2.1, is it still that taboo?
Upstatemax
Upstatemax Posts: 2,865
edited November 2016 in 2 Channel Audio
I found myself with the very rare Free Time this week and decided to play around with the bass management section of my P5.
I borrowed the SB2000 from my HT and brought it into my 2ch room. I was kinda hoping that I would not like it.
I set everything up and started to listen. Obviously the bass is meatier and more defined. But the Arro's came alive when I relieved them of bass duty. The midrange beefed up and vocals (especially male vocals) were on a whole new level.
Just to make sure I was not too far into my bottle of bourbon, I called my father over for more "help". We sat back down, bourbon in hand, and listened a whole lot more.
We were both in total agreement that the sub was a very welcome addition to the system. Sound stage was much more stable and the Arro's already great imaging took on a whole new life.
JJ Grey & Mofro's "This River" has never sounded so involving in my system. A tough song for the Arro's has been Anders Osborne's "Move Back to Mississippi". It's about as bass heavy as I get.
Again, the sound stage was just much better planted and everything just seemed to come together.
When I first got into this, the idea of a subwoofer in a 2ch system was about enough to get a visit from Tony and end up in the "waste management system".
Obviously this is clearly changing as a big selling point of the P5 has been its bass management. So I have to ask, what is the current feeling about a subwoofer in a 2ch system?
In the end, I don't care. I will do what sounds best for my system, but I'm just curious about other peoples experience.
Now I need to convince my wife that it's a great idea to spend the money to repair my Velodyne SPL1000 that needs a new amp...
The problem, my wife usually only has enough patience for one of my hobbies at a time and I'm building a new mountain bike over the winter. Haha.
«134
  • mdaudioguy
    mdaudioguy Posts: 5,164
    If it sounds good to you, do it!
  • kharp1
    kharp1 Posts: 3,453
    This is the exact reason I purchased a P5. I love the bookshelf/monitor sound and wanted to run one of my systems with stand mount speakers, but, didn't want to sacrifice the bass extension. I was running 2 SB2000's, however, I just got my old M&K back and seem to like it better that the svs.
  • Jaybeez
    Jaybeez Posts: 748
    I have a sub in my 2 channel listening room, to go with my Ascend Bookies. Adds just a bit of low end to fill out the total sound stage in a great way. I've listened with and without, and I'll take the former every time. As said previously, whatever sounds best is what is "right".
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
  • RamZet
    RamZet Posts: 792
    I was very anti sub.
    I played with my sub in my 2ch and ended up loving it.
    My speakers have awesome bass all on their own, but not like a Sunfire sub. I ended up setting the sub up to only cover the lowest frequencies and at alow volume level.
    The Tara-Labs subwoofer cables are nice too.
    B&W CM9Classé Sigma
  • littlewoodboats
    littlewoodboats Posts: 823
    I find my Monitor 7's midrange/midbass detail and clarity to be improved when running in a 2.1 configuration. With the RD0's and Clarity caps the 7's sound great on their own but the difference is audible when passing the lower registers to an external sub. I could not say how an active 3 way speaker might act in the same configuration. It seems the 7's lose a bit of detail when I am trying to run them in such a way as to force the lowest registers they are capable of playing. It may be Passive Radiator specific, I do not have the experience with different full range speaker systems to say one way or the others.
    As others have stated it sounds better to us as a 2.1 so that is how we leave them. With the Outlaw 975 switching from 2.0 to 2.1 is one push of a button so we have ample opportunity to compare. YMMV
  • Upstatemax
    Thanks for the feedback so far. I agree 100%, If I like it, it's what I'm going to run.
    I was amazed at how much I liked it.
  • halo
    halo Posts: 5,619
    I've got the P5 as well and I bought for its built-in DAC as well as the 2.1 bass management. I didn't need it with the Energy RC-70 floorstanding speakers but it is excellent with the Dynaudio X14s. It worked very well with the Energy RC-LCRs and the NHT SB-3 too. I was against the idea of a sub in a 2-channel set up as it felt like cheating by augmenting the low end - like using tone controls to boost the bass. After plugging in the sub I realized that this is not the case, instead, the bass that the speakers cannot reproduce on their own is filled in by the sub (or subs).
    SCompRacer Posts: 9,408
    No. :)
    Implementing a sub does not mean your main speakers are not good. The room determines whether your, for example, 20Hz-25kHz +- 1.5dB speakers will play at +-1.5dB at 20, 25 or 35Hz.
  • WTS
    WTS Posts: 170
    There's another aspect to this that sometimes gets lost in the discussion.
    Speaking as a musician whose instruments play in the subwoofer range, I know the effects that low bass can have on music. As a conductor once said to me, my presence makes other instruments, such as clarinet or piccolo, sound better, when we play together.
    If you play music with significant information in the contrabass range through speakers that cannot reproduce those frequencies, then you are missing out on part of the musical experience.
    If the speakers distort the low notes, and/or cause the amplifier to clip, all the worse.
