Overview Of Premium Cable History
124»
    F1nut Posts: 52,406
    edited April 2009
    xcapri79 wrote: »
    I'm sorry for upsetting your flat earth society.
    Ummm....you seem confused. The Flat Earth Society is a group of naysayers, like yourself.
    It is interesting and predictable how fire ants behave isn't it?
    Yes it is. Fire ants are much like any human family or group of close friends in that they will stand together to defend one another from outside threats. Isn't nature great!?!
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited April 2009
    I don't want to talk about fire ants.
    I want to talk about the apparent conflict of interest in John Dunlavy serving on an Audioholics cable naysayer panel in 2008 to beat up on poor old Pear Cable knowing all the while that he was peddling under performing, yet expensive, loudspeaker and interconnect cables as recently as 2002 (that's when DAL "folded up").
    This makes me question the credibility and motivations of the other "esteemed" experts on that AH panel.
    Your thoughts?
    heiney9 Posts: 25,711
    edited April 2009
    Xcapri all I see are a bunch of others opinions (in all your Google searches).............so how is it your version of common sense (which is based on opinion) is any more correct than our (people who believe cables matter) version of common sense. My common sense tells me if I hear a difference in certain types of cables I should invest in those if the differences are positive and rewarding to my listening experience?
    Apparently you haven't read or understood my SIG, please take the time to let that sink in.
  • DarqueKnight
    edited April 2009
    Ummmm....H9.....did you see the part where he said none of his gear has detachable power cords?
    Did you see the Audioholics reference?
    Do you think he is here to add anything constructive to the discussion?
    edited April 2009
    ^^ yes I did, but I was just trying to see if he could justify why his position is correct and the rest of our positions are wrong when all he has done is added his own as well as the other opinion references.
    It's mainly rhetorical as I don;t think he will give a sufficient answer..............because he thinks his *opinion* is the only option and he has nothing constructive add. He won;t be taking his blinders off anytime soon...........or ever I suspect.
    F1nut Posts: 52,406
    edited April 2009
    Your thoughts?
    Yes, apparent conflict indeed. It would also seem to be a matter of sour grapes on Mr. Dunlavy's part. I wonder if fire ants had anything to do with that as they do like a good leafy plant. ;)
  • dragon1952
    dragon1952 Posts: 4,942
    edited April 2009
    xcapri79 wrote: »
    You copped the attitude with your 'Easter' post. You write a condescending post trying to belittle everyone and expect no recourse? :confused:
  • DarqueKnight
    edited April 2009
    I just wish everyone could enjoy what they have and not have a conniption fit and assemble an "expert" panel to bash other people's entertainment devices.
    I mean, really, I don't think any of us would go to a crack den and give a lecture on the evils of drug abuse would we?
    By the way, this is somewhat off topic, but I just wanted you to know that I have ordered four Isoclean audio grade 1 Amp 5x20mm slow blow fuses to replace the two rail fuses in each of my JC 1 mono blocks. I replaced the JC 1's 12 Amp power line fuses a while ago and liked the improvement.
    I also ordered HiFi Tuning audio grade 0.5 Amp slow blow 6.3x32mm power line fuses for my Pass Labs line level and phono preamps. I would have preferred to have ordered Isoclean fuses for the Pass gear, but they don't make a 0.5 Amp 6.3x32mm fuse. The consensus of those who have tried both the Isoclean and the HiFi Tuning fuses is that the Isocleans are more....um...clean. One of our members up in Canada tried the HiFi Tuning fuses in some appropriate gear and really liked them.
    Review forthcoming.
  • DarqueKnight
    edited April 2009
    dragon1952 wrote: »
    Well, true to form, weren't the condescension and insults expected? Isn't what Confucious said over 2000 years ago still true today?
    "Abuse is the last refuge of the outwitted." :)
    - Confucious
    Anyway, if we can leave the trolls under the mushrooms and get back to cables...aren't these works of art?
    Figure 1. PS Audio power cable internal arrangement.
    Figure 2. PS Audio power cable internal arrangement.
    I have one of the red ones (copper only) and five of the blue ones (copper/silver). I use the red one behind my AC regenerator. A thicker and more expensive blue cable didn't sound any better than a red cable in that location.
    Such Good Sound.
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited April 2009
    QUOTE]
    They sure arrre perrtty. Niiicer look'n than new tars on a fancy car!
    Seriously, how is strain relief provided for a retrofit like this? Just add a cable tie or something? I didn't look in the back of my amp, but most mfgr installed power cables provide a degree of strain relief by having a nipple like arraingement built into the end of the cable that mates with the backplate of the device.
  • DarqueKnight
    edited April 2009
    Those connectors are 3" long and provide a measure of strain relief. After that, you're on your own. You also need 6" of clearance behind the audio component for a 90 degree bend.
  • amulford
    amulford Posts: 5,020
    edited April 2009
    I have found that snug connections are a must. With the heavy construction, it often advisable , IMHO, to allow for a little more room and provide some sort of horizontal support. YMMV
  • dorokusai
    dorokusai Posts: 25,658
    edited April 2009
    Locked until further notice....good job guys, way to be adults.
