. Once I get them back I'll have them terminated so they will be easily used by the majority of members. Right now thinking about Vampire bananas from Sonic Craft all around.
    If anyone has other suggestions please let me know.
    Up dated list is next!
    Drew
  • NJPOLKER
    Here is how I see the updated List
    They should be re-terminated and ready to go easily by the end of the month.
    If we can get some ideas on dates that work best for each persons evaluation and live with them this will not drag on. I'm thinking about a one week minimum and a two week max. If any of you guys have any suggestions, lets hear them!
    McLoki
    comfortablycurt
    Erik Tracy
    TNRabbit
    A_Mattison
    cambir
    acsubie
    muncybob
  • comfortablycurt
    You're re-terminating them? That's awesome man. Very nice gesture.:D That should make things go a bit more smoothly.
    Why is it that so much new equipment won't accept spades? Doesn't make sense to me...:confused:
    That should be about perfect timing for me. I've got a few other upgrades on the back burner right now, and they should be taken care of by then. I want to have my system in top shape for this demo if possible.:)
  • NJPOLKER
    We are just one big happy family :eek::eek:
  • Erik Tracy
    bikerboy wrote: »
    Hi,
    Well....???? :D
  • NJPOLKER
    Erik Tracy wrote: »
    Well....???? :D
    They are coming to me for new bananas all around. I'll be sure to have them back in play shortly.
    Drew
    BTW when do you want them?
  • Erik Tracy
    NJPOLKER wrote: »
    Drew
    I'm good anytime.
    I was just teasing/prodding bikerboy in writing up that promised report...
    I got my audioadvisor spade-to-banana adapters, but it looks like I won't be needing them...still...I did verify that my amp and speakers can accept bananas....good to go! :D
    Thanks,
    Erik
  • comfortablycurt
    Erik Tracy wrote: »
    I'm good anytime.
    Thanks,
    Erik
    Well at least now you'll have a few extra things to throw in that random gadget and doodad box.
  • Erik Tracy
    Precisely!
    So, when I become not only an IC cable believer, but a cable believer as well, I can snap up an audigon deal from someone looking to sell their cable set with spades! :D
  • cambir
    cambir Posts: 1,046
    NJPOLKER wrote: »
    McLoki
    comfortablycurt
    Erik Tracy
    TNRabbit
    A_Mattison
    cambir
    acsubie
    muncybob
    NJ - go ahead and take me out of line and bump everybody up a slot. I've been too busy lately and don't think I can give the AQs the time the deserve. Besides, it might make me want to change cables...my upgraditis is currently in remission and I just can't handle another setback like that.
    Erik Tracy wrote: »
    Erik
    Might be a while...he went on vacation for a week or so.
  • comfortablycurt
    Erik Tracy wrote: »
    Precisely!
    There ya go! It's a win/win situation.
    Ahh! I can't wait to try this stuff out...I've heard so much about how awesome it is...the anticipation is killing me!:p
    I'm just hoping I can have my 2-channel rig half-**** setup by the time I get them. That way I can give them a shot in both my HT and the 2-ch. rigs.