    That's the key isn't it ? Having speakers that can reproduce the whole musical spectrum. If you don't, then yeah, a sub is going to open everything up, especially with bookies.
    Nothing is taboo in audio, if it sounds good to you, roll with it.
  • K_M
    K_M Posts: 1,631
    In a single word....
    No
  • cfrizz
    cfrizz Posts: 13,417
    I have always used a sub in my system, Very few speakers are truly full range and can go that low. SDA's excepted.
    Until you hear the difference for yourself you won't really know what you are missing, the same applies to a powerful amp. That's why I encourage everyone to hear the difference for themselves.
  • codycatalist
    I don't personally need it with my SDA 2Bs but when I had my Monitor 5s I ran them with a nice musical 8 inch sub. I think it really lets the bookies shine like they are supposed to. I would never ask a Karate master to fight in a boxing ring and vice versa.
    msg Posts: 10,650
    I go back and forth. Sometimes I like the purer presence of 2ch, for instance, in dedicated listening sessions where I prefer overall balance and detail. For background listening or any sort of chillout/downtempo/electronic stuff, I'm in 2.1.
    Some prefer a very natural bottom end. Sometimes I like it fuller and fatter.
  • mdaudioguy
    msg wrote: »
    Can't stop laughing... yes, I've got a middle school sense of humor. :D
  • Nightfall
    Nightfall Posts: 10,083
    tonyb wrote: »
    Except equalizers and DBX stuff like noise reduction and dynamic range expanders. ;)
    afterburnt wrote: »
    Village Idiot of Club Polk
  • lightman1
    lightman1 Posts: 10,803
    mdaudioguy wrote: »
    msg wrote: »
    Fuller and fatter for me, thanks.
  • mdaudioguy
    lightman1 wrote: »
    Whatever floats your boat or tickles your fancy! TEHO! :p
  • Upstatemax
    lightman1 wrote: »
    That explains why you keep playing Meghan Trainor on a loop...
  • K_M
    K_M Posts: 1,631
    cfrizz wrote: »
    We do run subs with our SDA's, and feel it is necessary, especially with movies.
    While the SDA's do seem to have decent enough deep bass, its just not the same as a true sub.
    Plus removing the under 40hz or so stuff, seems to make the upper bass and mids of the SDA's cleaner and clearer.
    Always felt they compromised bass power handling to try to get deeper bass with most of the larger polks.
    The vintage Polk 6.5" drivers, have very limited excursion, so its tough to get truly deep bass, loud levels, and low distortion, even with several of them.
    2-15" Subs just do it so much more effortlessly!
    heiney9 Posts: 25,724
    If you need subs with SDA's, you have the wrong gear running them and/or room set-up issues. The excursion of the 6 1/2" drivers has nothing to do with the bass limiting you seem to experience. It's essentially a closed system, a fluid coupled system. The bass comes from the pressure inside the cabinet created by the mid-woofs to move the passive radiator. In fact the reason the bass is so extended and clean is because of the controlled excursion of all the mid-woofs.
    1C's are flat down to 30Hz (+/- 3dB) and play even lower at a few db's down and in the original review they had never tested a speaker that had that low a distortion figure at 25Hz. In fact they used the phrase "phenomenally low bass distortion" the lowest they had ever tested.
    SDA's had no issues with bass. 20Hz-18kHz +/- 5dB.
    You don't need a sub for SDA's.
  • lightman1
    lightman1 wrote: »
    mdaudioguy wrote: »
    msg wrote: »
    Two people agreed. It's not as taboo as we are told to believe...... ;)
  • ken brydson
    ken brydson Posts: 9,108
    lightman1 wrote: »
    mdaudioguy wrote: »
    msg wrote: »
    https://www.youtube.com/watch?v=7qDgCmzh5ao
  • lightman1
    Upstatemax wrote: »
    lightman1 wrote: »
    ;) Tell me you don't like that fuller more rounded bass(sic), then I will say you are in denial. And I don't mean swimming in the Egyptian river.....
  • WTS
    WTS Posts: 170
    lightman1 wrote: »
    mdaudioguy wrote: »
    msg wrote: »
    LOL.
    The part I especially love about "Big Bottom" is that they're all playing electric bass.
    It's all about the bass, 'bout the bass, no guitar....
  • lightman1
    Get on your bikes and ride!
    F1nut Posts: 52,406
    K_M wrote: »
    cfrizz wrote: »
    My SDA's will shame your subs.
  • ken brydson
    lightman1 wrote: »
    mdaudioguy wrote: »
    msg wrote: »
  • lightman1
    K_M wrote: »
    cfrizz wrote: »
    Pool of bass....and I swam in it.
    K_M wrote: »
    The test review would disagree with you. Lowest bass distortion ever tested (at the time) and I believe at 900 watts their reference amplifier (the most powerful in the day) ran out of juice before the SDA's ran out of "excursion".
    I am glad you enjoy your rig, but subs are a choice not a necessity with SDA's and they aren't really necessary.
